Cancer on steering wheel
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Aug 24, 2019.
  1. evpv
    evpv Active Member
    690
    338
    West Coast
    2019 Prius Prime
    If sunscreen and lotion were the cause I think we would see examples of blistering on the sides and bottom of the steering wheels. All of the blistering I've seen is in areas of maximum sun exposure.
    mistermojorizin likes this.
  2. evpv
    evpv Active Member
    690
    338
    West Coast
    2019 Prius Prime
    Here's a thread on the 2016+ Liftback forum discussing this problem.
    I've see a few cases of wear on the sides and lower section, but they look more like wear from friction than blistering.
    I've seen enough used & worn steering wheels over the years to make me wonder how people do what they do...
    Steering Wheel peeling | PriusChat
    Marine Ray likes this.
  3. Marine Ray
    Marine Ray Senior Member
    1,139
    945
    Sparks, NV
    Dealer today cleaned off with rag and some cleaner. We'll see if that does the trick. Hope it's that simple.
  4. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    Another steering wheel cover with abnormal wear. This is in the 6 o'clock position and really not exposed to much wear. Has anyone had this replaced under warranty? I'm less than 3 years and only 26,000 miles.
    This car is garage and never sits in the sun. I rarely use the heated feature on the wheel.
    sonomac likes this.
  5. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    :whistle::whistle:
    I have the same on my 2016 softex steering wheel wrap. 10 o’clock position. But this is very minor. Not like a cracked windshield or clunking suspension (my 2 warranty claims).
    Interesting comment about sunscreen. I often apply sunscreen with my left hand while driving, and then hold the steering wheel at 10 o’clock, where it’s peeling :whistle:
  6. sonomac
    sonomac Junior Member
    25
    US
  7. ems2158
    221
    162
    Bucks County, PA
    Better start looking on Amazon for some kind of wheel cover. The wear on my steering wheel was less but warranty claim was denied, "Wear caused by jewelry, my fault."
    Thing is I don't wear jewelry and the worn spot was at 6 o'clock. Apparently caused by rubbing the bottom of the wheel while sliding in.
    Softex is clearly inferior to real leather in high wear areas. Leather has been used for thousands of years and is a proven material. Is Toyota worried about a PETA protest?
    sonomac and Marine Ray like this.
  8. sonomac
    25
    US
    My 2017 Prime is the premium model w/ no heated steering wheel and it started peeling @ 26000 mi. Very slight at first and just as my warranty expired it went crazy. 20191031_100914.jpg
  9. Salamander_King
    Salamander_King Senior Member
    11,010
    8,940
    New England
    WOW, that look terrible! My Premium has just passed warranty miles of 36K, but so far no sign of peeling. I wonder if this is Softex material problem? I have not read anything similar happening to Softex material used on the seats yet. It must be specific to the wheel.
  10. Marine Ray
    1,139
    945
    Sparks, NV
    If out of warranty I'd either live with it or get a good steering wheel cover. P.S. - at same time monitor if somewhere down the road this becomes a recall issued by Toyota. P.S.S. - still show your Toyota dealership even if out of warranty.
  11. priusdonkey
    priusdonkey Member
    211
    51
    Los Angeles, California
    My 2016 Prius lost the cheap vinyl on the steering wheel at around 38,000 miles. I had an extended 100,000 mile warranty and Toyota would not fix it. They said it was normal wear and tear. I tried to get the dealer to fix it under goodwill and Toyota Refused. Last time I buy a Toyota.
    Now the car battery is dead and it’s the second Toyota battery. The dealer says without a receipt it can’t be replaced under the two year manufacturer warranty. So I’m switching brands. Again Toyota got away without replacing the part. Incidentally the steering wheel is very expensive if you have a higher end model. My Prius now has 193,000 miles
  12. evpv
    evpv Active Member
    690
    338
    West Coast
    2019 Prius Prime
    I always laugh a little... "The Prius is an engineering marvel, but my 12V battery died and the dealer won't replace it without a reciept, so I'm never going to buy a Toyota again."
    On the steering wheel I'd try cutting off the Softex cover and seeing if there is a nice textured rubber wheel underneath (see photo of what it probably looks like). If not, just buy an aftermarket cover for the wheel, or get it recovered in real leather, or find a used one on eBay, or buy a new one. Lots of options that are less extreme than never buying another Toyota.
    16-17_Toyota_Prius_G4_Steering_Wheel_w__Switch_Button_Assembly_Black_A33_OEM___eBay.jpg
    #52 evpv, Nov 3, 2019
  13. ems2158
    221
    162
    Bucks County, PA
    I tried to cut the Softex cover off the steering wheel. That was a complete fail. The Softex covers a thin foam wrap that is glued to a thin shiny plastic rim with no texture. Also, the are a few 1/8" notches molded into the plastic that extend to the interior aluminum rim. What you are left with after the Softex and foam padding is removed is a unusable mess.
    evpv likes this.
  14. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    I suspect there may be a disconnect between people who've owned Toyotas since the 1990's or 2000's and people whose first Toyota is more recent. I suspect people who have owned Toyotas in the past are more likely to be appalled by the lower quality and service that Toyota of today has compared to years past. People who have driven other cars may be used to driving a collection of annoying minor defects, but long-time Toyota owners aren't used to it.
    I suspect Toyota has learned the old adage that you don't have to be great, just better. If all the other cars break down every 10,000 miles, you're not maximizing profits making a car that breaks down every 200,000 miles. Instead, you just need to make a car that breaks down every 15,000 miles. Likewise, if the other brands average 20 minor defects and customer complaints, Toyota only has to average 15 or less. In days past they would aim much higher.
  15. evpv
    evpv Active Member
    690
    338
    West Coast
    2019 Prius Prime
    Option 2....
  16. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    is there a good cleaner or something to maintain the steering wheel?
  17. LoganNolag
    LoganNolag Member
    47
    25
    Atlanta
    Any pictures?
  18. JosephG
    JosephG Active Member
    115
    102
    2018 Prius
    Write to Consumer Reports? They got Honda to fix the Civic battery didn't they? This is the kind of issue they exist to investigate and expose.
  19. PiPLosAngeles
    1,551
    724
    That doesn't have the controls for the dynamic cruise control and lane assist.
  20. LoganNolag
    LoganNolag Member
    47
    25
    Atlanta
    I wonder if it's possible to transfer them from the old steering wheel.
