Cannot dial phone after adding a second sim to phone
Discussion in 'Prime Main Forum (2017-2022)' started by jgspears, Aug 28, 2018.
  1. jgspears
    jgspears Junior Member
    30
    Conover, NC
    After adding a second sim to my phone, I can not longer make calls using entune. I have my primary sim as default for calling and date but entune responds with a error when I try to make a call. Guess I just need to dial with Android auto and forget using entune. I will eventually go back to a single sim but my phone supports two and one would expect entune to as well especially when all defaults point to a single sim. Any suggestions?
  2. FuelMiser
    FuelMiser Senior Member
    1,270
    861
    Monument, CO
    I don't have any idea if this would work, but what I'd do is delete any saved Bluetooth connections from the phone and the car, power down the phone and then start over with a fresh BT pairing. It's like doing CTRL-ATL-DEL in the old days.
  3. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    I have a cell phone. I installed Google Voice which has its own phone number. So in essence I have one phone with two numbers on it. When I make a call I have to choose which number to use to dial out. As a result I am unable to make an outbound call using my car. Is this was you are describing as 'two sims"'?
  4. jgspears
    30
    Conover, NC
    Thanks FuelMiser. Repairing did the trick. I should have tried that.
