CAN View Users (Charge/Discharge Limits)
Discussion in 'Gen 2 Prius Audio and Electronics' started by p626808, Dec 20, 2005.
  1. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    oic, ok maybe backwards then the neg one is the one on the bottom of the formatted screen. its the one with the generally higher RPM figure. so MG1 would be smaller of the two then?
  2. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Yes MG1 is the one that goes plus and minus mostly. MG2 is tied to the wheels.
    Not sure it will help with when EV mode switches off. I think that is best seen with amperes and you need to adjust the levels for battery temperature and maybe SOC.
    Engine will always come on well before the max current limits in my experience but this limit does vary with battery temp.
    Generally I look for 20 amperes when very cold, 30 when warmer and maybe to 50 when quite warmed up. Limits are maybe 50 cold and then over 100.
    EV button allows more amperes before engine start. Still the full limits are more likely reached when flooring the accelerator I think.
    But pushing accelerator too fast even a little bit also triggers engine on.
    I think MG1 may prove most useful on highway to see the torque and economy points. Not sure yet. Just got my update loaded.
    Still working on this as my SSC50P update has clearly changed the limits. I can regularly go up hills with engine off that I could not do ever before! And engine off mode works at like 20 deg lower temperatures too than before for a given amount.
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    haven't looked at the formatted screen in a while as I have set the text 1 screen to have
    amperage
    rpm
    MG2
    MG1
    throttle
    gas gauge
    currently that's what displays when the car first starts up. I did look at the formatted screen to check the min max results but don't nomally look at it unless something piques my interest. I change the text screens to suit my current interest. I should actually change the text 1 screen to have instead of gas gauge the ICE temp and will probably set it to that next time I use her car.
  4. eflier
    eflier Silver Business Sponsor
    164
    Fraser Valley BC
    On the MG1/2 topic, here's my reference numbers.
    MG2 is purely a function of road speed. It will vary with effective tire diameter (and so the load in the car and tire pressures) but not by more than maybe 2-3%.
    So as its supposed to be limited to 6000 rpm, that works out to be ~105 mph which is about what Toyota claim is the Prius top speed. You'll note when they did the 130mph Prius test, they kept the same MG2 limit by just putting on bigger tires. (Which of course needed more HP from the tweaked engine to get it to 130 mph)
    MG1 peaks at +10,200rpm for me under acceleration from standstill. And also at -6900 rpm so far, but its not clear what produces this other lower peak.
    On the odd discharge limit topic, I've been waiting for it to be warm enough to try an experiment. When warm, one limit (that I've called charge) peaks at 105 amps, while the other limit (that I've called discharge) peaks at 125 amps. So the experiment is, if you get the car warm and stable with these two limits reached at clearly different levels, and then accelerate/brake which current corresponds to which limit? You can't try this cold because the 2 limits are then roughly the same. Well its now warm enough (and wet enough!) to try here on the Wet Coast.
    What I saw was maximum discharge of 125 amps and maximum charge of 102 amps.
    That says to me the charge limit IS the smaller one, because if it wasn't, it would have limited the discharge current to less than 105 amps, not the 125 amps I saw.
    Which means despite it being logical that reaching a high SOC would cause a drop in maximum charge, that can't be what is happening. I am going to guess that what is being observed is the battery reaches a high state of charge and gets hot and the battery ECU says, I'm going to let the battery cool off, so I'm going to prevent high discharge currents for a while by dropping the discharge limit way down and I'm already preventing further charging by having switched to 'B' (engine braking) mode.
    And I'll remove these temporary liimits just as soon as the battery has cooled off a bit.
    But its just a theory....
  5. Frank Hudon
    4,147
    you with EV can on the set up screen change the box with the 3 dashed lines to 3>>> and that will give you the throttle amount on the second user graph screen that you can input before the ICE starts. It comes on as a line of >>>>>>>>>> and when the ICE starts it turns red. It'll give you a fairly wide line of >'s before it triggers.
  6. kk6yb
    kk6yb Junior Member
    36
    2011 Prius Alpha
    I was driving around today and the battery temp was about 100F. The discharge limit was -125 and the charge limit was 100. I was able to steadily draw -120 in EV mode without the ICE coming on. So it seems like the limits are labeled correctly.
  7. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    just got back and MG2 speeds i tracked
    2800 RPM=50 mph
    3050 RPM=55 mph
    3300 RPM=60 mph
    3575 RPM=65 mph (probably should be 3550 to match the pattern here.)
    also, have to question the discharge and charge limits being related to SOC...not seeing that yet. will have to observe a bit more. is there a way to put charge and discharge on a txt page?
  8. Frank Hudon
    4,147
    on the text page just push on what line you want the amperage to be on and CAN-view will take you to the setup section for that page push the A button and then push Save and it'll take you back to the text page and that line will show amperage +or-
  9. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    actually im looking for the Max charge and Max discharge numbers. trying to see a correlation between that rate and gonna compare SOC first and then battery temps... or maybe both to see if either varies with those rates. the format screen is a bit too busy and hard to read more than one simultaneous reading.
  10. eflier
    164
    Fraser Valley BC
    I am going to have to make a retraction here. 'Frenchie' has pointed out this article:
    http://prius.ecrostech.com/original/Unders...SplitDevice.htm
    Whilst done for the Classic and so a different final drive ratio than the current Prius, the PSD gear teeth numbers, according to NERL, have not changed and so the equation for MG1 should still be (3.6 X engine rpm) -(2.6 x MG2 rpm)
    I can't fault this article so will go back to the original calculation in CAN-view. So now I have to come to terms with seeing MG1 reaching 10,800 rpm, which is a lot higher temporary overshoot. But if that is the actual rpm, then so be it.
