Can we bring up Power Mode again?
Discussion in 'Gen 3 Prius Main Forum' started by theCatman, Oct 2, 2012.
  1. theCatman
    theCatman New Member
    VA
    When is Toyota going to respond to the countless messages here and elsewhere on the internet (since 2006!) about allowing Power Mode as the default startup mode?
    I've almost been hit several times trying to pull out of a parking lot only to find I have no power!
    Having to remember to hit an extra button every single time I start the car is tedious and unnecessary. Many messages on the internet point to the same conclusion I've drawn as well, this being that the best mileage is only available in Power Mode given standard driving conditions in the USA.
    I can barely hit 48 mpg in EC mode but easily surpass 50 in Power Mode. I keep the acceleration light and even when starting using EV mode to get the car rolling, Power Mode to get to speed and in most city situations can use EV for the duration of my trips.
    On long highway trips Power Mode again outpaces both the EV and/or the default driving modes keeping me above 50 mpg.
    The Prius will remember the default mode and EC mode and I can think of no reason why I can't select Power as well as a starting default. I've asked them to respond to this and will post their reply. Meanwhile I and all of the other Power Mode users run the risk of an accident!
    Now that the incessant backup beeping has been put to rest, this is my only major complaint about an otherwise wonderful car.
    52,862
    no idea, hopefully soon.
  3. Mendel Leisk
    42,352
    Even though I never use it, ECO either, just leave it in "the mode with no name" (Normal), it seems overbearing that PWR doesn't stick.
    One other thing kind of like that is cruise control: it switches off when you shut down. I'm ok with that.
  4. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Of course you -could- just press the gas pedal further down. That is the only difference between normal mode and power mode.
    rxlawdude likes this.
  5. fuzzy1
    10,710
    Not until fuel economy is improved enough to score 50 MPG on the EPA label while in PWR mode. The consensus here on PC when the Gen3 was introduced was that it fell short of that score in PWR mode. For marketing reasons, Toyota didn't really want to be advertising 49 MPG.
    Speak for your own regional driving conditions. There is no one standard condition that applies to the whole USA.
    While many drivers do agree with you, many others do not. I'm one of those who do not. And none of us drives exactly like the standardized CAFE and EPA test cycles.
    markabele likes this.
  6. ETC(SS)
    7,563
    ….About the same day that they're sprinkling salt on the sidewalks from where HELL has frozen over. :D
    Toyota is rather like Mac in this regard.
    Do things their way, or feel free to join the unwashed Philistines in doing things the 'other' (read: dumb) way.
    I've got about 36,000 miles in type (G3, 2010) and it's one of those many little things that used to irk me about the car, but now I just mutter about it on occasion. I thought about tinkering with my G3 to force the car into PWR mode upon booting the car, but since 'my' G3 is not really "MY" G3, but a company vehicle.....those thoughts have died of loneliness. I do manage to eke out from 55-59 MPG in 'my' car (hand calculated - tank to tank) and I've not really noticed much of a difference when I jab the PWR mode or the ECO mode, or just leave it alone.
    I do notice the difference in acceleration between PWR and Normal when I'm using the throttle like an ON/OFF switch, but I live in a rural area and so I'm usually not operating in the WOT region.
    It's just one of the many reasons that Kermit the Frog always used to say: "It ain't easy being green..."
