Canada Prius Prime trim level details
Discussion in 'Gen 5 Prius Main Forum' started by beamsley, Jan 6, 2023.
  1. Trollbait
    12,831
    It was mentioned somewhere, plus the pack in cutaway photos seems too small to have air cooling.
    52,862
    i can't wait to see the details on that, a major change for toyota!
  3. Trollbait
    12,831
    o_O The Rav4 Prime has liquid cooling.
    But I wasn't being a completely clear before. I used liquid cooling to also include coolants that are liquid only part of the time; refrigerants.
    52,862
    A first in plug-in Prius.
    Still not clear , can you describe the coolant system details a little more?
  5. Trollbait
    12,831
    Haven't come across an indepth description, but sounds like cooling is accomplished by A/C cooling lines through the pack. The old Escape hybrids did this for their packs.
  6. Christopher O'Brien
    153
    79
    Toronto
    2013 Prius Plug-in
    Too bad the Prime's bigger battery plus its accoutrements like the cooling system mean that there isn't room for the rear AWD-e that the non-plug-in Gen 5 gets. I've asked Toyota Gazoo Racing in Germany (the folks that brought us the world champion GR010 WEC hypercar) to have a go at designing a smaller AWD-e to fit under (around?) the Prime's battery. I'm thinking that perhaps all the fancy (small, lightweight) technology put into the GR010's electric front axle could be adapted to the Prime's rear axle(s). No answer yet, but I dream. :)
  7. nukem
    nukem Junior Member
    34
    Ontario, Canada
    Does anyone have an idea when Toyota Canada will finally update their website with the new Prius info?
    I know we're a sad second cousin for a lot of things but I'd expect that someone with a little bit of marketing savvy at Toyota Canada would be hyping the heck out of this. But noooo we're still showing the old Prius with not a word of something new.
    Call me :(
    moonmist and mountaineer like this.
  8. Tideland Prius
    16,681
    Toyota Canada only updates the site when the vehicle goes on sale. It’s been their MO for decades so not expecting that to change.
  9. nukem
    nukem Junior Member
    34
    Ontario, Canada
    Spot on but sad.
    Sigh, where is the Toyota much vaulted continuous improvement? Everyone in business knows that you have to market early and a lot.
    All the Canadian website wants to do is send you to a dealer. Fine, but I want to research first before I get the sales pitch and told what I can't get that our cousins down south can get. :)
    OK, enough bitching. I love the new design and while we argue about mpg between one model and the other, this is the first model of Prius that I would consider buying again. I really wasn't enamoured with the last generation as it looked too much like something from the transformer movies. But that's just me ...
  10. Trollbait
    12,831
    Is that why the Prime doesn't AWD, or could it be because of marketing or logistic reasons?
  11. beamsley
    beamsley Member
    66
    100
    2023 Prius Prime
    Premium w/ Solar Cells
    From what I read somewhere, it's a packaging issue. They weren't able to fit both the Prime's battery and an electric motor in the rear. The HEV doesn't have the same space constraint since the battery isn't as large.
  12. Tideland Prius
    16,681
    If you’re friendly with your dealer, they may let you in on the vehicle order form ahead of time. But that’s usually a month in advance at most.
  13. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    Actually it has to do with the Solar roof option. They have to fit a couple of pieces of equipment to deal with DC/DC conversion, temporary storage and its cooling system. Europe's Prius Prime (called Prius PHEV) had solar panels and needed the middle console to install a small NiMH battery for temporary storage as well as a DC/DC converter. One of the reasons the 2nd gen Prius Prime seated only 4 for the first 2 model years.
  14. Trollbait
    12,831
    Considering where the traction battery is, I'm guessing the new solar roof doesn't use an intermediate battery as a buffer.
  15. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    It'll have a combiner, DC/DC converter to traction battery. I'm assuming they integrated the ECU and cooling system with the DC/DC converter. Not sure about the exact packaging but don't forget they also have 120V 1500W outlet(s ?) that have to have DC/AC Inverters. They have to put them somewhere as well.
    JoeBlack likes this.
  16. Christopher O'Brien
    153
    79
    Toronto
    2013 Prius Plug-in
    If the absence of AWD-e on the Prime is not due solely to the bigger size of the Prime's battery but also due to a bunch of other stuff stuck under the back that drash has mentioned above, then maybe I'd be willing to do without some/all of that other stuff and whatever features they serve so I can have the AWD-e. At least Toyota should give us a choice rather than just a blanket "no". Does anyone know where to get a look at a technical analysis (or better a video) of the situation?
  17. mountaineer
    mountaineer Active Member
    146
    115
    Hamilton, ON
    2019 Prius Prime
    Anyone else notice how they've raised the price on the 2022 Prius Prime. When did that happen?
    Earlier in 2022 wasn't the base model in the $33,000 range, the top trim around $40k. Now the base model is about $37k, and the top is $42,200. Will be interesting to see how this changes for the 2023.
  18. bisco
    52,862
    nothing available yet, but in the end, whatever the reasons, we can't change toyotas mind
  19. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    No tech details yet. They still have a ban on 2023 Prius Prime details other than that released by Toyota. We don't know how much the Solar Roof outputs (the old one was 180 W), the exact battery cooling details, and only cursory picts of the layout. Another reason for not putting in a rear e-Axle is weight distribution. The 13.6 kWh battery is still a good chunk of weight sitting by the rear wheels. Final design details are probably still being finalized.
    Notice there are no picts of the gas tank (more added weight in the rear) or other necessary objects like the charging circuitry which we don't even know what the maximum AC charge is. Hopefully they make that 6.6 kW across all trims.
  20. Christopher O'Brien
    153
    79
    Toronto
    2013 Prius Plug-in
    Thanks, Drash. I guess we're just going to have to wait and see what turns up. Btw, where did you find that pic of the drive train?
