Can you disable the "panic brake stop" ?
Discussion in 'Gen 3 Prius Technical Discussion' started by Higgins909, Aug 6, 2022.
  1. Higgins909
    Higgins909 Member
    289
    71
    I am absolutely tired of this safety feature. It's barely mentioned in the manual as brake assist iirc. Basically what happens is that you go from gas to brake too fast or brake too fast and it will think you're panic stopping and lockup the wheels, even as you're letting back up as you feel it slam down on them.
    Note: Camera makes everything seem slower and further away. I'm not sure if you can tell a clear difference between 30fps and 60fps but this camera is 30fps and real life felt like 60fps. (x1.5-x2.0 on youtube?) The "cutoff" wasn't that bad but not that great. I was planning to do a smooth brake all the way up their rear, but that didn't happen.
    Here's today's event. I going down a 55mph doing about 60 and then get up to some traffic and am mumbling about the person in front of me is in fact turning with no blinker and slowing down to about 40mph. This whole time I'm trying to watch for the car that in the end ended up pulling out in front of me and ride slightly left of the lane. (Problem area)
    Then they actually do pull out and I go from slight throttle to little "physical brakes" and it ends up locking up my wheels and crud was flying around my car. I go down to about 20mph and pretty much coasted up to them. They never got any real speed.
    I'm not really upset so much at the driver that pulled out, but the way the brakes behaved and that I have no idea if I almost got rear ended because of this stupid safety system.
    TL;DR tapped my brakes and almost came to a skidding stop.
    52,768
    that doesn't sound right. correctly working abs should prevent the wheels from locking, even when you hold your foot on the brake as hard as you can
  3. Higgins909
    Higgins909 Member
    289
    71
    I'm not sure if abs was working or not. The A/C is so loud. The post is more about how I barely touched the brakes and the car acted like I slammed them down to the floor.
    52,768
    can you locate that o/m info? maybe it's an option i don't have. i've heard of hill park assist or something, but not brake assist.
  5. Higgins909
    Higgins909 Member
    289
    71
    So in the PDF manual I have it's 2-4. Using other driving systems Driving assist Systems Page 245 on the paper. If I use the search function on the manual, it's the 1/8 for "brake assist".
  6. Higgins909
    Higgins909 Member
    289
    71
  7. Elektroingenieur
    2,515
    3,288
    Three Touring
    The brake assist feature, which provides increased braking when the driver presses the brake pedal, is implemented in the skid control ECU firmware, and I don’t know of a practicable way to disable it.
    The pre-collision braking feature, in which the car might apply the brakes on its own based on input from the millimeter wave radar and other sensors, can be disabled using a switch; see “Disabling pre-collision braking,” Owner’s Manual (PDF), page 250.
    Higgins909 likes this.
  8. CR94
    CR94 Senior Member
    2,817
    1,236
    Northwestern S.C.
    In my experience, behavior of that feature is not as extreme as you describe it, but I agree that it's annoying. Press the pedal quickly but not hard, and the car briefly brakes hard.
  9. Tombukt2
    Tombukt2 Senior Member
    13,802
    2,503
    Durham NC
    So it's like insurance for spazes. I would think that's a good thing keep people from rear ending folks I've never noticed it so I don't know if my car doesn't have it My 2010 car that my wife has has every available option solar roof blah blah blah course she drives like herself so she probably doesn't even know if this feature exists
  10. Tombukt2
    13,802
    2,503
    Durham NC
    I can't imagine being in any Prius and having to stomp on the brakes right smartly going say under 25 miles an hour just take your foot off the brake and steer around the boob or drive in the grass or whatever but I mean it 20 miles an hour even if the brake locks up unless you just have crap laying everywhere in your car to go flying even with all my tools and stuff in here I got one or two items that'll slide to the forward edges of the back seats maybe and that would be about it
  11. bisco
    52,768
    if my car is equipped with this, i have never experienced it.
    i'll have to check the o/m
  12. Mendel Leisk
    42,253
    Desciption of the Pre-Collision System starts on page 249 of Owner's Manual. There is an asterik and footnote saying "if equipped". "Brake Assist" is also mentioned. There's a button to disable (screen-grab from page 250):
    ^ I looked: our 2010 CDN Touring model doesn't have that button, nor radar cruise.
    Do you have radar cruise too? Not sure, but wondering if brake assist requires radar cruise.
  13. Elektroingenieur
    2,515
    3,288
    Three Touring
    It doesn’t. A sales brochure for 2010 shows that the Star Safety System, including brake assist, was standard on all grades for the U.S. market, but dynamic radar cruise control was available only in an option package.
  14. fuzzy1
    10,687
    Is it really locking up, or is it just going into full force pavement-grabbing ABS braking? As previously mentioned, it shouldn't really be locking up unless there is an ABS system failure.
    This is important to figure out.
    Your car is equipped with it. I had several unwanted experiences with it in my first year of Prius ownership, but those experiences recalibrated my braking reflexes. Now it happens only when it is actually appropriate.
    Considering that a not insignificant number of drivers just don't push the brake pedal hard enough in certain situations, resulting in collisions that are either avoidable or have less than optimum speed reductions before impact, I don't expect that this feature will getting a disable function.
    #14 fuzzy1, Aug 7, 2022
  15. Higgins909
    Higgins909 Member
    289
    71
    So mine is a 3 trim level and I think you need a 5 trim for the radar and ACC. The only button I have under there is the TPMS. My steering wheel has no buttons on the right side fort he ACC. I guess there is nothing I can do about this feature. My first year with this car was pretty rough because of this. (had about 4 years now) My previous car, a 04 Honda Accord had about 2" of free travel for the brakes. I was so used to instantly pressing down that 2" to get light braking that it was problematic in the Prius.
    However over the years, there have been unpleasant instances of this safety feature. Some that I remember are a red light in the rain and stopping for a pedestrian waiting to cross in a crosswalk. A squirrel ran out in front of me... To many instances in my own neighborhood. Getting some whiplash...
  16. ASRDogman
    ASRDogman Senior Member
    8,038
    4,074
    Why did you say the a/c was so loud? Are you running the fan on high all the time?
    Have you thought about taking to a dealer, or a shop that specialized in Prius's and have
    them check it out?
    Or use techstream or similar to check it?
  17. bisco
    52,768
    i would say it is because i drive so carefully and never have to hit the brakes quickly with force, but o/p said he 'went from slight throttle to very little breaks'. i do that all the time, and it has never happened.
  18. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Ive never heard of a silent AC system in a car, you got a good point
  19. bisco
    52,768
    who said the a/c was loud?
  20. ChapmanF
    18,950
    not sure. couldn't hear over the a/c
