Cannot play audio / music via usb
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jas5, Dec 23, 2018.
  1. Jas5
    Jas5 Junior Member
    CA
    2014 Prius Plug-in
    Hello,
    I plugged in my iphone via usb to the usb port under arm rest
    Wanted to use the prius speaker when using google maps navigation or play music on my phone
    The audio just doesnt play
    Am i missing some setting
    Thanks
    52,849
    does a stick work?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Try making the connection with BlueTooth instead.
  4. Jas5
    Jas5 Junior Member
    CA
    2014 Prius Plug-in
    Bluetooth works, was not impressed with the stock stickers on 2014 PIP Base when playing at higher volume
    I feel playing audio over usb connection might sound better
    Is it possible ?
  5. SlidingBike
    SlidingBike Active Member
    171
    113
    Fremont, CA
    Was it working before and stopped suddenly OR you are trying to connect for the first time?
    I used to use USB stick with songs connected there but changed to connect it with my iphone to play the itunes playlists etc.
  6. Jas5
    Jas5 Junior Member
    CA
    2014 Prius Plug-in
    First time
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    I'm thinking that it might depend on your phone......and am guessing that it might not accept an audio input via USB but would "find" the music library on the phone IF the phone allows it.
    It seems like I remember that mine would "find" music stored on a memory card on the phone but couldn't see any stored in the main memory.
  8. SlidingBike
    171
    113
    Fremont, CA
    This can be easily tested.
    1. Connect a USB flash drive with songs in it and check if those can be played on the Head Unit(using USB source selection)
    2. Connect an iphone with songs on its itunes/apple music, select "iPod" option on the head unit.
    if either works, PiP's USB connector is healthy. If both are not working, try to charge a phone using USB connector. If charges, USB is partially working(only power channel), if not working you must say RIP for your USB in car.
  9. mrlebop
    mrlebop Member
    136
    68
    My USB stick no longer works in my PiP. Went to a 16 GB stick and it worked for a few songs, then went wonky. Now it doesn't read it at all. The files show up on the home computer and play just fine. The USB feature worked fine when I used an 8 GB USB stick. I wonder is this means I need to upgrade to the latest head unit software version.
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    Your new "stick" may not be formatted correctly for the car to use.
    Try your old 8 G again to see if there is a problem in the head unit.
    mrlebop likes this.
