Can you recommend a coolant bleeder tool?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Krall, Nov 9, 2022.
  1. Krall
    Krall Member
    125
    37
    NY
    My 2010 Prius sounds at some points like a river is flowing under the drivers dash after flushing the system (anti-Freeze) and replacing the coolant.
    I don’t have a bleed valve. I tried running the car with the overflow cap off and that didn’t really help.
    I see there’s some cheap funnel like tools on Amazon, but not sure how they’d work with the overflow design. Most of the descriptions say they keep air out while adding coolant.
    Any recommendations for a tool?
    thanks!
  2. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    Under the driver's dash that doesn't really make sense I wouldn't think the driver side of the dashboard would have much coolant might have inverter coolant over on that side and it's pumping and what have you but there are minimalist amount of hoses that run to the heater core but you should be able to slow fill the system and get it to work out
  3. Aegean
    Aegean Active Member
    464
    209
    Alexandria VA
    I am using a Robinair 75260 Coolant refiler on my cars including the Prius and no air bleeding is ever needed. Very quick coolant change process.
  4. Krall
    Krall Member
    125
    37
    NY
    I guess more accurately it’s the drivers side in front of the dash. Like you said mainly small hoses, but I’m assuming it’s the EGR cooling circuit. I have no inverter coolant loss and haven’t done any maintenance too it.
    I slow filled the system adding a little coolant at the time.
    I have virtually no heat now either.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,604
    Taylors, SC
    I use the original all metal UView tool, but I've heard good reviews on the less expensive ones sold by Harbor Freight.
    Both takes less than 30 minutes to drain and refill coolant without having to put the engine in service mode.
    Krall, StarCaller and Tombukt2 like this.
  6. Mendel Leisk
    42,355
    Are you sure? It’s a black plastic junction, with white plastic screw cap at top, and a spigot just below that you can push tubing onto, if you want to keep it neat. It’s just above the EGR components; should be on a 2010, unless it was replaced at some time: I believe they kept the part number but deleted the bleed feature??
    m.wynn, PriusCamper and Krall like this.
  7. Tombukt2
    13,864
    2,519
    Durham NC
    Good Lord that's too funny never would have imagined that is great though but haven't needed it so far so I don't know I haven't even used the maintenance mode or whatever I just fill it up slowly and turn the car on and I don't know whatever everything seems to be fine.
    Krall likes this.
  8. Krall
    Krall Member
    125
    37
    NY
    Thanks!
  9. Krall
    Krall Member
    125
    37
    NY
    It’s on the back side of the tank near the top the the neck?
  10. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    Near the top end of the EGR cooler, which is the highest point of the cooling system. Not used after some point in the 2011 model run, so my later 2011 doesn't have it.
    Krall and Mendel Leisk like this.
  11. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Our 2011 doesn't have it either. Here's a picture of the hose without the valve, there's a sensor on one side and a blank tube on the other side. 20210904_141900.jpeg
  12. rjparker
    rjparker Tu Humilde Sirviente
    11,119
    6,975
    Texas Hill Country
    I have replaced my coolant several times and never had a problem. Just measure what you take out and put the same back in. Run the engine with the cap off long enough to warm it up.
    Krall and Tombukt2 like this.
  13. ChapmanF
    19,035
    Another approach that works is the one in the repair manual: fill the bottle to the B line (this is the only time you ever use the B line), and run the engine up to operating temp and several minutes more with the cap ON the bottle, and squeeze and shake some hoses during those several minutes after warmup.
    Then shut the car off, wait for everything to cool, and verify that the now cooled-down coolant has dropped from the B line to the F line. What it did was trade places with the air in the system. Gen 3 uses a degas-bottle system design, with that headspace in the bottle being where the air ends up.
  14. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    The potential problem with that routine is that some important hoses are inaccessible for squeezing and shaking unless one has the lower cover or air intake tubing off, or has very thin arms with extra joints.
    Krall likes this.
  15. ChapmanF
    19,035
    No extra joints here, though my arms might be thinner than some.
    I don't really go squeezing and shaking every possible hose. The big easy ones do the trick. It makes some surges in the flow and the steady flow from the water pump takes care of the rest.
  16. Mendel Leisk
    42,355
    If OP is missing bleed valve, disconnecting one of the hoses at that aforementioned gizmo would also work.
    Krall likes this.
  17. xliderider
    8,140
    3,280
    Honolulu, HI
    Didn't disconnect any hoses to bleed air, and didn't have any problems. YMMV
  18. ChapmanF
    19,035
    The repair manual also did not add any remove-some-hose step to go with the removal of that extra valve. It just still gives the procedure described in #13, which still works.
    Krall likes this.
  19. Mendel Leisk
    42,355
    OP thinks he has trapped air; can you ease up on the sarcasm?
    Addendum: FWIW, the 2010 publication of Repair Manual says to open "air release valve" before filling. I did that, felt air coming out when filling, and then a flow of coolant. Since Toyota subsequently deleted that valve, pulling off a hose in the vicinity you'd think would do similar function. And it's likely intent is to reduce/eliminate air pockets?
    #19 Mendel Leisk, Nov 10, 2022
    Krall, bisco and Tombukt2 like this.
  20. Tombukt2
    13,864
    2,519
    Durham NC
    Looks like you could just add the 2010s valve it's on my 2010 with solar roof that my wife drives I went out and looked yesterday we've never used it I didn't even know what it was just sittting with a white cap on it.
