Can we bring up Power Mode again?
Discussion in 'Gen 3 Prius Main Forum' started by theCatman, Oct 2, 2012.
  1. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    The delayed intake timing achieves the same results as a true Atkinson cycle engine without the complexity of an articulated connecting-rod. That point is moot - the point I'm making is that PWR mode doesn't force this any more than ECO other than the programmed response from the demand requested. I'm suggesting that at 50% demand (which would be more pedal in ECO, less in PWR), the cam timing would be identical.
  2. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    How can this be done without causing pre-ignition as the compression ratio rises toward the relatively high expansion ratio of an Atkinson cycle?
    Can you point us toward any technical papers explaining it?
  3. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Only Toyota's comment that the Prius engine construction is no different than their other engines. It is not built as a Atkinson engine. They get the same low torque, higher efficiency effect via electronic controls. They can take it in and out of Atkinson mode or more correctly have it in variations for performance from PWR mode, standard engine to regular mode, mild Atkinson, and ECO mode, full Atkinson.
  4. HTMLSpinnr
    5,341
    920
    251
    The 13:1 ratio is expansion under atkinson mode - 9.5:1 is the approximate compression ratio. With intake valve timing adjustment, I do imagine this would go a bit higher.
    Proximal, you'd do us all a favor if you quoted a published source.
  5. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    I'm also convinced that PWR mode does more than just remap the throttle response. I think it also delivers more power and torque to the electric motor while accelerating. In NRM mode if I push the pedal down harder to compensate for the throttle response, I notice the ICE revs higher with less net torque when accelerating from a stop than it does in PWR mode. In PWR mode you get less ICE RPMs and more net torque. That's either because they are changing the ICE timing to deliver more power or giving more power to the electric motor. I also find that my average mileage is better in PWR than NRM or ECO.
  6. walter Lee
    1,126
    376
    Maryland
    PWR mode turns on the ICE sooner than Normal or Eco Mode during an acceleration cycle/phase/event ( i.e. there is less of a delay between the time you press the accelerator and the time the ICE engages the transmission) - Engaging the Prius' ICE sooner than later helps to keep up with the power demands (of moving forward) when driving environment's power requirements are over and above what the NiMH battery will allow for (the NiMH maximum battery load is the power limiting factor not the electric motor - this is somewhat addressed by the Plug-in Prius by using a more powerful Li-Ion battery ). This is useful when the Prius is going uphill or accelerating from a stand-still or trying to maintain superhighway speeds (or little bit of everything above). One way around manually setting the modes in the superhighway scenario is to use Cruise Control(CC) to automatically handle the throttle. For example, in ECO mode because of the delayed throttle, I have trouble keeping the Prius speed at a constant fixed 55 mph going uphill - I tend to over compensate on the accelerator because of the delay response and end up going too fast or I under compensate on the accelerator because of the delay response and end up going too slow. Using PWR mode which has a faster throttle, makes it easier for me to adjust and control the throttle so i can maintain a fixed superhighway speed going up hill. The alternative Superhighway method is to set the CC to a particular speed when going uphill and let the Prius' computer control the throttle going uphill. At superhighway speeds with no elevation advantage, top speed is the determining factor in MPGs (especially when going on a uphill phase in a uphill-downhill cycle ), so anything that helps a driver limit the Prius' top speed helps in improving the Prius' MPGs. The only exception where the Prius MPG can slightly improve if its top speed is allowed to momentarily increase while slightly going downhill when that newly generated momentum/speed is needed to immediately to go back uphill (this technique is called Driving with Load or DWL among hypermilers)- during this following uphill climb the Prius sheds this extra speed/momentum gained during the previous downhill stretch as it climbs to the top of the next hill - DWL is suppose conserve the Prius' potential gravitational energy. With respect to the energy efficiency of any fixed/standardized vehicle, a hypermiler is manipulating four factors: conservation of momentum, consevation of potential gravitational energy, rolling resistance, and aerodynamic drag.
    hope this helps
    Walter
  7. mjones12
    mjones12 Member
    115
    26
    North Carolina
    My 2012 Prius Four is always in the Eco mode at startup. No button-pushing necessary.
  8. markabele
    5,084
    1,782
    Nebraska
    This isn't getting enough love. This is actually pretty brilliant and I now have something else for my hypermiling arsenal. Thanks!
  9. Former Member 68813
    3,524
    983
    US
    There will be no reference here as it's impossible to use 87 octane gas in 13:1 compression ratio without engine knocking to death. The whole Otto cycle under demand idea is nonsense, even if it sounds great on a surface.
