Can't find a replacement 12v battery for my Prius.
Discussion in 'Generation 1 Prius Discussion' started by Jesse Elledge, Sep 13, 2018.
Tags:
  1. dabard051
    dabard051 Tinkerer-in-Charge
    258
    97
    Rochester, NY USA
    2002 Prius
    Replacing the Gen I 12v battery: you have a couple of choices
    This assumes you are ok with replacing (if necessary) the OEM battery connectors with standard connectors
    (connectors [12 inch negative clampw/wire and a marine type clamp with thumbscrew for positive]
    both available at AutoZone, Advance Auto, OReilley, NAPA...)
    --battery type 51R (450-550 CCA) fits fairly well, but the OEM mechanical clamps (to hold it in place) won't fit
    (I used a couple of pieces of wood to wedge it into place and hold it steady)
    --battery type 151R (maxx Everstart from Walmart, 340CCA) fits a bit better, but is a bit pricier.
    Either battery should be available for $120 or less, depending on the retail outlet.
