Can you tell on this picture if the rims are OEM or fake?
Discussion in 'Newbie Forum' started by animuz1, Aug 29, 2015.
  1. animuz1
    animuz1 New Member
    netherlands
    Firstly I am new to the forum.
    I registered because i have a question that probably only toyota fans know.
    I am planning to buy these rims for my winter tires on my lexus ct200h
    The seller says the rims are OEM and should fit my ct200h. The hub bore on the ct is 54.1, how do i know these rims have the same size hub bore? Should there be written on the rims aswell?
    I hope you guys know the answers to the questions.
    Peter
  2. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    I don't have a ct 200h, but these look aftermarket to me or OEM of other Toyotas, not Lexus!
  3. animuz1
    animuz1 New Member
    netherlands
    I own a lexus and i am planning to buy used toyota rims. The seller told me these are OEM toyota rims. Is there any way to check that and the hub bore?
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Could they be 16" rims from a Gen2 Touring?
  5. animuz1
    animuz1 New Member
    netherlands
    These rims are 17 inch. The seller told me the hub bore is also 54.1, same as the lexus ct200h. Only thing im concerned about now is how to tell if these rims are real toyota rims or some fake ones.
  6. JC91006
    16,470
    8,383
    Oem rims are stamped Toyota on the inside of the rim. They might be Corolla wheels
  7. hill
    8,073
    not stock gen2 touring. We have a family member with one of those and that's not them. But they do look nice. Weather they're fakes it is another thing -
    #7 hill, Aug 31, 2015
  8. hill
    8,073
  9. Tideland Prius
    16,074
    I don't know about the "size hub bore" but the rims should be 5x100 specification (that's 5 bolt pattern, 100mm apart between the bolts).
    As far as fake vs. real, I'm not sure but as a long time Toyota follower, I'm struggling to visualize what Toyota came with those 17" rims. Nothing comes to mind. Then I google'd the images and eventually found that it's from a 10 year old Avensis! That explains why we won't recognise those rims because they were never fitted to a U.S. spec car (and of course the Avensis isn't sold here)
    I guess you could check the weight and see if they match the weight of the OEM rims (if you can find the specs), maybe see if there are any weird cracks or poorly manufactured joints.
