Can we bring up Power Mode again?
Discussion in 'Gen 3 Prius Main Forum' started by theCatman, Oct 2, 2012.
  1. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Don't see that I mentioned any compression ratios, just that the Prius engine is a regular engine not built as an Atkinson Cycle engine (you might want to look that up to see what an Atkinson Cycle engine is). Toyota notes they achieve the "Atkinson Cycle" effect via electronic controls, not engine construction. They could run a Corolla engine in "Atkinson" mode but at such a low torque setting, without the electric motor boost, it would be reeeeely slow acceleration.
    Relating to the PWR mode (and ECO and REG modes) that the normal construction engine in the Prius is run on a spectrum via the electronic controls from the low torque "Atkinson" mode to higher torque "Otto" mode via those controls.
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    I can't visualize this, can you explain?
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    The offset crank, or why it may affect the piston speed?
    Offset crank reduces lateral forces of the piston against the cylinder wall and makes the power stroke more efficient, by capturing the force in more vertical form rather than with the connecting-rod at an angle as the crankshaft passes beyond 90Ëš after TDC. I can't explain how I envision the geometry here, however this has to change the relative piston speed at a given crank-angle somewhat. Either way, this is a departure from the topic of the thread, and the technology is well documented elsewhere.
    Now we're just debating semantics. It's an Otto-cycle engine with an exaggerated intake cam-lobe to achieve an Atkinson cycle w/o the complicated linkage. Because of the duration of the intake valve opening, it's impossible to permit a traditional Otto cycle. Looking at the VVT-i graphic I posted, the earliest the intake valve closes is 61Ëš after bottom-dead-center (most intake valves have closed before bottom dead center). A traditional Otto engine would close MUCH sooner. Thus, regardless of intake cam phase, it's still going to be an Atkinson cycle. VVT-i only affects phase, not lift or duration.
  4. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    InsightCentral.net - Encyclopedia - Honda Insight Offset Cylinder
    You can work out the geometry from the diagram. I don't know the offset in the prius engine, but given that and the valve timing you can work out where in the cycle the valves open and close.
    The actual compression varies with rpm as this affects the way the cylinder breaths.
    Its a traditional engine design with atkinson valve timing:(
    The engine can not work in otto, both because of the valve timing and detonation problems. Otherwise they could just increase valve timing and run both. Mazda skyactiv allows for 13:1 compression in otto mode with regular gasoline, but it has a number of modifications (piston design, di, manifold) to allow it to do this. Skyactiv can also do the attikson valve timing, but part of it is implemented with variable lift as well as phase. That is off direct topic, but toyota could be doing something similar in gen IV.
  5. Former Member 68813
    3,524
    983
    US
    You don't understand the simple fact, if Prius engine was allowed to run in Otto cycle, compression would be 13:1. Why don't you look it up yourself, please, and report back when you get it?
  6. Former Member 68813
    3,524
    983
    US
    I did a simple experiment this AM while driving flat road at 40 MPG coasting at zero net charge (ICE off). I punched gas fully in quickly and let it go under a second 3 times each in different mode (normal, eco, power). Each time the ICE turned on, but didn't have time to accelerate the car noticeably before it was off again. I see no difference in response time in such quick gas on/off maneuver.
    LOL, I meant 40MPH.
  7. austingreen
    13,714
    4,232
    Austin, TX, USA
    Your butt dyno may be off;)
    Theory 1) Power has the ice on more often, so it is prepared to quickly accelerate. It would be nice if someone confirmed. Your test didn't test this as you put it in a situation where the engine would be off in power mode
    Theory 2) ECO mode dampens response to acceleration inputs. To test this you would need to time acceleration to a new point, say 40-50 mph, and tell if ECO mode got there as fast as power. You can't tell response if you simply slow back down again. You would start the stop watch when you pressed the pedal, then hit stop as you climbed through 50 mph.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    The Prius didn't have Power Mode until MY 2010, so anyone complaining in 2006 must have been prescient.
    Secondly, all modes have exactly the same amount of available power. If you almost get hit in normal mode, you won't do any better in power mode. Perhaps you need to leave more room pulling into traffic. If that's not possible, you may need a higher performance car.
    Tom
  9. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    There are many of them on this site and a lot of them on this thread
    JE Sukara likes this.
  10. qbee42
    18,058
    3,081
    Northern Michigan
    "How many engineers does it take to explain Power Mode?" The answer is 15: one to hold down the OP, 14 to beat him senseless with the technical details. :D
    Tom
    JE Sukara and HTMLSpinnr like this.
  11. ProximalSuns
    1,877
    PNW
    I prefer to take Toyota's word for it. According to Toyota it is not built as Atkinson cycle engine but achieves the effect via electronic controls. It seems to be a religious issue to some here that the Prius engine is "Atkinson cycle engine" (angel) and not an "Otto cycle engine" (devil).
  12. Corwyn
    2,171
    659
    23
    Maine
    And that 1 isn't doing their job... [Catman hasn't been on since the day he posted.]:D
  13. qbee42
    18,058
    3,081
    Northern Michigan
    A true Atkinson cycle engine uses an unusual crankshaft design that achieves the four stroke cycle in a single turn of the crankshaft. This was done as patent beater to work around Otto's engine patents. A useful side effect of this unusual linkage is that the expansion stroke can be longer than the compression stroke, allowing for greater efficiency at the expense of lower torque.
    Modern 'Atkinson' engines are really Otto cycle engines with altered valve timing. The intake valve is left open during the first part of the compression stroke, effectively shortening the stroke. This accomplishes the same thing as the true Atkinson engine without all of the extra mechanical complexity of the Atkinson crankshaft.
    Tom
  14. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Atkinson and otto cycle is activated by vvti on the intake side. The atkinson cycle has less compression, air and fuel = more efficiency. Power mode is just otto cycle, more compression, air and fuel = more power.
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    That happens not to be the case. ECO and PWR mode only change the throttle pedal User Interface. (ECO also alters the A/C cycle)
    The Prius has a 13.5:1 expansion ratio, if it was also the compression ratio, you would need a LOT more Octane rating.
    Maarten28 likes this.
  16. ChapmanF
    19,032
    Weird how a thread can fill 53 posts with competing misinformation, go dormant for six years, and get revived with more of it, everybody trying to guess at a topic that's explained and diagrammed in the manual.
    -Chap
    Maarten28 and farmecologist like this.
  17. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Chap, In their dreams, PWR mode means more power. Sadly, it just means more power for smaller changes in the accelerator pedal early in its travel.
    The intake timing DOES change, but not due to any push button. (gen 2 shown)
    danlatu, fuzzy1 and austingreen like this.
  18. danlatu
    533
    1,367
    maryland
    I guess i got this confused with the way the atkinson cycle works on the tacoma, how it can cycle from otto to atkinson cycle. I always thought the prius did the same due to having vvti on the intake side.
  19. arescec
    arescec Active Member
    238
    105
    Croatia
    Maybe you should not endanger others by recklessly pulling out in front of others and then blaming the car? My last car was heavier and had 90hp and still had no problems, and the car before that had 65hp and still no problems. Maybe different driving would help?
