Can't "SEE" my oil <> Why?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, May 3, 2010.
  1. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    The manual says to run the engine up to full working temperature, then park on a level surface, turn off, wait five minutes for oil to flow back into the sump, then measure.
    If you don't do this you get an erroneous result.
  2. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Just went and looked... It looks like I was removing 40-50 ml per syringe for a full removal less than a cup, but getting close.
  3. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,840
    Hyampom
    For all of "US" metrically-challenged folks in the USA -- 45 ml is just a smidge over three tablespoons -- or 1 and a half ounces....(1.5 ounces).
