Can't open the driver door
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by semilak, Jun 11, 2023.
  1. semilak
    semilak Junior Member
    Darwin NT
    Hi guys
    I installed sound deadening and haven't put the door handle wires correctly.
    If I remember well I installed the heads of the wire properly but forgot to put in the right position the green and white plastics..
    It can't be opened from both sides and central locking doesn't work :confused:
    It looks like I need to damage the inside part of the door a little bit for opening the door.
    I hope there is a chance for opening the door in a less brutal way :)
    Thanks a lot!