    I will correct the numbers at the same time I post the version with selectable graphs for MG1 and 2, in the next few days.
    Darn, I got it wrong....
  11. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    thanks for the info. your formula does work with the data i collected yesterday (allowing for some read errors)
    what i collected
    RPM...MG2...MG1...calculated compare last two for error margin)
    1300....0...4400....4680
    950..1475..600..-415 (large downhill numbers jumping probably accts for errors here)
    0...1250...-3400..-3250
    0...1350...-3400..-3510
    2350..3300..-300..-120
    950..3300...-5400..-5160
    2550....3250...0...730
    2400...3325...-200...-5
    can't wait for the new update...its like having a new toy to play with every other week!
  12. p626808
    p626808 New Member
    292
    Interesting theory on the charge discharge limits..
    Still no other reports of this?
    I am going to get the Stall recall update this weekend.
    Will see if that changes anything.
    Scott
  13. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    If you guys want to check your RPM ratios, try the simulator. Even though the simulator is simulating the classic, the PSD ratios haven't changed, thought the RPM limit for MG1 has been raised to 10K from the original 6500 limit.
    Would be nice if the simulator would show pwer input/output from ICE/MG1/MG2.
    MG2 had an RPM limit? I hadn't heard that.
    Also remember, not only do you have fixed RPM ratios, but you have fixed force ratios. From those 2, you should be able to calculate power ratios. Takes a lot of math though. I make too many derivation errors to do it myself.
  14. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I think Wayne Brown's THSII simulator does all these things...as far as graphing ratios...if MG1 is X and speed is Y then MG2 is Z, etc...
    http://privatenrg.com/#Nomograph
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ok Scott... i did see something that does lend so creedence to what you saw. situation was car still cold. going down long hill at 25 mph (State Street for those of you that know Olympia) SOC started at about 64%. discharge rate at 95 amps
    SOC is up to about 68% then discharge starts to drop and fast. by the time SOC is at 72%. discharge is down to 5 amps. unfortunately, hit the bottom of the hill. (i was really bummed <_< )
    so later on way back, same hill, different side. (going west to east is steeper shorter hill) saw SOC rise to 71% but discharge rate didnt change one iota. stayed at 98 amps all the way.
    more than a little baffled by this. obviously, not looking at the right combo of indicators. so (ya wasting gas now... :unsure: ) i get to top of hill, circle a 4 block turnaround route and go back down State Street again. this time, i get to 74% SOC and discharge rate still didnt change.
    ok...ummm... any ideas?? only thing i can see that was different was the first time, the Prius was not warmed up completely. i had just left my house and the hill starts only a few miles away.
    sooo... Scott, you may be on to something, but we need to be looking at something else too... any ideas?? im kinda lost
  16. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    OK I have not been down that hill with the CAN-View but I have been down it a lot of other times. 25 mph and they patrol it, a lot. You keep your speed down or else. I have been at 7-8 green on several occasions in the past. I usually cruse around the "filled in tide flats" of Olympia in EV mode and then up the hill a bit. It is a very nice hill for filling the battery!
  17. Canuck
    Canuck Member
    605
    Vancouver Island,BC,Canada
    Evan, what an excellent find! Thanks. Much more than this feeble brain can consume but extremely interesting. Next time around I think I'll become a mathematician, engineer, and master a Palm pilot. I can work an abacus tho' :D
    gary
  18. KMO
    KMO Senior Member
    2,022
    744
    Finland
    2023 Prius Prime
    120-125A as a maximum discharge limit sounds exactly right given the published performance figures. The engine is known to be 57kW max, and the max power is consistently quoted as 82kW, which leaves a 25kW shortfall to be made up by battery output. And 25kW/201.6V = 124A.
  19. p626808
    p626808 New Member
    292
    Well at least I am not the only one now.. :rolleyes:
    Anyway.. what you see is consistant with what I see..
    When your soc was at 74% what was your battery temp?
    I noticed the higher the battery temp.. the higher SOC need to start the Discharge amp limit dropage.
    A 74% SOC is borderline to start the discharge limit amp drop.
    Definitly by 75-77 SOC it should start to drop when warm.
    Anyway I was driving home last night and had another theory as to the value being display..
    What if the value is actually.. the limit imposed on discharging the battery..
    for instance.. as it approches SOC 80%.. the Battery ECU says.. Hey.. you are getting full.. I will not impose any limitations on what amps you can draw (besides the limits of the motor itself)...hence the value as you approch 80% goes down to zero amps as the limiting value as apposed to a max value?
    Any thoughts on that?
    I also got to 82% as a max SOC.. I saved that screen.. The engine turned on just as the SOC read 82%.. interesting..
    Another interesting fact.. The full discharge limit.. of 125 amps.. comes at battery temp of 77 degrees F.
    scott
  20. eflier
    164
    Fraser Valley BC
    I'll just add a note on the MG1/2 feature. I'm not afraid to admit while I read the article on the Prius planetary gearbox and the math made sense, my brain couldn't quite catch up with the idea. With it continuing to niggle away at my brain xcells, I made a 'gearbox' up out of styrofoam cut to a blown-up template from that article, with just 1 pinion gear as multiple pinions don't affect ratios.
    Then with the 'ring' held stationary (car stopped) I twirled it around by hand and counted the number of sun (MG1) revolutions for 1 complete planetary (engine) revolution.
    Yup, 3.6:1
    Why is it you can trust your eyes more than your mental ability? Or is that old age creeping up?
    [attachmentid=1761]
    PS: I rate this 'gearbox' at ~1/millionth HP with a warranty of about 2 minutes.....