  10. JE Sukara
    JE Sukara Junior Member
    17
    San Francisco Bay Area
    2018 Prius
    Holy cow! Are you all engineers?
  11. bubbatech
    bubbatech Member
    153
    60
    Alabama
    I submit that if you feel the need to use power mode all the time, then the Prius may not be the optimal car for you.
    markabele and HTMLSpinnr like this.
  12. HTMLSpinnr
    5,341
    920
    251
    I never suggested a full 13:1, however with advancing of intake valve timing, realized compression ratio could increase. I'd suggest 9.5:1 is an average compression ratio. Looking at the Toyota NCF guide for the 2010 MY Release, the SFI section outlines the VVT-i operating range. Intake valves close as soon as 61° after BDC (highest compression) to as late as 102° after BDC (lowest compression). Assuming that's a 20.5° spread either way from an average, and that compression ratios are linear (which they're probably not as piston speed and travel is greatest around 90° ABDC), that could translate to as low as 8.5:1 or as high as 10.6:1.
    That all said, I'm not sure all of that range is used under powered scenarios - there is some adjustment that takes place during no-power free-wheeling >42mph to minimize pumping losses.
    fuzzy1 likes this.
  13. fuzzy1
    10,686
    ^^ Thanks for the new valve angle map, it is slight different than Hobbit's Gen2 valve angles.
    If I'm computing the simple static geometry correctly, I'm getting compression ratios of 10.28 at 61°, and 5.95 at 102°. But a previous discussion indicated that this static result answer isn't the complete answer.
    HTMLSpinnr likes this.
  14. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    Its been reported as 9:1 maximum compression that can go down to 6:1 and averaging 8:1. There is a fairly aggressive cooled egr taking place also. The engine should run much cooler than a normal 4 cylinder ice.
    I don't know on the toyotas but honda leaves all the valves closed. That provides the lowest pumping losses.
    Yep But I can't remember the math.
  15. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    " and that compression ratios are linear"
    Piston movement should be sinusoidal, yes?
  16. HTMLSpinnr
    5,341
    920
    251
    Yes, though the offset crank could affect that somewhat. I'm not going to dig out my high school geometry, but will happily defer to those who can work that out for us, using numbers we already have (piston stroke, etc.). Max compression of 9.5:1 makes a bit more sense too, and that low 6:1 is likely where the engine is running during free-spin mode.
    As for cooled EGR, I don't believe this is introduced during high load situations, but rather during cruise to reduce pumping losses under part throttle, unless it would be in response to pre-ignition.
    There is no mechanism (like VTEC) in the Toyota valvetrain to hold all valves closed (disconnecting rocker-arms) - only severely retarding timing here could negate most of the intake stroke by blowing back via the compression stroke (which should feed the next cylinder's intake stroke during closed throttle).
    And with that, I realize that I've set a bad example in steering this thread rather off-topic.
    For those who would insist PWR mode is changing engine or drivetrain dynamics beyond the accelerator curve, we need more empirical data rather than anecdotal "butt-dyno" feedback. I've already dis-proven with a ScanGauge that inverter voltage remains the same in ECO, Normal, and PWR modes during full acceleration. Using the same tools (or the Torque app on a phone, or a TechStream laptop), one could look for differences in carrier frequency for MG2, total battery current, or MG2 torque at max acceleration. We might even be able to look at ignition timing, fuel mixture or fuel flow to see whether the ECU is enrichening the mixture differently (if at all) for ICE power. I'm not sure if anyone has found VVT-i advance angle as an XGauge or we could look at that as well.
    My point is, we need evidence rather than speculation to put this topic to rest.
    fuzzy1 and Corwyn like this.
  17. austingreen
    13,713
    4,231
    Austin, TX, USA
    Yes, I think that is it. In PWR mode I would think the ice would be on earlier, but not producing much power unless the battery was low. The aggressive cooled EGR makes this low power situation more efficient and the ice on allows the prius to deliver power quicker when called upon. Has anyone confirmed this with a scan guage, that the ice turns on easier?
    I assume EGR is also used as engine temperatures get hot to allow stoich mixtures without pre-ignition.
    Thanks I did not know the details of the system.
  18. Former Member 68813
    3,524
    983
    US
    Sorry, my comment was directed at ProximalSuns who boldly stated that Power=13:1 compression full Otto cycle and Eco= standard compression full Atkinson cycle.
  19. born_again
    born_again Member
    103
    47
    Rancho Palos Verdes, CA
    insane. Almost 40 replies to a guy that can't drive out of a parking lot without PWR button. LOL
    oh, original poster has ONE post.
  20. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    But on the bright side, only one person who replied gave incorrect data, and he always does and never learns.
