Can't fix this electrical issue.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Aug 15, 2022.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    3 replacement modules ordered, plus new bus bars.
    Going to have about $300 in this when all said and done, but still a far cry from $1400 for a replacement.
  2. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    Holy crap, glad you're still with us.
    edthefox5 likes this.
  3. Prius92
    595
    122
    Iowa
    Voltage is halved with the safety plug removed. Pack was around 220v DC..so around 110V DC with the plug out.
    I didn't really get shocked, the ratchet took the brunt of the load, it's the arc heat that got my finger.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    If you shorted two adjacent bus bars together, then "all" you had were two charged modules (around 16V), that could put out a couple hundred amps for a short amount of time. Still a lot of power, enough to run a typical ICE starter motor.
    I would be surprised that the loose connections at the contactors didn't "burn" them or otherwise cause damage.
  5. mr_guy_mann
    4,113
    2,011
    NJ-USA
    "Why can't my two code scanner apps as well as my Creader handheld scanner see these U and C series codes?"
    Because none of them are capable of "talking" the the ecu's that have the codes. A Gen2 Prius has 15-16 ecu's. DrPrius and Car Scanner can read codes from the ECM, hybrid control, and (some from the) HV battery ecu's. IDK what model of Creader you have- the more basic ones can only connect to the ECM.
    This is the exact reason I made an app review thread (stickied) at the top of the Technical Discussion forum.
  6. tracy ing
    tracy ing Active Member
    384
    173
    wash dc
    Engineering begins at power, and power requires grounds.
    I have been certified in over 30 electronic systems in my life, and all the classes started with that.
    You need to get the HV battery in it and forget if its right or not, and go find the problem with the car.
    From what I have read, you have a loose corroded connector, fuse, fuse block, wire, or rodent damage.
    I would get the car running and care less about the HV, and start pulling and pushing on wires and connectors, for a start, while the ice is running, you have way too many problems and they all seem to be tied to loss of communication and rebooting (for lack of a better term).
    Dont ignore the condition of those underhood fuses, road salt took one out on this 2005 years ago which took out the power train control module next to an engine computer behind the glove box, the two of them do not share the same power source, i found after much schematicing around, which led me to a fuse, that when pulled, disintegrated.
    There is a bigger problem than the HV and working on the battery at this point is futile, in my opinion.
    #26 tracy ing, Aug 17, 2022
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    That's odd, because after 99 years of being qualified on 6.7 million systems, and having 4 minutes of hands on experience, I've always been of the mantra to fix the obvious first. It's probably saved me at least 400 years of tail chasing false triggers.
    How ITH is he supposed to do that without an HV battery? Do you actually know how a Gen 2 works?
  8. tracy ing
    384
    173
    wash dc
    no i am totally clueless, yes you are right, he should spend about 4 weeks and unlimited cash building the perfect prius pack, instead of inserting what he has so he can troubleshoot the core issues, your way, he can put the pack in after hundreds of hours of work, and maybe find, the car is toast.
    more excellent advice here
  9. ChapmanF
    19,010
    Here's what he has. It might not start the car.
  10. tracy ing
    384
    173
    wash dc
    You people are something else, obviously thats what he HAS and he states he has ORDERED the parts.
    You people post strawman arguments that are retarded at the core.
    So since comprehension skills are lacking here
    1- You state you fried some stuff
    2- You state you are securing the parts
    3- You state you have all these non HV issues that prevent the car from being usefull for transportartion
    SO
    DO THIS
    ONCE YOU GET THE PARTS
    ASSEMBLE THE HV
    DONT WORRY ABOUT HOW GOOD IT IS
    INSTALL IT
    THEN
    GO FIX THE CORE ISSUES IN THE CAR
    THEN
    COME BACK TO THE HV
    CAUSE YOU MAY BE REPAIRING A JUNK CAR
    SO WHY WASTE TIME PERFECTING THE BATTERY
    For the mentally disabled here
    PS Your assertion that the OP would try to diagnose the car without the HV infers that he is stupid, he is not stupid, but your inference that he may come to the conclusion from my post that you did is actually a slight on him, not me, well, and you, for inferring such random stupidity into the thread in the first place
    This is what happens when your personal bias and agenda override your common sense and dignity
    #30 tracy ing, Aug 17, 2022
  11. tracy ing
    384
    173
    wash dc
    Let's see, he is in iowa, so he can mess around with the HV, then, he can start trouble shooting a car with issues in colder and colder weather, maybe snow.
    Or
    He can fix the car, and work on the HV indoors where its nice and dry and comfortable regardless of whats going on outside
  12. alftoy
    1,132
    519
    And you have no agenda? :ROFLMAO: Oh, the look at me agenda. Oh, look at all the stuff I do and have agenda. YAWN.
    You sure get riled up over a perceived slight.
  13. tracy ing
    384
    173
    wash dc
    you people are funny, agenda, look it up
    lol look at me agenda
    but at least going forward i know where you stand, explains why you post "gotcha" questions in my posts, that go nowhere you hoped, then edit them and delete them leaving an empty post.
    not into your games
  14. Prius92
    595
    122
    Iowa
    No need to argue guys.
    I can't fix any other issues right now until I get the battery rebuilt.
    The old sensing harness had tons of blue corrosion on it, so I'm replacing it with a brand new one, and have to now anyway since it got burnt up.
    The lugs of the contactors don't seem to have any spots of heat damage, arcing, etc. However I also noticed the nuts aren't lock nuts, and will probably use lock nuts going forward.
    I can't use a torque wrench on the bus bars because mine does not go down that far.
    Also..on the 12v battery..it looks like at one time there was a small clip that held the plastic around the pos terminal to the carrier, but can't find that clip in part diagrams.
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
  16. ChapmanF
    19,010
    I would be cautious about any change of nuts from Toyota's. A lock with a locking washer, for example, could seem like a good idea, but end up making poorer contact. An actual "lock nut", with pinched threads making it hard to turn, would play havoc with getting the right torque and contact force.
    Easily remedied at a nearby Harbor Freight, etc.
  17. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    I'd second Chapman's advice. Go get an in*lb torque wrench.
    I'd be cautious also about changing to lock nuts. If you cannot reuse the old nuts that came off the modules, buy some new ones of the same type, preferably from Toyota.
  18. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Well, I have nothing else to say.........
  19. Prius92
    595
    122
    Iowa
    Would it be better to use lock washer/nuts on the big orange wires on the contactors?
    I have new nuts I got off amazon, M5x0.8mm with the serrated teeth on the bottom.
    shorturl.at/cfjwX
    Weird thing is..after hand tightening with a nut driver..they all were slightly loose when I took the cover off. So I might need to invest in a 1/4" torque wrench.
    #39 Prius92, Aug 17, 2022
  20. alftoy
    1,132
    519
    Serrated nuts, not advisable.
    Battery bus bars | Page 2 | PriusChat
