Can you switch the temperature display from F to C?
Discussion in 'Prius c Technical Discussion' started by col127, Jul 27, 2012.
  1. col127
    col127 Member
    345
    Illinois
    Hi All,
    Is it possible to switch the temperature display (outside and the climate control) from Farenheit to Celsius? Couldn't find it in the settings anywhere but maybe I'm missing it somewhere. :)
    I've got a C 3. Thanks!
  2. Izham Aziz
    Izham Aziz Junior Member
    67
    Kuala Lumpur
    Yeah, anyone know also how to change the fuel consumption display from KM/L to L/100km perhaps?
  3. rjdriver
    rjdriver Active Member
    400
    166
    Rhode Island
    Was unable to find a way to change either of the above, but you never know. Even the way to change from miles per hour to kilometers per hour is buried in a weird unintuitive place.
  4. cpfans4
    cpfans4 Junior Member
    42
    illinois
    With your odometer visible press and hold the trip button and it will change to Kilometers
  5. Izham Aziz
    67
    Kuala Lumpur
    will this change the consumption unit too? I mean from km to miles, so consumption unit from KM/l to mpg or maybe to L/100km?
  6. col127
    col127 Member
    345
    Illinois
    haven't found a way for that :( only thing i've seen is switching the speedometer from miles to KM... and you can switch the units in the navigation from miles to KM... but haven't seen any switching of odometer/gas consumption or temperature... :(
  7. Izham Aziz
    67
    Kuala Lumpur
    So if you change speedometer reading from Miles to KM, the fc unit still stays as MPG?
  8. col127
    col127 Member
    345
    Illinois
    Yep :(
  9. Izham Aziz
    67
    Kuala Lumpur
    Tried holding the trip button while at ODO display. Nothing happens.
