Canadian Driver. Lithium vs Nickel battery in cold weather
Discussion in 'Gen 4 Prius Main Forum' started by Shamalamabingbong, Feb 13, 2020.
  1. Shamalamabingbong
    Shamalamabingbong New Member
    Two Eco
    question: do you mean the 2016 trim levels that used lithium have the battery heaters in the year 2017 or do you mean the actual year make as in the 2017 prius?
  2. Tideland Prius
    16,683
    AFAIK, it’s Model Year 2017 when they added a battery heater to the Li-ion models which allowed them to sell it nationwide.
    2016 did not have a battery heater so those trim levels were only available in Toronto, Montreal and Vancouver.
  3. Shamalamabingbong
    Two Eco
    Other question: is there an aftermarket method of installing these heaters?
  4. Prodigyplace
    12,720
    11,852
    Central Virginia
    I would look at the 2017 Canadian parts list. You may need to add a thermostat to control the heater though.
  5. Tideland Prius
    16,683
    I’m not sure. It was only for that one model year. The battery has to be at -30°C for that battery protection to kick in. That means the car has to be parked in -30°C or below for at least several hours. Hopefully a garage is a touch warmer.
    Prodigyplace likes this.
