Can't access vehicle settings
Discussion in 'Gen 3 Prius Technical Discussion' started by Jarrod m, Jan 27, 2019.
  1. Jarrod m
    Jarrod m Junior Member
    kingsport, tennessee
    When I first bought my standard 2011 Prius US used the touch screen didn't work and they replaced the GPS stereo CD changer assembly. When I try to access vehicle settings the only option is a maintenance log. Is there perhaps a cable that goes between the entertainment system and the ecu that wasn't plugged in? Please let me know.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    You need techstream installed on a pc device connected the car obd port. You can access vehicle settings that way.
    SFO and Raytheeagle like this.
    52,878
    what settings are you looking for?
  4. Jarrod m
    Settings like automatically locking the doors when putting the vehicle in drive, dimming dash lights with headlights turned off, turning off the piezo chirper
  5. bisco
    52,878
    you don't access through the touch screen
    Raytheeagle likes this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Those are either done with Techstream or the Carista app;).
    Good luck and keep us posted (y).
    SFO and Grit like this.
  7. Joele3
    Joele3 Active Member
    138
    206
    Bay Area
    On my 2014 Prius V I was surprised to see some vehicle settings through the touch screen. But no reverse or seat belt beep option to turn off. Just one click to unlock all doors. How long to leave the lights on after car off.
  8. WolfpackBill
    WolfpackBill Senior Member
    349
    501
    Lexington, NC
    That became available in 2012 facelift so Techstream or Carista are the only sources to use to change settings.
    Grit likes this.
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    You’re better off with techstream, Carissa is only limited time paid service.
