Cant decide
Discussion in 'Gen 2 Prius Accessories & Modifications' started by h2photo, Jun 22, 2007.
  1. pingman
    pingman New Member
    124
    <div class='quotetop'>QUOTE(pingman @ Jun 23 2007, 04:05 PM) [snapback]466968[/snapback]</div>
    im just using that one inch raised line on the see through plastic door as a judge to the HSD badge to me the badge looks like it is a 1/4 inch to the right
  2. pingman
    pingman New Member
    124
  3. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    How do you take them off?!
    acetone?
  4. h2photo
    h2photo Member
    432
    Chandler, AZ
    <div class='quotetop'>QUOTE(Slair @ Jun 24 2007, 05:53 PM) [snapback]467415[/snapback]</div>
    nope, just grab a hair dryer, heat them up till they are just hot enough (i suggest to wear gloves, they are HOT) & then I pulled them off, to loosen one side i used a mini screwdriver covered in a t-shirt piece(so not to scratch) & had some floss out there just in case the tape wasn't coming off that easily. They should just pull right off if you have them heated up enough. Simple thing took 5 minutes each
  5. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
