CanBus connection for China Android Headunit
Discussion in 'Gen 2 Prius Audio and Electronics' started by Michciu94, May 22, 2022.
  1. Michciu94
    Michciu94 Junior Member
    44
    Poland
    View attachment 226509 View attachment 226510 View attachment 226511 View attachment 226512
    Hello.
    I’ve bought CanBus Android Head Unit 2GB for Prius 2 at the AliExpress and I had some problems which seller don’t help so maybe someone here will. Here is Ali info:
    US $118.18 54% Off | ZUIDID Carplay Autoradio 2 din Android 10 For Toyota Prius 20 2003-2009 Car Radio Multimedia Video Player GPS Navigation Stereo.
    1. I have problem with CanBus - the steering wheel control work but other function like ac, control amplifier etc don’t. Maybe someone have this radio and know how to connect all?
    2. I have noise in speakers when just start Android and don’t know if it is normal?
    3. Mic is very queit even when I connected external one
    maybe someone can help?
  2. dolj
    dolj Senior Member
    7,648
    3,858
    Wellington, New Zealand
    1. It sounds like your CAN-BUS cable likely does not have the 68Ω resistor which is required to correctly terminate the CAN-BUS. If you search this site for 68 Ohm resistor you will likely pull up at least one thread with the details of what you need to do.
    I don't have any information in regard to your other questions.
  3. Michciu94
    44
    Poland
    I put resistor and original AC control works but i cant connect CanBus to Andorid Head unit. Steering wheel controls works but I cant control amplifier by Head unit or maybe Prius 2 cant do that ?
