Can't reset tire sensor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lenjack, May 9, 2017.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    ..and skips subscribed replies. That means back to the dealer for diagnostics. They didn't do that. It was a free visit. Damn!
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    It can be costly to replace TPMS sensors.
    My tire place would charge me $30/tire, and that is just the installation fee assuming I buy the replacement TPMS unit (from Amazon) and reset the codes by myself with Techstream.
    TPMS Management with Techstream | PriusChat
    #22 wjtracy, May 13, 2017
  3. JC91006
    16,935
    8,646
    I had a friend that bought a 2006 with 2 failed sensors, I used techstream and disabled all 4, no more lights
  4. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    How long did that last? My experience is the warning light will come back on, although I never tried disabling all 4 tires.
    How did you "disable"?
    I can get the warning light to go out for weeks, but at some point (after a long enough drive) the computer will figure out you faked it out.
  5. JC91006
    16,935
    8,646
    I registered 4 new codes.
    0000001
    0000002
    0000003
    0000004
    All cleared.
    I took a screen shot of the sensor codes before I changed them, just in case I have to put them back. So far after 3 weeks, no warnings. Just like my 05 without sensors
    m.wynn and Raytheeagle like this.
  6. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    If that's true, that's cool as no one has yet figured how to disable the TPMS like that. But I am skeptical. I have tried similar to that approach and seen it to be temporary (several weeks) success.
    If the person only does short drives, then it could take a while for the TPMS system to realize the spoof attempt.
  7. JC91006
    16,935
    8,646
    Try it, it works perfectly. I just did it as an experiment after reading your 0000001 code, just did it 4 times
  8. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    I will try but my Techstream sessions are not too frequent as I use a desktop.
    Tell you what, when I finally lose another TPMS ( so far still have 3 of 4 good almost 11 years old) I will def try it then.
  9. JC91006
    16,935
    8,646
    It's only been 3 weeks, I can update you if the lights return. But my friend does really short trips everyday, less than 10 miles 1 way daily
  10. Mendel Leisk
    42,289
    Does a warning light get either of you pulled off the road, fails inspection? (n)
  11. JC91006
    16,935
    8,646
    I'm not sure if it'll fail inspection. CA has smog inspections and this is not emissions related
  12. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    In my experience, it can take 20 minutes of driving for the system to quit looking for a dead sensor and throw a light. Interesting observation - please keep us updated.
    Inspection issue depends on your state. Here is a list from TireRack
    Wheel Tech Information - State TPMS Regulations
    Raytheeagle, wjtracy and Mendel Leisk like this.
  13. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    That's very interesting re: state regulations!
    Sure glad my state VA is on the correct side of that. I am thinking many states do not even have inspections, so to require TPMS to be working is a real hassle, for those subjected to states mandating working TPMS.
    #33 wjtracy, May 13, 2017
  14. KJ Fitz
    KJ Fitz Junior Member
    55
    Guam
    The other day someone assured me that I'm nuts, and that there is no sensor in the spare. Be that as it may, I dug out the spare, found it at 25 PSI, filled it to 60 PSI, and was suddenly able to reset. So either the conventional wisdom regarding a sensor in the spare is wrong, or I experienced The Mother of All Coincidences. Can't hurt to check, anyhow -- glad I didn't NEED my spare, only to find it deflated.
  15. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    The ECU can handle it (it has a 5th data set, visible in Techstream), but a sensor usually is not installed in the compact spare they provide in our market. Glad that worked for you.
    Always worth keeping that spare ready, in any case, should you need it!
  16. Mendel Leisk
    42,289
    @KJ Fitz , what does the valve stem on the spare look like, metal or black rubber? Metal would likely mean it has tpms sensor, and black rubber definitely not.
  17. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    One of our PriusChat members (I think @RobH) added TPMS to the spare tire to make 5 tires covered, but it required that he manually reprogram the ECU to set it for 5 tires. other wise the system only takes 4 tires and will not let you insert the code for Tire5.
  18. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    The TPMS ECU does in fact support 5 tires. About 7 years ago I was studying the messages that Techstream used to query/set TPMS status. There is a message (0x21 0x06) that queries the number of TPMS sensors that are registered. I discovered that Techstream reported 4 or 5 sensors, depending on the reply to the 21 06 query. I tried a leap of faith experiment of sending a message that set the current value to 5. It worked, and I was able to register my spare as a TPMS device. The program that did it was a one-off experiment that is lost to history. Note that the messages are for the K line, not CAN. It will be necessary to directly access the Techstream device driver to send these messages - CAN bus and the ELM don't have the ability. The protocol allows any value of 0 to 7 to be set, although only 5 has been tested. Note also that some Toyota vehicles have a switch that selects between two sets of TPMS devices. The Prius ECU is wired to report the switch in the Main position. Perhaps comparison of the Prius ECU with an ECU used in a two-set vehicle would reveal how to add a similar switch to the Prius.
    The following are the messages I decoded. The values are in hexadecimal.
    82 2A F0 21 06 ........ Query # sensors registered
    84 F0 2A 61 06 x0 y0 .. x=main set, y=2nd set
    ....................... x:8= 4 sensors, x:A= 5 sensors (high 3 bits of Each byte)
    84 2a f0 3b 06 x0 y0 .. Set # sensors that can be registered.
    ....................... x=main set, y=2nd set
    82 f0 2a 7b 06 ........ Reply
    82 2A F0 21 07 ........ Query # of sensors registered (during registration)
    84 F0 2A 61 07 0x 00 .. high 3 bits of x is count
    82 2A F0 21 09 ........ Select Switch position
    84 F0 2A 61 09 x0 00 .. x:0=Main, x:8=2nd
    #38 RobH, May 15, 2017
    ILuvMyPriusToo, wjtracy and SFO like this.
  19. Danger
    Danger Member
    175
    22
    Frisco
    After a long saga to figure out what was going on. I ordered the same MVCI cable on Amazon and tested it out. Guess what IT WORKS! I can read my TPMS sensors. Whohoo! So after paying $60 for a cable on eBay thinking it was the latest version 2.0.4 firmware. And going back and forth having installation problems. They sent me another cable and it worked for all my cars, but no TPMS readings. So for $60 I got a 90% working cable and customer support that made TS ver12 work. The Amazon cable is firmware 1.4.1. Finally I can replace my TPMS sensor. Does anyone know the orienation of the sensors? Is sensor 1 driver front, sensor 2 pass front, sensor 3 pass rear and sensor 4 driver rear? Thanks for all the help everyone.
  20. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Glad this cable is working as expected. The sensors are not in specific locations; is it clear that one is not reporting? You need to watch the numbers and drop each tire in turn by a few psi to figure out which working sensor is in which wheel/position. Then you will know where the one is that needs to be replaced.
