Can't start the ATF fluid swap
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JJ Pen, Dec 21, 2022.
  1. JJ Pen
    JJ Pen Junior Member
    Salem Oregon
    Hey Everyone, it has been 5000 miles since the first oil change was done on my prius since I've had it. I thought I would also swap the ATF fluid. After following this video
    and getting the 24mm socket and 10mm hex socket.
    I can't get the drain plug open! I have a torque wrench that has started to strip the 10mm inverted(don't know the technical term) bolt to drain the fluid. My wife suggests Wd40 but I spent a couple hours trying to get it out. I borrowed an impact drill and ended up twisting one of my bits. No movement on the bolt.
    Any ideas? Definitely learned alot for first oil change ever. Wish I could have finished the ATF fluid though.
  2. Tombukt2
    Tombukt2 Senior Member
    13,871
    2,521
    Durham NC
    You could take a plumbers torch with the yellow can of map gas screwed to the torch preferably a pencil flame and heat the area gently around the bolt I'm assuming you're on the correct bolts you need to be undoing with the video I can't see from here but heat will generally help a nut or a bolt to come out of metal You're not trying to melt anything we're just trying to heat it up see if that works if you're scared of fire well I guess that's that You could try a heat gun but that would be a slow process it's like a blow dryer for the shop. If you're breaking bits I would tend to thank your seriously overpowering the bit or the bit is not up to impact duty which is also possible.
  3. Mendel Leisk
    42,365
    Just being Captain Obvious: object with the heat is to slightly expand the metal of the threaded hole, so the bolt (being cooler) will hopefully loosen.
    maybe buy a replacement bolt before going any further. If you can verify the bolts stats, maybe you can get an alternative hex head bolt?
  4. ChapmanF
    19,045
    This is a good place for the traditional advice to always crack open the fill plug first. Why? Think how frustrating it is when you can't get the drain plug open. Then think how it is when you got the drain plug open, then can't open the fill.
    #4 ChapmanF, Dec 22, 2022
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    Seems silly to mention, but
    keep in mind this plug is upside down....make certain you're turning it the correct direction.
    Sometimes a love tap will help free stuck fasteners
    Sometimes heat will do the same
    I don't think I've ever, ever, ever stripped a hex socket when using the hex wrench, that thing must be stuck like crazy.
  6. Mendel Leisk
    42,365
  7. Tombukt2
    13,871
    2,521
    Durham NC
    I have the same drain plugs on my piaggio Italian single cylinder engines in my scooters this company also makes airplanes. And some of these things get ridiculously stupid type I'm not sure why I don't know if it's the type of metal the threads the steel being screwed into aluminum or exactly what generally I try to make sure once I get them out I never put them back in anywhere near that tight. Maybe some anti-seize on the threads.
    JJ Pen likes this.
  8. Mendel Leisk
    42,365
    On our 2010 both fill and drain bolts are socket head cap screw, with 10 mm hex pocket. They're a little stubborn, but never started to strip. I used a 19" ratchet wrench, with a "hex bit socket", I think that's the terminology. Looks like this:
    If you're using an Allen key with a cheater-pipe, maybe not so good.
    I wish Toyota would take a cue from Honda: their transmission drain bolts are socket head cap screw, with a 3/8" square hole: just put a 3/8" drive ratchet bit in it.
    Tombukt2 likes this.
  9. Tombukt2
    13,871
    2,521
    Durham NC
    I believe some early Toyota transmissions were like this in k e. t e and r a Celica cars w and T transmissions come to mind . Been a long time ago
  10. Mendel Leisk
    42,365
    Not sure what you said but sounds good. (y)
    Can you read it??
    edthefox5 likes this.
  11. Tombukt2
    13,871
    2,521
    Durham NC
    KE and TE and RA we're the the codes for Corolla and Celica Toyota models of yore. They had RWD trans and solid diffs. And similar plugs in thos trans and tears similar to the Honda you like the differential had 1/2 square hole install your half inch drive ratchet give it a yank All you needed No tools just the ratchet
  12. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    The OP's only viable solution is to drill out the center of the drain plug with a 1/4 inch drill bit, drain the transmission fluid and then take out the plug with a broken bolt extractor.
    I would drill carefully and retrieve the steel cuttings of the drain plug with a strong magnet especially before the drill breaking through, I would stop just before the drill breaks through.
    Then, I would drive in a straight broken screw extractor to break through the center of the drain plug and wrench out the plug,
    https://www.northerntool.com/shop/tools/product_200685157_200685157
    I would replace the drain plug with an M18x1.5 magnetic drain plug like this one.
    #12 Georgina Rudkus, Dec 23, 2022
  13. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    You have to know when to hold 'em, and know when to fold 'em.
    I'm all in favor of "learning experiences", but you may want to consider taking this to a repair shop. Once the female hex of the drain plug is damaged, then things can get tricky. If you get some specialized tools, you might be able to remove it yourself. If you damage something, do you have a plan B?
  14. JJ Pen
    Salem Oregon
    Thanks for the responses!
    Fill plug was never an issue.
    I was going to grab a bolt extractor kit and pick up a replacement bolt from the dealership like was mentioned. But decided to invest in a cordless torque wrench and torque driver (I figured I want to do work on a car and those tools make it a lot easier). The torque wrench didn't fit the 3/8th socket on the 10mm allen because I didn't have a conversion but I did have a bit that fit for the torque driver that is less powerful. I guess that and the wd40 did the trick. Thanks for the help!
    Mendel Leisk and bisco like this.
  15. JJ Pen
    Salem Oregon
    I have since learned of the benefits of pb blaster penetrating oil over wd 40 for rusted bolts, very helpful. Napa auto parts had a really affordable replacement Atf toyota ws equivalent Enos? i believe? Did the same on our highlander hybrid.
  16. Mendel Leisk
    42,365
    Last time I checked, Toyota ATF WS was around $11 CDN per liter through our dealership parts department, and readily available. And they have the replacement washers for drain and fill bolts.
    No offense, but considering Toyota cautions that anything else could damage the transaxle, and this is something you do once, maybe twice, in the car's lifetime, I'd rather not risk "equivalents".
    Georgina Rudkus likes this.
  17. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    I use a half inch impact gun with the socket to pop the plugs out. But then I use the socket wrench to put it back in gently
  18. douglasjre
    2,250
    751
    Null, NL
    I've used Max life LV the 1 gallon Red jug from Walmart and dozens of Prius over the past 15 years. Never had a single problem. I've owned four Prius personally and put a combined half a million miles on them I never had a problem with them either. Up to you I can't blame you for buying the Toyota WS. Maxlife LV is very slightly thicker and I guess you could say it's not the same thing so it's up to you