  7. walter Lee
    1,126
    376
    Maryland
    I switch to Power Mode when I believe the Prius will be stuck in bumper to bumper traffic (going less than 15 mph) for more than 15 minutes and the SoC is less than 55% - Why? I want to use the ICE sooner and use the electric motors less to avoid draining the HV battery to a SoC less than 50% so I can avoid activating the Prius automatic HV battery recharging cycle. The Prius automatic HV battery recharging cycle causes the MPG to drop between 5 -10 mpg for that trip so I try to avoid it whenever possible. While Power Mode in a traffic jam, I do mini Pulse and Glides. For example, while stuck in a traffic jam on MD Route 355 along the Military Base ReAdjustment Construction for the Naval Hospital in Bethesda ( this is a daily traffic jam during the weekday 2:30pm - 6:30 pm along northbound 2 miles road segment of Md Rt 355(Wisconsin Ave-Rockville Pike) from Cordella to I270 exit which can often take up to 60 minutes to traverse), I pulse ICE to get the Prius to 7-15 mph as quickly as possible and then shut down the ICE so I can glide the rest of the way. A mini pulse needs atleast 1.5 car lengths to do efficiently. As long as I can drive about 30 more minutes in regular driving after the traffic jam - I can nurse the MPGs back up over 50 mpg. When not in traffic jams, I usually use Normal Mode because I'm driving in many hilly terrain and it gives me a more balanced control over the throttle. If the roads were flat - I'd use Eco mode.
  8. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    You should call Toyota and log your complaint. Everyone else who agrees w/what you want should do the same thing.
    See Entune - class action suit, anyone? | PriusChat as to why.
    Seems highly unlikely that there'd be the bolded section since 2006. The power and eco buttons didn't exist on Priuses until the 2010 model year. Us US 2nd gen (04-09) Priuses have NO EV, power, nor eco buttons. 2nd gen Priuses in some other countries got an EV button though...
    I've had my 06 Prius since January 06 and have been following Priuses since then...
  9. Sergio-PL
    Sergio-PL Member
    160
    46
    Poland
    You get something for something else. US models didn't have EV button, but 3 years longer warranty support for almost 2x longer distance and from user point of view without sacrifice anything - except nice to have feature.
    In PWR mode accelerator is remapped for faster action and from time to time engine idles instead of shutting down. This means that from user point of view there is nothing in terms of security in not being able to enter PWR mode. Prius will accelerate from stand still and from some speed the same way like in normal and eco modes. It only depends on how fast you floor accelerator.
    On the other hand idling engine instead of shutting it down produces more emissions and makes it harder to pass emission tests with reasonable result. This way car manufacturer have to avoid making it default mode.
    You could ask why we can't disable traction control or on other cars why we can't set it default disabled.
    Look at it from the other perspective - Prius C owners even don't have a chance to try PWR mode. They only have ECO and Normal with no support for PWR.
    CT200h owners have 3 modes, which ECO and Normal gives 500V output voltage to the engine while PWR changes VSP VSC mappings and increases output to 650V. We have 650V all the time.
  10. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    No you haven't. Pwr mode provides no more power than Eco or Normal mode. In fact, if you are running heat or AC, you have MORE power in Eco mode, since less will be used for that. By the way in a parking lot, at low speeds, you have 295 foot-lbs of torque from the electric motors, more than some muscle cars.
    lensovet likes this.
  11. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Not true. PWR mode takes it out of the Atkinson mode and changes the performance of the engine considerably including the torque. The Toyota engine is not a true Atkinson mode engine but achieves it via electonic controls vs. engine construction.
    That is why PWR mode will always require manual intervention vs. being a selectable default like ECO modes.
  12. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Source?
    HTMLSpinnr and fuzzy1 like this.
  13. David Beale
    5,963
    1,990
    Edmonton Alberta
    It has been stated repeatedly here that the "modes" are mostly just a remapping of the throttle potentiometer effect. This was explained by Toyota that the purpose was to allow easier hypermiling or more efficient driving when in "eco" mode. "Power" mode was there to satisfy those who never have enough. A quick throttle response -feels- more powerful (just as most car manufacturers, like Ford, do it because their cars sell better when they do - the public is SO gullible). The modes do other things, such as reducing the AC cooling aggressiveness when you switch to "eco". I have NEVER heard anywhere that they change the engine parameters.
    So, YES, source?
    fuzzy1 and PriusCamper like this.
