CAN-view sales
Discussion in 'Sponsored Commercial Sales' started by eflier, Nov 7, 2005.
  1. Frank Hudon
    Frank Hudon Senior Member
    4,147
    the CAN-view isn't a beta test unit, it's a working unit that displays the data that is on the buss. Just like normal software that gets updated from time to time that is what is going on here. Norm develops software for his unit. Then he posts it and if it's stable he goes on to working on poviding more usability with the module by posting Beta software. You down load it and install it and use it if there are problems you report them and he corrects it. Then posts an update. If it has a major bug you install the previous version. But not to worry as the 2k6 is not compatable with it as the MFD on the models with nav is a new unit. He's already posted this information. The base model without nav still uses the old style MFD on the 2k6 and as far as we know it's still useable on those models. BUT check with Norm or his website to find out for sure.
  2. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Get or down load a copy of Prius New Car Features from Toyota. If the owners manual is Prius 101, New Car Features is a 251 course. You get a much better idea on how the car works and you don't need a engineering degree to understand it. The standard software is very stable and you don't have to get in to the beta stuff. The CAN View gives you a peek at the internal workings. Everyone does this at his or her own level. I don't get out of this as much as Norm or Frank but I get what I can and stretch my brain. Keeps me out of trouble. Perhaps starting with the ScanGage. The problem with that is the generic nature of that instrument and it sits there and teases you into wanting a bit more.
  3. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    I'm sure your right... will Can-view clear error codes and if not, do you consider that an valuable asset to be able to see and clear error codes?
    Ill wait till I learn more..When the normal stuff becomes boring, then Ill be ready.
  4. eflier
    eflier Silver Business Sponsor
    164
    Fraser Valley BC
    This just in folks, I just received another 10 sets of those stupid custom Toyota NAV connectors, so that means I can build another 10 with-NAV units. (no limits on the without-NAV versions) Preference given to those who have already asked.
    In response to requests, I've been working on an upgrade which allows you to select a black background on all screens for night driving, either manually selectable or switched when you turn on the headlights. Sounds simple but it wasn't. Hope to post that (with a different mystery item) later this week. At which point the existing Beta code becomes the new standard issue code. and the version with selectable background becomes the new Beta test version. (In case there's any confusion)
    Also I now have plenty adapter cards, but still no sign of those Flashblaster programmers (although they are definitely en-route from the factory to me)
    Just noticed latest post while I'm writing this. I'm not trying to compete with scan-gauge: CAN-view does not read/reset trouble codes, its purely a CAN information display for those hybrid specific items that don't exist on the OBD2.
  5. Frank Hudon
    4,147
    I have the abilility to read and clear codes on my Classic MiniScanner but probably wouldn't clear a code, I'd probably read it, no I would read it but the car would go to the dealer to be fixed and the code cleared then if under warranty. I also have an OBD11 scan tool and can do it with that also. So for me no I really don't care if it does or doesn't, others might find that a disadvantage I really don't think so. Another thing is that a lot of the Prius codes are not read by most OBD11 scan tools, they are proprietary codes and don't show on most scan tools.
  6. windstrings
    6,280
    378
    Central Texas
    thanks for the reply.... I just didn't see a need to get the scanguage if the canview did the same thing... so it sounds like I may want both....
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,195
    Nixa, MO
    Norm,
    I think I found another bug with the software.
    Here's the sequence.
    From CAN-View screen press "Audio" button on bezel. Tap Text soft key. Press Audio button again (I was hoping that would return me to the CAN-View screen.
    Instead, it pulls up the 'I Agree' screen for the NAV system! I have to hit the INFO button twice (not 3 times) to get to the CAN-View again.
    Not sure if there are similar glitches with the Climate screen and others and it would be best if someone else confirms this too.
  8. eflier
    164
    Fraser Valley BC
    Hi Evan, I needed a means to select external video (camera, DVD) easily and so with no other buttons to use, I made the AUDIO button (audio/video?) toggle between audio and whatever external video source had been selected on the CAN-view setup screen. So toggling AUDIO (pressing it twice) brought up external video 2 (your NAV screen) and as you hadn't pressed 'I agree' yet, that was what was displayed. If you had selected RGB1 instead of RGB2 on the setup screen, AUDIO would have brought up whatever was plugged into the RGB1 socket (typically a camera) And if you had selected RVRS on setup, going into reverse would have brought up RGB1 with the camera image (or a black screen if no camera installed)
    If you don't have an external video source, select version 1 on the setup screen and AUDIO will no longer bring up an external video screen.
    Without referring to www.hybridinterfaces.ca, I recognise that this is a bit obscure, so on the latest code to be released this week, this AUDIO function is described a bit more clearly in a new separate video setup page.
