Can't Open The Charging Port Door! A New Years Tale
Discussion in 'Prime Plug-in Charging' started by plow, Dec 27, 2016.
  1. bisco
    51,948
    don't ever recall reading about a problem. maybe they put it in because japan gets the 100v out?
    jerrymildred likes this.
  2. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    Mrs. Bear did this on the first time she used a public charging station. She arrived home with the charging port lid open about a half inch and a warning message displayed. Pushing or pulling on the lid seemed to risk damaging something.
    Note that when the port cap is placed improperly in its storage position or allowed to dangle from its tether, it's possible to wedge the charging port lid in a semi-closed position if you try to close it by using excessive force.
    Fortunately, I had skimmed the printed manual and vaguely recalled seeing something about dealing with the charging port lid if it would not open normally:
    This is really obscure, but something that's good to know. It could save you a needless trip to your dealership.
    Also, be aware than when the charging port lid is properly closed and the car is locked, the lid is also locked. Unlocking the car -- or just carrying the wireless electric key in your pocket -- will allow the charging port door to be opened.
    The user manual also notes "If the rear edge of the charging port lid is pressed when the doors are locked
    and you are not carrying the electric key, the charging port lid opens slightly, but remains locked. Carry the electronic key or unlock the doors, and then press the charging port lid twice to open it." I interpret this to mean that you press the lid once to get it fully closed and then a second time to open it normally.
  3. ml888
    ml888 Member
    50
    29
    New Jersey
    Thanks for the post! I encountered that today and glad that I searched and found this post before trying to tinker with the door.
  4. Sara Jane Pasti
    Sara Jane Pasti Junior Member
    Kingston, NY
    I found your post today when I was shoveling snow and mistakenly shut the port lid with the cap in the holder, not in the plug-in slot. Somehow the lid shut, bit not all the way and it could not be reopened from the outside. I found the solution on p. 116, just as you said, and it worked!!
    huskers and bisco like this.
  5. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Is he allowed to use the "S" word this early?
  6. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Had to get out my snow blower yesterday. Was only 4-5 inches, but heavy enough I needed small engine help. sigh
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Early? I'm sick and tired of climate change. Last year I didn't use the snow blower even once. This year the same. I used to use it around 3 times by now.
  8. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    I just drove it and so I had my key. Wouldn’t open. One time I tried to close the charger door with the plug left in the holding station and it would not close. I’ll have to try the emergency release later. Is it possible it might be frozen? Extra cold this morning! Had a train to catch so there was not enough time .... :-(
  9. Salamander_King
    11,019
    8,954
    New England
    If you had a key with you, and you did not jam the cap on holding position, ice built-up frozen shot might be a possibility. If that is the case, it should melt by afternoon in your local. Wouldn't day time high be above freezing?
  10. barbaram
    912
    70
    Trenton, NJ
    Temp daytime will hover around freezing but I hunk it will be in the sun. I’ll find out about 3 pm.... otherwise I have the emergency instructions now thanks to all the experts here.
    Salamander_King likes this.
  11. Salamander_King
    11,019
    8,954
    New England
    Good luck! Let us know how it goes, and what was causing it if you find out.
  12. barbaram
    912
    70
    Trenton, NJ
    No problem this afternoon, it opened right up! No real sign of any moisture either. Cap in correct position. Perhaps just old Mercury shaking his fist at me? Hopefully it not happen again. There was a Tesla there that didn’t plug in, guess I should have moved when I couldn’t get it connected. Not many charging slots.
