Can't use cruise control for 1500 miles?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by csk47, Jan 8, 2011.
  1. csk47
    csk47 Junior Member
    Port St. Lucie, FL
    As odd as it may sound, our Prius salesman told us we should not use the cruise control on our 2010 Prius II for the first 1500 miles. We could not find any such warning in the manual. Did we just misunderstand or was the salesman correct?
    Any explanation is appreciated.
  2. msirach
    msirach Member
    321
    Southern Illinois
    I have only used the cruise control to make sure it worked. He was getting carried away by saying the cruise should not be used for the 1st 1500 miles. Just don't drive the car in a manner that the motor revs excessively.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    While I don't agree with the specifics of the recommendation, it is true that during the break in period, you want to vary speed, RPMs, etc., and using cruise control would not accomplish that. Who knows where the 1,500 miles came from. :confused:
  4. donaldhall
    donaldhall New Member
    17
    Lumberton, Texas
    The manual say's, during the 2000 mile breakin refrain from long constant speeds or something like that.
    You CAN use the cruise, just dont do a tank full of gas at one steady speed.
    I am in the process of reading the manual on my new 2010 V, ha ha
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Yeah, the manual says don't drive at a constant speed for X miles, and since the cruise does just that, that's why he said not to use it.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Unless your area is billiard table flat (like mine) even at constant speed the RPMs will vary quite a lot.
  7. brick
    brick Active Member
    1,083
    78
    Upstate NY
    What he said. If you have hills, you have sufficiently varied RPMs. That's all the engine needs.
  8. zonie911
    zonie911 Member
    585
    Nashville, Tennessee
    It's true, it's true, it's true.
    At least, that's how my service rep explained it to me also, when newly purchased.
  9. fuzzy1
    10,172
    The recommended breakin period for my 2010 was only 600 miles (see manual, page 151), not 1500. And the recommendation against constant speeds was only for extended periods. I did a lot of playing with it for short periods as part of learning how the car works.
  10. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    For the OP, your salesman is a jerk. You have to take everything told to you with a grain of salt........Drive your Prius as you would any other car.......enjoy it !!!!!!
    FWIW: Read the owners manual cover to cover.......TWICE !!!!
  11. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Salesmen don't usually know much about the cars they sell, they specialize in ways to get into your wallet instead. That idea, no cruse control for some number of miles, is for conventional cars that would maintain a constant engine speed with the CC set. As previously mentioned the Prius does not do that, engine speed will vary constantly even with the CC set.
    I would avoid full throttle except in an emergency for the first 600 or 800 miles and take it easy on the friction brakes for the same period and you will be fine. Actually it's pretty safe just to drive in a normal fashion from day one.
