Can you turn off the light that shines on shifter lever?
Discussion in 'Gen 3 Prius Main Forum' started by rpg51, Aug 26, 2012.
  1. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Maybe im just use to it........My Caddy had the same thing.
  2. Its34below
    Its34below Junior Member
    Roanoke VA
    I got the same model except mine's 12 years old now. If anybody's still watching this thread, mine stopped working and I miss it is there a fuse to check I can't find it on the list thanks in advance.
  3. Mendel Leisk
    41,479
    Any post brings the thread back to “new posts”, so lots of people. :)
    Maybe bulb failed?
  4. amarino
    amarino Active Member
    139
    102
    99
    Since this is now brought back up, I'll share some pics of when I swapped out the LED from white to red. It is a bit involved as the LED is in a plastic housing that has clips and soldered to the PCB. So you have to first de-solder the LED, then unclip the black housing part that holds the LED.
    ASRDogman likes this.
  5. GFO
    GFO Member
    75
    50
    Larkspur
    @amarino Nice job.
    Red sharpie pen, a steady hand and a couple of seconds will give you a nice red glow too. I've not done it, but I've pondered doing it.
  6. Its34below
    Roanoke VA
    What fuse is that bulb on and is it on the same circuit as the interior map lights if so then I imagine the bulbs bad I think I'll stick with white though because I use it a lot to read invoices while I'm driving at night and it's driving me nuts now
  7. ASRDogman
    ASRDogman Senior Member
    7,599
    3,915
    put a piece of electrical tape over it.
  8. Its34below
    Roanoke VA
  9. amarino
    139
    102
    99
    Since the LED is soldered onto the board you can look at getting a replacement map light assembly. Either from eBay or a local junkyard if you are lucky enough to have one nearby. It is also not that hard to swap just the PCB since it is only a handful of screws that hold it into the plastic assembly. Here are some examples from eBay:
    2010-2015 Toyota Prius Roof Overhead Console Dome Map Light Lamp 1D111-124G OEM | eBay
    2010 - 2015 OEM TOYOTA PRIUS FRONT CENTER OVERHEAD INTERIOR LIGHT | eBay
    Toyota Prius 10-15 Overhead Console Map Light Lamp, Gray, A853, OEM, 2010, 2011, | eBay
