Can't beleive I actually bought a Prius!!
Discussion in 'Gen 2 Prius Main Forum' started by Zafoe65, Jul 31, 2005.
  1. Zafoe65
    Zafoe65 New Member
    Hello all! I am new to your board and found it thru Google. My post is simple ... I just want to tell everyone about my new Prius!
    I have always loved trucks. And until yesterday drove a pretty nice Tundra with every available option. But when I realized that I was spending over $100 a week on gas, I knew it was time for a change.
    So yesterday I traded my truck in for a 2005 Prius. I can't beleive it. ME? A Prius!?!? This is gonna be hard to explain to my freinds who haven't seen my in anything but a truck or SUV for as long as they have known me.
    So far I am happy with it! I got a metalic blue with beige interior. I am still "hypnotized" by the computer display, and I do have a few questions now that I have driven around a little.
    It seems like the engine is "always" on. I had heard that it would turn off and on a bit. When I accelerate the display shows engine AND electric, but never just electric. Also, I "feel" the engine when I accelerate, like any normal 4cyl. Is this normal? Of note is that the battery, to the best of my knowledge, has never been 100 charged. So far it has only gone to about 3/4.
    Anyway, I feel like i have gone from envrionmental assasin to environmental allie.
    -ZAF
  2. Tideland Prius
    16,076
    Hey Zaf and welcome to PriusChat! Congratulations on your purchase!
    The battery will never be "full" cause the computer won't let it. Seeing 8 bars is actually 80% of the true SOC. 1 bar is about 40% and the 6 bars you see is ~60% true SOC.
  3. kirbinster
    kirbinster Member
    602
    Morris County - New Jersey
    You are going to have to go through a learning curve on how to drive the car. If you tromp on the accelerator like it the truck you will never see just battery. From a standstill if you very very very gently depress the accelerator on flat ground you can get up to 42 mph before the gas engine kicks in once the car is warmed up.
    You also need to work on the featering technique. Once you get up to speed take your foot off the gas for a second and then slowly press down to the point you need to just to maintain your speed. This will have you getting much better mileage. Try to drive the terrain also, gather speed going down hills and let yourself coast up the hill where possible. With a little practice you should be able to consistantly get high 40's or low 50' mpg.
  4. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    ZAF,
    Congrat on your purchase!
    It's ok, new Prius drives always do that. But keep your eyes on the road! :D
    When the car isn't warm up yet (first 5 to 10 min of driving), the gas engine will likely to turn on when you press on the pedal.
    If you use kirbinster's technique, and search around this forum, you'll learn how to drive the car better. Well, enjoy your Prius!
    Scott
  5. Fredatgolf
    Fredatgolf New Member
    339
    Pinehurst
    Most of us use the kirbinster technique at least a little. When I drive, I spend a lot of time on the energy screen that shows the battery. I feather a lot to keep the green arrow going into the battery because I find that in the long run, the better the battery charge is the better the mpg. This way, you won't change your speed that much. Once you obtain the desired speed it is relatively easy to keep the green arrows going into the battery.
  6. victor
    victor New Member
    414
    Gilching Bavaria Germany, & Drapanos, Crete, G
    I dont use this method because:
    1. It distracts from the road
    2. The display is only updated every 3 seconds so is not reliable
    3. The energy screen lies!
    The best place to monotor if the ICU is running is the consumption screen which updates far more often, a couple of time a second. When the ICU is "off" no fuel is being used.
    When I say the Energy screen lies have you ever noticed [you], being stopped, and the Energy screen says the motor is stopped, but you can hear the motor running? I get this a lot, and it will run for well over a minute, but go to the consumption screen and the fuel useage will still be at 99.9ltr/100Km!
  7. evander
    evander Junior Member
    26
    Ill
    Hey, what do you mean "evander" being stopped? Our immortal guinea pig has never left his cage except for Prius trips to the vet. : :roll:
  8. kirbinster
    kirbinster Member
    602
    I keep mine on the bar graph screen most of the time, and whenever the current reading goes below 50mpg I think to myself is there anything I can do differently to get it to be higher. Obviously when going up a hill or accelerating there is not much, but on flat ground this helps me acheive maximum mileage.
    I never try to run on just electric unless I know that I will be approaching a down hill shortly or it is the last mile or so before I park. Remember almost all electric energy comes from gasoline - either directly charging the battery or recovering energy provided from gas when you apply the brakes. The best way to maximize fuel usage is to think and not to over drive the conditions so that you minimize the use of the brakes.
