Cannot figure out what is wrong....electrical issue...
Discussion in 'Gen 2 Prius Main Forum' started by NickBaker9, Sep 11, 2012.
  1. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    As previous posters have indicated, the reported symptoms clearly
    point to a new 12V battery.
    That said, there is no guarantee that even a brand new 12V battery,
    directly from a InterWeb source or a Toyota dealer is ready to be put
    in the car. OP would be wise to ensure that the battery is fully charged
    before it is installed.
    If this is beyond the OP,s technical abilities, it would be wise to take the
    batteryto a independant battery shop and have them do it. Typically the
    battery will be tested and charged on a machine that can print out a
    condition report. Be sure to get a copy for your records.
    The OP could post the report so that the e-smart folks here could then
    comment on the battery's liklihood of providing a long trouble-free life.
    (Typically 4-5 years if the battery is never deeply depleted at any time
    requiring a jump start or otherwise abused.)
    It should be noted that all batteries suffer a reduced service life in an
    environment of repeated hot-soaking; lets say being parked daily in an
    uncovered parking lot through the mid-day sun. While the LA area
    is not generally known to be particularly hard on batteries, the OP's
    particular useage pattern could set up a special case where reduced
    battery life/capacity is likely to occur.
  2. John H
    John H Senior Member
    2,208
    558
  3. NickBaker9
    NickBaker9 Junior Member
    42
    Los Angeles, California
    John, thank you so much for that. Bernie, the guy that owns that website, lives relativly close to me. I'll be picking up my new Optima battery today and will install soon. He said he keeps them fully topped off and that charge lasts for over a year, but I'll install it in the next day or two. I will come back and tell you all how I did with the install. From what I'm understanding the install of the battery is a chore but not that difficult. Take out the battery vent, use a socket wrench, follow the instructions on the eLearnAid website, and I'll be golden. Please let me know if I'm in for something over the top, but I do know how to turn a wrench...I used to build sets in college. Believe it or not, actors are not useless...well, some of us anyway...lol
  4. John H
    2,208
    558
    It's about 15 minutes if you don't hassle with trying to keep the 12V system alive while swapping. I don't know what kind of setup Bernie has at his place but you might be able to just do the swap at his place and leave him your old battery to recycle.
    Maybe he can video you doing the swap and put it up on his website... "Hey, even a Hollywood actor can swap a Prius battery with our instructions!"
    cwerdna likes this.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Stop fooling around. This is a bad battery, plain and simple.
    Tom
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Be be sure to follow the order in the directions exactly and be careful about any metal unexpectedly touching. I covered the handles of my wrenches w/non-conductive tape, just in case.
    You don't want to accidentally short either the old or new battery's positive terminal against the frame of the car w/your wrench. And definitely DO NOT get the polarity wrong. See Recharging after Dead 12v Battery | PriusChat (search for spark) and Just shorted 12v battery, advice? | PriusChat for some tips.
    (Disclaimer: I'm no EE, so I can't speak to the accuracy of the tips at those threads.)
  7. John H
    2,208
    558
    I always disconnect the negative terminal first, put the plastic cap on it, and that way you don't get any shorts while you are disconnecting the positive terminal or anything else.
  8. R-P
    R-P Active Member
    804
    288
    Netherlands
    10.6V is way too low in my view. Hell, even 12.2 is too low.
    From here (many sites have similar data, this is the first I found):
    And as for the 5 hours: I set my timer and camped out in my shorts near the car from 4:50 to 5:15 hours after leaving the car, but no sounds...
    I did hear rattling today 5 minutes after shutting down, possibly the same rattling I hear whenever driving it for 2 minutes, but then I hear it from the inside (like a noisy electric motor running)
    This is why you always disconnect the ground-wire first*. That way the minus-pole of the battery is no longer connected to the chassis, therefor undoing the plus-pole is suddenly no longer a life-threatening excersize...:cool: I didn't get it the first time I read this advice, and I AM an EE...:whistle: But after thinking about it, it makes sense, doesn't it? So spread the word, this saves lives.
    *and obviousle reconnect last.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Or just unplug the pos heavy duty wire connector on the Prius. Just click it and pull it out.
    But any other car unbolt the neg first.
  10. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    This is a comparison of apples to oranges. The voltage chart you quoted is for open circuit voltage as in measured without a load on the battery except for the minuscule load from a high impedance volt meter.
    Comparing that with the loaded test voltage of 10.6 means nothing.
    Could you please share proof of how deadly 12V batteries are? I was under the impression 12V was not likely to kill anyone.
  11. John H
    2,208
    558
    Perhaps he was refering to the life of the battery :) they have a mind of their own after all.
  12. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Yeah but thats what I want to see. If its measuring 10.76 without a load you can bet it will be very very low with a load.
    Either way 10.6 is done loaded or unloaded.
  13. Avi's Advanced Automotive
    776
    363
    Apples:
    Oranges:
  14. John H
    2,208
    558
    It's been a few days since we have heard from Nick. I hope he didn't confuse the HV battery with the 12V.
  15. Avi's Advanced Automotive
    776
    363
    As long as he doesn't start a third thread. This one has already turned into a circus.
    cwerdna likes this.
  16. John H
    2,208
    558
    Well, there are a lot of clowns running around, what would you expect :)
  17. R-P
    R-P Active Member
    804
    288
    Netherlands
    The OP wrote: "The battery reading with no components on was 12.2v." which I read as the unloaded battery was 12.2V. That's why I quoted the numbers. It was not my intention to compare the 10.6V measurement with it.
    Reading it back, I find it highly unlikely that he has a voltmeter on the battery, so he probably used the MFD to do the readout, which I wouldn't call 'no components on' but that's semantics.
    BTW: my numbers are:
    12.0V in accessory mode on the MFD.
    11.6V in 'ready'
    14.2 when the inverter kicks in
    All with this 'not so new' battery (post 38)
    It was a hyperbolism. I cannot (nor do I WANT to) find proof carbatteries ever killed anyone, but they are very dangerous and should be treated with the utmost respect. They can melt a thin screwdriver and fling glowing particles of metal in the direction of your body or even eyes.
    A famous urban myth is that a mechanic was working in a submarine and touched the hull with his wrench while tightning a bolt on the + of a battery bank. The wrench melted and pretty much disappeared... (Sub batteries are 'slightly' larger than carbatteries, but you simply shouldn't short either of them...).
    edthefox5 likes this.
  18. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Couldn't agree more R-P. A car battery is a very dangerous thing. Car batteries explode all the time and not only do you have plastic shards flying you have the added fun of electrolyte.
    Hard to believe a mechanic say otherwise.
  19. John H
    2,208
    558
    Any references available for "casualties due to 12V batteries"?
  20. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Serious? Google it. There are hundreds. How about You Tubes? I have personal anecdotes I won't bore you with.
    Only car forum on the planet where people argure about battery safety.
    Oh alright.....
    car battery explosions - Google Search
