Can't put my Prius in to drive nor reverse
Discussion in 'Gen 2 Prius Technical Discussion' started by vlaadt, Sep 14, 2017.
  1. vlaadt
    vlaadt New Member
    I cant put my Prius in to drive for some reason.
    I was in a minor accident but it was drivable but one day I sit in it and it just beeps twice and won't go into drive. I tried neutral or reverse, nothing. Also I got a weird Car and exclamation sign on the screen.
    Any guesses what that might be?
    I took some pictures of my dash board hope that helps.
    Thbak you so much in advance.
  2. Moving Right Along
    Moving Right Along Senior Member
    687
    539
    Looks like you're out of gas. You've got no lit up squares on your gas gague, which would also explain your low battery level. You can try adding at least 3 gallons of gasoline and see if that helps.
    Of course, you also may have damaged any number of things in the accident, but I like to start with the simple things.
  3. vlaadt
    vlaadt New Member
    I had very little gas as well and it was able to put it into drive but I will try adding gas. Thank you, I will let you know how it goes.
