Can't shift to neutral
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ejensen, Oct 10, 2021.
  1. ejensen
    ejensen Junior Member
    Philadelphia area
    Hi all,
    We have a 2004 Prius with about 85,000 miles on it, and recently it won't shift into Neutral. Shifting to other gears works OK. Any suggestions for what to look at here? Or is this something where we just have to take it in have someone look at it?
    I've searched through other threads and have seen occasional mentions of not being able to shift to Drive or Park, but nothing about Neutral. Possibly those are similar issues with the shifting mechanism, but I'm not sure.
    Thanks for any thoughts or advice here!
  2. JC91006
    16,937
    8,647
    you hold the lever to the neutral position for 1-2 seconds and it'll go into neutral
    Raytheeagle and ejensen like this.
  3. nancytheprius
    nancytheprius Active Member
    365
    157
    iowa
    yes you have to hold it longer than you would expect
    ejensen likes this.
  4. ejensen
    Philadelphia area
    OK, thanks! The car is no longer in my possession - my son now has it, and reported this recently. I bet this is it - I'll check with him and report back.
    Thanks for the quick help,
    Eric
  5. ejensen
    Philadelphia area
    As expected, this was the issue - he just wasn’t holding the shift lever there long enough. Thanks again for the quick and on-target replies.