  14. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    What annoys me about what you've said is that it's simply not true that you have "no power" or any loss of power that can't be adjusted for by stepping on the accelerator further.... And then to claim you and others run the risk of an accident? Really? I'd love to hear you explain to the judge that aggressively swerving out into oncoming traffic causing someone to run into you is somehow a manufacturer defect. Come on! Gimme a break!
    And what doubly annoys me is that you celebrate the fact that you no longer have a reverse beep even though you admittedly have a hard time "remembering to hit an extra button every single time." Did you not know that the reverse beep exists for forgetful people like you who may not be aware that they have NOT shifted back into drive after using reverse?
    How long till you accidentally stomp on the gas to pull out in front of a fast approaching car while forgetting you're still in reverse and smashing into the car behind you instead?
    Or would you argue that you aren't forgetful enough to do that? And thus, if you aren't forgetful enough to do that what makes you forgetful enough to not hit an extra button when you start up the car every time?
    In other words, why not just enjoy your awesome car and stop whining and complaining? It's really annoying... I hope Toyota ignores you!
  15. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I run in eco mode all the time and have barked the tires on more than one occasion when pulling out in traffic, according to one theory, I would have sent the tires up in smoke and got hit, if I'd been in power mode.:)
    Tande likes this.
  16. fuzzy1
    10,710
    I believe that throttle remapping includes not just pedal position, but also time filtering. Filtering inherently causes some time delay. That means the heavily filtered ECO mode has more time delay from pedal to engine than does the lightly- or un-filtered PWR mode.
    So while numerous sources indicate that flooring the pedal produces the same engine power (and torque) in all modes, the time it takes for the engine to spin up to that power is different. PWR mode gets to full power the quickest, ECO produces the very same power but takes several tenths of a second longer to get there. Normal mode falls in between.
    Is the often unrecognized time delay the real cause of this longstanding PWR vs ECO disagreement?
  17. PriusCamper
    13,467
    5,434
    How many milliseconds of difference between modes are we talking about?
  18. Sergio-PL
    Sergio-PL Member
    160
    46
    Poland
    0.1 s or less?
  19. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    PWR is nothing more than a throttle response alteration. The curve (and likely time delay) are altered somewhat to favor a quicker response with a more aggressive curve. The perception of lack of power just means you're not pressing the Go-pedal hard enough!
    ECO reduces throttle response (and smooths inputs), as well as reduces AC power consumption (150-200 watts typically). My car virtually never leaves this mode, and I've learned to compensate by pressing more if I need to go faster. Sadly, this makes me a poor driver in cars w/o the feature as I tend to lurch forward in them until I realize that another car's pedal has a more "PWR" like response.
    In the NCF (New Car Features) guide, there's a graph that outlines the response difference. When "floored", all three modes respond with 100% power.
    It was one claimed that ECO and PWR also altered the voltage boost from the inverter. I call BS on that claim. Yesterday, I used a ScanGauge to show inverter voltage boost. Default cruise is 500v, but when you demand full acceleration, it'll boost to ~650v. This was the same in both ECO and PWR modes (in fact, ECO showed 650v, PWR showed 648v, but that's probably due to other factors).
    The claim that PWR changes the engine from Atkinson to Otto is false. This happens when you accelerate in ANY mode. During light engine loads, the ECU keeps the intake camshaft timing in a regarded position to delay valve closing until partially into the compression stroke. Heavier engine loads (or higher speeds) advance camshaft timing as much as 41° to be a bit closer to the more traditional Otto-cycle timing where the intake valve closes 61° after the the beginning of the compression stroke instead of as late as 102° afterward.
    It doesn't seem that the intake timing value has been identified for ScanGauge, or we could validate this once and for all.
    Codyroo, alekska, lensovet and 2 others like this.
  20. ProximalSuns
    1,877
    PNW
    The Prius engine is an "Otto" engine that uses electronic controls to get low torque results similar to Atkinson engine.
    Correct...dumps the "Atkinson" mode for the power and torque of regular compression sequence.
