Can't find silicone wipers for 2018 Prius...
Discussion in 'Gen 4 Prius Accessories and Modifications' started by GRF819, Mar 1, 2020.
  1. GRF819
    GRF819 Junior Member
    Los Angeles
    I have yet to find silicone replacement blades for my 2018 Prius - any one have any suggestions?
    Thanks!!
  2. The Professor
    The Professor Senior Member
    567
    762
    UK
    Excel
  3. GRF819
    Los Angeles
    According to their site, "Not available"!!
  4. GRF819
    Los Angeles
    I'm still looking - PIAA is sold out of driver's side. 2018 Prius' seem to be almost impossible to get silicone blades from any brand - WTH is going on here - is this model and Albatross???
  5. The Professor
    567
    762
    UK
    Excel
    I didn't buy mine from PIAA directly. I bought them from an authorised stockist (UK here though). They still have them in stock, so there can't be that much of a shortage.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,764
    47
    South Yorkshire, UK
    Dealer just replaced mine FOC at the service when I told them the drivers one was wobbling at the bottom end and had been since new.
    jerrymildred and krmcg like this.
  7. MrBugMan
    MrBugMan Junior Member
    Earth
    2018 Prius Prime
    Hi!
    I've read the other thread and did not see a link to the wiper blades. I could be wrong, but this forum doesn't allow hyperlinks. Do you happen to know the part numbers so I can Google it? Whenever I do a search on PIAA's site it results in zero matches for "Prius Prime Silicone Wiper Blades". Actually the only search results for "toyota" are parts/accessories for trucks.
    EDIT: Alright, I did a search on PowerBulbs site and found 28"/16" silicone blades and will contact them to make sure the "F" adaptors come with.
    #7 MrBugMan, May 2, 2020
  8. The Professor
    567
    762
    UK
    Excel
    Yeah sorry it was post #11 not #10. If I recall correctly, all wiper kits are meant to come with all adaptors. PIAA (directly) said there was a manufacturing issue and some kits went out without the F adaptors, but they should all have them now.
    MrBugMan likes this.
  9. jerrymildred
    jerrymildred Senior Member
    10,981
    13,394
    Tampa, FL
    My factory originals are still working fine. If and when they get bad, I want another set just like these. ;)
    Mendel Leisk, krmcg and kithmo like this.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,764
    47
    South Yorkshire, UK
    Mine were wiping ok, just the longer one was wobbling at the bottom end and the new one still wobbles slightly. I think it's the design, they're not rigid enough and I'll probably go for a sturdier aftermarket brand when I need replacements.
    jerrymildred likes this.
  11. The Professor
    567
    762
    UK
    Excel
    My front wipers were maybe 2 years old when I replaced them. They probably didn't need it, but my motivation was to help maintain the Rain X (a silicone based rain repellent), as silicone wipers do build up a slight coating over a very long time that helps the rain run off. The OEM wipers were squeaking a bit due to the Rain X too, which was getting annoying.
    I have just replaced my rear wiper at 2.5 years old, as the rubber was beginning to disintegrate - it had split about 2" along its length from both ends. That may have happened due to being stuck to the window that was iced over. It's bewildering why Toyota didn't extend the rear window heating element up enough to cover the full height of the window and wiper, but whatever, it is what it is.
    I just got a Bosch H409 rear wiper, which seems identical to the OEM wiper in everything but name.
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,784
    Undisclosed Location
    That's been my challenge with "beam" style wiper blades. They're just not rigid enough to not wobble. Which is too bad because in all other respects I believe they are the better design.
    I eventually had to step down to the "conventional" style blades, with the metal holders, just to get the rigidity needed to make a full wipe cycle without wobbling/chattering.
    kithmo likes this.
  13. GRF819
    Los Angeles
    Got the wipers from PIAA in the states. NOTE: the 16" blade did not come with correct adapter, but PIAA was kind to send one promptly - great company and product!!!
  14. MrBugMan
    Earth
    2018 Prius Prime
    I'm a little concerned they will not have the "F" adaptors because of this note/warning on their silicone wipers...
    "(NOTE: The PIAA Si-Tech Wiper Blade comes with two wiper arm adapters to ensure compatibility with a wide range of vehicles’ wiper attachment methods. Detailed instructions are provided – simply select the appropriate adapter and attach as demonstrated.)"
    Notice it only says "TWO" wiper arm adaptors.
    Has anyone had long term experience with these wipers? I have read/heard silicon wipers last some users 10 yrs before being replaced.
    #14 MrBugMan, May 3, 2020
  15. The Professor
    567
    762
    UK
    Excel
    I would contact them and ask. Certainly when I bought mine a while back both wipers came with a bag full of maybe 5 or 6 adaptors.
  16. Cshigeok
    Cshigeok Junior Member
    Hawaii
    are these the same ones as the ones on the 2016 Prius?
  17. DevilDogDoc
    DevilDogDoc Member
    31
    28
    SoCal desert
    Three Touring
  18. andrewpable
    andrewpable Junior Member
    24
    Naperville, il
    My piaa have been working great for years now. If the adaptors don't come just contact piaa and they will send you them. I have a silblade for rear wiper and it's also been good. Only complaint is that the piaa adaptors aren't the most sturdy mount so they wiggle a little on occasion, it's not my favorite but I've never had a malfunction either and they wipe beautifully, the stock rubber just is awful in comparison.
  19. Mambo Dave
    Mambo Dave Active Member
    543
    268
    2019 Prius
    L Eco
    My OEM wipers lasted perhaps a few months over 1 year. The Florida heat and sun must have did a number on them. I keep my wiper surfaces clean (more so than any other driver I've met), but they got to the point that them being clean, alone, wasn't helping anything.
    Of course I wanted to go with the best reviewed wipers by ProjectFarm, but it seems that those wiper companies don't make wipers compatible with Gen4 Priuses. So I went with this:
    "AERO Avenger 28"+16" Premium All-Season Beam Windshield Wiper Blades OEM Replacement for Toyota Prius 2020-2017 (Set of 2)"
    Thus far I've been happy with them, but we aren't in the monsoon season right now. Nonetheless, it's nice to have a very clean windshield to look through again.
  20. andrewpable
    24
    Naperville, il
    Honestly surprised yours lasted so long I feel like mine started becoming bad before that and I'm in illinois. Those look interesting, I have my doubts on rubber longevity though. After switching to silicone I honestly don't know if I'll ever go back, and at the rate they continue to perform I might never need new ones either.
    Mambo Dave likes this.
Loading...
