Can't locate a front tie-down for canoe - Prius 2008
Discussion in 'Gen 2 Prius Main Forum' started by Priuses4All, May 4, 2013.
  1. Priuses4All
    Priuses4All Junior Member
    17
    Some Prius owners have posted that they carry canoes on racks fitted to their Priuses. I just bought a canoe, have a rack, but I can't find anything to tie to at (or under) the front of my 2008 Prius. The Toyota-provided screw bolt that you can install in the covered port in the bumper is way off the centerline of the vehicle, so that's not helpful to tie down the front end of a canoe.
    I'm hoping not to have to drill and mount an eye bolt and I don't do welding. Any canoe-carrying Prius owners' suggestions would be much appreciated!
  2. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Priuses4All,
    Welcome to PRIUSchat. :)
    Found using 'tie down' in the search function:
    4 Point Kayak Holder: Front, Rear and two middle | PriusChat
    it is EXTRA important that kayak(s) be secured with a line from the bow to front of car.
    I have found the perfect attachment point (there are few options). Pop the hood. Attach
    a permanent loop through the small hole directly below the hood latch, and pull it through
    the first grill opening. Voila! You now have a bombproof attachment point, that you can
    tie a line to the kayak(s), without opening the hood,or crawling under the car. Use thin
    high strength nylon cord....use a trucker's hitch to tie off kayak to loop that you can stash
    in grill opening when not in use....
    Anyone haul a kayak on your Prius? | PriusChat
    I also recall a member posting that they used the hood and rear hatch hinges as tie down
    points... But I can't find the post. Thinking about it, the lead angles of the ropes/straps
    wouldn't appear to be right; more fore and aft than up and down. I do not know!
  3. Priuses4All
    17
    Rokeby - Thanks very much for your great idea! I immediately went out to the car and popped the hood. -- How in the dickens did you loop nylon cord through that small hole?! I guess I can do it with some dental probes! ;)
    I'm wondering, given how small diameter that hole is in my Prius (maybe 3/16"?), whether it would be a stronger anchor point for my canoe to use a piece of heavy insulated copper-core wire, and thread this out through the grill. Or maybe use thicker nylon rope around the hood latch support itself?
    Edit: I tried a short length of (I think, 1/4") vinyl-covered braided steel cable and got it threaded through the hole. Had to use a hooked wire to pull the end back out through the opening in the grill, and then I put a small cable clamp on the two ends of the cable. Once the long end of the cable was cut off I pushed the cable clamp through the grill into the engine compartment, leaving a nice steel cable loop that I can use to tie down the front end of the canoe. Very handy!
    Thanks again for sharing your ingenious method!
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I'm glad that I could point you towards a solution that might work for you.
    I wish that I could claim some small credit for the through-the-grill idea.
    But, I can't. I just used the tried and true method of using the search function
    to dig around in the archives. Just about anything Gen2 related is addressed in
    there somewhere.
    'The search function is your friend.' :)
    The Biggest Tool in the Newbie Arsenal | PriusChat
  5. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    Rokeby likes this.
  6. metro-mike
    metro-mike Junior Member
    53
    Tacoma WA
    I would think using the front bumper tow hook would work for you.
  7. wjtracy
    wjtracy Senior Member
    11,313
    3,588
    Northern VA (NoVA)
    The Prius has the nicest tie downs on all 4 corners at least 2006. Up front they are sort of directly beneath the head lamps. The view from an angle is blocked by plastic so you sort of have to look close to the headlamp. Someone on PriusChat talked me into a Tarpon 100 kayak last year, which he fits in the Prius by leaving the tail gate open with a tie down. I just put it totally inside my minivan. So I have not been doing the canoe much.
  8. Widget
    Widget Junior Member
    If you look on REI's website or similar ones, search for seatle sports hood loops or quick loops. Pieces of nylon that you bolt underneath the hood.
    This is what I do with my prius (note - the distance between bars is so short that it really seems to be necessary to diagonally cross tie sea kayaks when carrying them... they work themselves loose easily as compared to on my subaru), it saves the paint on the front. I put a hitch on the back of mine, so I hook to the hitch in the back.
    wjtracy likes this.
  9. Saguache
    Saguache Junior Member
    Vashon, WA
    2014 Prius v wagon
    Got the rack and kayak (even though it's not quite done) atop my 2014 v (lowercase v for the Prius v wagon) yesterday.
    wjtracy likes this.
  10. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I guess this is a thread resurrection, but I use the shipping tie-downs underneath the front valence and up under the bumper in back. The canoe tie down cords we have (they've been in the family a while) have sections of rubber tubing over the rope near the ends to protect the bumpers.
  11. MElizabeth
    MElizabeth New Member
    Central Florida
    That is impressive! What length bar is that? 60"? And the weight/load on roof is ok? Do you have a sunroof?
  12. JerryCS
    JerryCS Prius camper with trailer hitch
    76
    Elk Rapids, MI
    With a trailer hitch in back it's easy to use that in the rear. In front, the two shipping eyes don't let rope run easily and they are not easy to locate. During boating season, I hang a carabiner (actual climbing carabiners, extremely strong) in each one making it easy to tie in. I like the idea of the nylon webbing loops bolted under the hood, but my boats are too long...