  9. efusco
    19,891
    1,195
    Nixa, MO
    Ah, I see. Thanks Norm. Can't wait for my flasher part to arrive so I can update my software. Got my USB thingy from Digi-Key last week so I should be all set to go.
  10. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I am going to post a minor bug (“featureâ€) that is not a big deal it is just there. It is only for you Bluetooth phone users out there. When I power up and use the CAN-View as the default screen, the banner across the top showing Bluetooth connected successfully is not displayed. Interestingly the Bluetooth disconnected and Bluetooth unsuccessful banner is displayed. You do get the Bluetooth connected successful banner the first time you hit the info button and switch to the energy or consumption screen. The phone works as it picks up calls and I can make calls and is in fact connected it is not displayed on start up. A curious thing not a bad one as far as I can tell. Anyone else see this? My other theory is that it is a function of the Verizon v710 phone that I will replace next month. I am willing to blame anything on Verizon.
  11. joelparks
    joelparks New Member
    82
    Bedford, MA
    I get the same behavior with my Nokia 6280 (GSM, happens to have TMobile SIM). So I wouldn't blame it on Verizon or Samsung or whomever makes that phone for them...
    Joel
  12. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    That would be Motorola, I blame Verizon for everything! Well maybe not everything, but my phone! I don't think this is a huge thing but maybe it can be fixed.
  13. efusco
    19,891
    1,195
    Nixa, MO
    I think I must get that too....I noticed a long delay before seeing the BT success banner tonight but can't recall what I was doing at the time it came up. Motorola V551 with Cingular.
  14. joelparks
    82
    Bedford, MA
    Where can I locate this document?
  15. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
  16. joelparks
    82
    Bedford, MA
    Thanks - except the only things I could figure out how to get for free were the emergency responder's guide and the dismantling instructions. Interesting, but not what I was looking for...
    On another note, every time I look at your avatar picture I think that black dog is a gorilla, or maybe a chimp. Don't know why...
  17. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i know why... Sasha is a big as a gorilla!@@!
  18. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Sasha is a Newfoundland Retriever! She and her family have been mistaken for Bears but never Gorillas. If fact may years ago her great great Aunt and great great Grandfather, Fred and Natasha, were mistaken for Bears in Yellowstone National Park and we were reported for "chaining up Bears in our campsite" The Ranger that came to check out the report almost split a gut laughing when he walked up to our campsite. We had Ranger escorts all over the park and Fred and Natasha got more pats and loves that week than you can imagine. The Rangers spoiled them silly.
    The down load will cost you $10 a day but you can down load the New Car Features and the Repair Manuals in one day if you have a high speed connection.
  19. efusco
    19,891
    1,195
    Nixa, MO
    Norm,
    I got my programming card from you in the mail today.
    I've read through the instructions a couple times on the web site for installing updates, but I'm just not 100% confident I know what, exactly, to do.
    If I want the latest updates need I install only the last 3 files on the 'download' page (CVjan176, CLjan196, and CCjan196) or must I also upload one of the many preceeding files?
    I see that the switches need to be moved when installing to different CPUs, but it isn't clear to me which software goes to which ECU...that just isn't clear or I missed it in all the other verbiage. Specifically, the 3 files above, which CPU switches do they go to? All to the CAN? How can you tell b/c the file names don't really suggest where they go to me.
    Finally, I sort of need a simple step-by-step....do I run the flash program and then it'll tell me how to upload each file? How do I know when it's done (with flash program just say "file done" or some other obvioius clue?
    Does the car need to be powered up during the transfer or should it be shut down or does it not make any difference?
    Sorry to be so complicated, but I'm paranoid I'm going to mess up and fry one of the CPUs and at $300 I just don't want that to happen. I'd also like to suggest a step by step set of instructions clarifying those things above on the web site or in the box with the card.
  20. D0li0
    D0li0 New Member
    118
    Seattle, Wa
    http://www.hybridinterfaces.ca/Download.html
    When you run the flash program (mine anyway) it begins on a "Connect/Disconnect" tab. From there I first choose the Serial or USB programmer, it starts at serial and I have to click the USB radio button. Then I click on a connect button, which sometimes gives me some warning or error message about something being out of wack... But the connect light comes on so I ignore that, I've got some general USB flakyness going on with my computer...
    Next I have to click on "Download Hex File/Go/Stop tab. From that page I click Browse and find one of the three files. Once the file and the switches on the programmer match you can click the "Download" button and a little progress meter will pop up and should finish within a minute or so.
    Browse for the next file, flip the programmer switches to match, click Download.
    Once you are finished you can go back to the first "Connect/Disconnect" tap and click on disconnect.
    Hope this helps...
