Cannot find answer - 2 questions
Discussion in 'Gen 3 Prius Fuel Economy' started by mosezgo, Apr 10, 2011.
  1. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I think he's being sarcastic.
    Yes, please answer the questions. We can at least tell you to check this or that, don't do this or that or that your mileage is normal for your commute.
    Fuzzy1 is absolutely correct. There is no promise that you will get EPA estimated mileage. Since your expectation seems completely based upon EPA estimates, please read http://priuschat.com/forums/other-c...uth-about-epa-city-highway-mpg-estimates.html and compare their procedure to your driving. Even the EPA says http://www.fueleconomy.gov/feg/why_differ.shtml.
    FWIW, CR got Most fuel-efficient cars.
    Since you mention late Feb, although you seem to have warmer weather now, you did have bouts of colder weather per History : Weather Underground and fairly low lower bound temps. Please see http://priuschat.com/forums/gen-iii...ileage-in-mid-west-winters-2.html#post1216266 about why mileage drops in cold temps.
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The MID is ~7% optimistic. Inflate the tires, block the grill, & cut your speed. If I only got 50mpg I'd be pissed. I'm disappointed I haven't seen 60mpg.
  3. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Agreed about the above but re: blocking the grille, I'd only do it in colder weather.
    If the OP is in Tulsa, OK, then I'd strongly advise against grille blocking given the weather conditions and forecasts I see at Tulsa Weather Forecast and Conditions and 10 Day Weather Forecast for Tulsa, OK (74103) - weather.com. It's currently 78 F and the projected high temps for the next 10 days are almost all above 70 F and in two cases, above 80 F.
  4. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    My Prius displayed mpg is pretty consistently 2mpg optimistic compared to calculated mpg.
  5. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
  6. krelborne
    krelborne New Member
    295
    Alabama
  7. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    While I do recommend inflating the tires to 38/40 PSI and know that cold weather driving can reduce MPG by 5-10%, overall just drive the bloody thing.
    If you cannot deal with the subtleties of the Prius and are still unhappy in 6-8 months, then trade it for a different brand. No blame - just leave the aggravation behind.
  8. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
