Car alarm keeps beeping and won't.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cruz05, Jun 7, 2016.
  1. cruz05
    cruz05 New Member
    Salem Oregon
    Car is a 2005. So this morning i hear a car alarm to go off. I soon realize is mine so i grab my keys go outside and try to turn the alarm off. The fob key didn't not work when i tried to turn it off. The car has the oem alarm.I had to turn the car on in order to stop the beeping. Once i got to work i turned the car off and the alarm kept beeping. So i left the car on for an hour and then i went out turned the car off and the beeping stopped. After about 6 hours the beeping continued and by then it was time to go home so i just left the car on for another 30min until i left work. got home and parked the car and about 30 minutes later the beeping continued once again. I took the car to get the 12v battery tested but they said it was good. If anyone had this issue before and can help out that would be great
    #1 cruz05, Jun 7, 2016
    52,773
    what is an oem alarm? how do you set it? 12 years and 3 pri, i didn't know i had one.
  3. cruz05
    cruz05 New Member
    Salem Oregon
    it the alarm that comes stock with the car
    52,773
    how do you set it?
  5. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    There might be a glass breakage sensor on your car that is defective that might be causing the problem. There was an accessory that was available when I bought my 2004 Prius (I didn't get it, so I am only guessing here).
  6. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    Could be a stuck or extremely sensitive panic button on your fob.
  7. cruz05
    cruz05 New Member
    Salem Oregon
    W\I don't know if I have one. Bought the car used of cl. but ill keep it in mind
  8. cruz05
    cruz05 New Member
    Salem Oregon
    Maybe. i replaced the battery not to long ago. But a mechanic suggested to get a new one. Hopefully its just the fob key
  9. cruz05
    cruz05 New Member
    Salem Oregon
    I click on the lock button and it locks. To unlock i just grab the door handle and it unlocks all doors
  10. bisco
    52,773
    and how do you make the alarm go off, do you have to break into the car?
  11. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    Sounds like the panic button on the Fob. I didn't think Prius had a OEM alarm.
    #11 lar.smith42, Jun 8, 2016
  12. bisco
    52,773
    i haven't heard of one in 12 years, unless it's dealer add on or aftermarket.
    lar.smith42 likes this.
  13. dolj
    dolj Senior Member
    8,633
    4,386
    Wellington, New Zealand
    The easiest way is to roll down the window, then get out, close the door and lock the car. When you see the immobiliser light blinking, reach in and open the door. That will set off the alarm.
    It is factory fitted. I think in some markets it was an option for some of the lower spec models.
  14. Shane Burns
    Shane Burns Member
    94
    126
    SoCal
    I have that same problem with my 2005 Prius. It also have aftermarket alarm installed (Rockledge). I figured that my key fob might be dead so I switched to different key fob. No problem since! Have you tried using different key fob?
  15. cruz05
    cruz05 New Member
    Salem Oregon
    i only have one as of now but i did order a new one this week. hope thats the problem. cars been parked for a week now with the batter disconnected
  16. bisco
    52,773