  9. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    The ICE will run a lot more than the Toyota advertising might lead one to expect. The ICE is more efficient than using the electric motor under most conditions, particularly during anything heavier than very light acceleration. Don't sweat it, the car knows what it's doing.
    As you get used to the vehicle you'll learn how to feather the pedal and force the ICE off and to stay under electric power when it is most efficient to do so.
    You're in Stage 1 of your Prius driving experience...fascination. Soon you'll be in Stage 2 and switch to the consumption screen so you can see what your mpg is doing over time as you start working to improve mileage.
    After that is Stage 3 and you're going to be back on the Energy screen really trying to eek every drop of mileage possible out of your gas.
    Stage 4 is true Prius Nirvana where you drive with the screen off or pay no attention to it what so ever b/c you know what's going on...I haven't gotten there yet in almost 2 years of ownership...I suspect many never do get there.
    BTW, you're far from the first to make the radical transition. I drove a '97 Ford Expedition for 6 years before getting my Prius. When I live in Alaska it was necessary equipment that I eventually convinced myself was always going to be necessary...it's hard to even consider a smaller car after enjoying the roominess and road presence of a big truck.
    But I've never been happier than with my Prius and the first year fuel savings over my Expedition came to about $1800...second year will be well in excess of $2000.
  10. Kablooie
    Kablooie Member
    273
    La Canada
    The thing that gets annoying though, is how high your electric bill is after plugging in the car all night. :violin:
    And yeah, I notice the engine seems to run sometimes even though the monitor says it's not on. I'm assuming it has to do with the air conditioner running. I've only noticed it recently when the weather is unusually hot.
  11. efusco
    19,891
    1,191
    Nixa, MO
    Re: Can't believe I actually bought a Prius!!
    :tomato: :iagree :rofl:
  12. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Victor, did you just inadvertantly invoke the (YOU) command?
    For those playing at home, typing the word "you" eclosed in brackets "[ ]" is a programming code that replaces the (YOU) with the name of the person reading the post. Look to the left of the screen and you will see your own avator and your own screen name. It's no challenge for the server to take your username and plug it in. Sometimes, this is done with humorous results. In this case, however, I think Victor did it accidently.
    ZAF: Congratulations on your Prius. Keep in mind that your car is still relatively new. The engine will run a bit more and will need to settle in. Additionally, there is a world of difference between driving trucks and SUVs and driving a Prius. This means that you will need to settle in with the car.
    As Evan said, there really are distinctive stages to driving a Prius. Stick with us, comb through the boards, and learn all that you can.
    In my opinion, the best thing you can do is go to the Archive section of Priuschat, start reading the oldest post and work your way to the newest. It's not that the posts are all old. Rather, it's the same as the regular side of the board but without pictures. This means that you can get right to the meat of the posts and if the post is picture relient, there's a link to view the pictures. Start there and you will be amazed at how quickly you come up to speed.
  13. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    Congrats. I am also a convert from trucks. I drove a F150 and an F250 King Ranch. It took me a bit to get used to being lower and having less storage space but I love it. I went from $120 monthly fill ups to about $28.
  14. evander
    26
    Ill
    I agree as well. And what's really frustrating is blowing fuses in the house with Prius plugged in as well as AC energy full blast in our stifling weather. :cussing:
  15. Kurt
    Kurt New Member
    Check to be sure your temperature control is all the way to "Max Cold". If you have it set at anything but that the ICE will continue to run until it can heat the water up enought to put out the temperature set, i.e. the higher the temperature set the longer the ICE will run.
    A friend of mine bought a new Prius and hers was set at 78. She also could not figure out why her engine ran for such long periods of time.
    I went through her car with her step by step. She was amazed by what the car had to offer...2 extra storage compartments that she didn't know about (yes the one in the center dash and the one below the arm rests) and she didn't even know about the smart key system. YIKES!
  16. Rick58
    Rick58 Junior Member
    Took me a little while to figure out the temperature setting as well - I was wondering why the A/C wasn't cooling (had temp set to 78 ...).
    I also went from a '99 Explorer to the Prius as a commute car ... but still have the Explod - uh, Explorer for hauling more stuff, camping, etc..
    Nice to get ~50mpg instead of 18! and the Prius will certainly hold up better!
  17. dipper
    dipper Senior Member
    1,242
    252
    Traded in my LX470 for Prius. My wife refused to drive the LX470. From 13-14mpg (premium gas) to 50 mpg.
  18. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Uh, no, not in the summer. If it was 40 or less degrees outside, then maybe.
