Can we only use Toyota coolant?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Christina.cmb, Jan 13, 2019.
  1. Christina.cmb
    Christina.cmb Junior Member
    38
    16
    Bay area Ca
    Hi.
    Geting ABS pump replaced. Need coolant to complete the job. Does it have to be Toyota brand only?
  2. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Has to be the red type Asian cars
    SM-G965U1 using PriusChat mobile app
    Christina.cmb likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Your changing out a brake component and your putting in engine coolant:whistle:?
    SFO, edthefox5 and Jmack111 like this.
  4. Christina.cmb
    38
    16
    Bay area Ca
    Am i mixing up the anti freez for the coolant? Could of swore he told me coolant is removed when taking out ABS pump.
  5. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    The Anti- lock Braking System has Dot3 brake fluid present;).
    Coolant stays in the engine or inverter (y).
    SFO likes this.
  6. ChapmanF
    19,038
    It may not be uncommon to move the inverter out of the way for better access to the ABS actuator, hence a need for some coolant to refill the inverter loop after the job.
    I would recommend sticking with the Toyota SLLC.
  7. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Toyota coolant works very well, but there are options. I also like Peak Global Lifetime. Available at Walgreens for $13.99 a gallon pre-diluted last time I bought some.
  8. Mendel Leisk
    42,355
    Simple and safe is to use Toyota fluids, either their coolant or brake fluid.
    Skibob and Merkey like this.
  9. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    There's also Zerex Asian, typically around $12/gallon at Walmart.
  10. Christina.cmb
    38
    16
    Bay area Ca
    He said he has to bleed the brakes.
  11. Christina.cmb
    38
    16
    Bay area Ca
    Do you think my
    Mechanic is over charging me for labor? 600.00.
  12. Christina.cmb
    38
    16
    Bay area Ca
    Can you only buy it from a Toyota delaer?
  13. Mendel Leisk
    42,355
    You can buy through Amazon or EBay too, but dealerships are reasonably competitive in price, and close at hand.
    Christina.cmb, Skibob and Merkey like this.
  14. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Make sure you take home whatever he does not use. You might need it at a later date and it doesn’t go bad.
  15. Christina.cmb
    38
    16
    Bay area Ca
    L what do you if goes bad?
  16. Skibob
    2,912
    1,505
    Northern California
    The extra coolant, it never goes bad.
  17. Christina.cmb
    38
    16
    Bay area Ca
    Ok thanks for telling me. I didnt know that. How about motor oil and brake fluid? Do those expire?
  18. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Mobil will warrant their oil if used within 5 years of purchase. I guess this is because they will modify/enhance their formula in this time frame.
  19. Mendel Leisk
    42,355
    Speaking of things "going bad", I read in one Toyota document, to always use fresh/unopened bottle Toyota ATF WS (the transaxle fluid). They claim it goes off, attracts water IIRC.
    Brake fluid is similar: I tend to use what I need, keep any left over for just a few days while monitoring level, then recycle it. Dealership will take it I believe? Last time I was recyling it Mr. Lube (who takes used motor oil) turned me down; I managed to leave it with their neighouring business that does do brake work.
  20. Skibob
    2,912
    1,505
    Northern California
    If oil does it’s more years than you will be driving. Brake fluid on the other hand attracts moisture if you don’t keep the bottle tightly sealed. Always seal the bottle right after you are done using it. Sealed it will last for many years, you would wind up throwing it out because the bottle looks old before it actually goes bad.
