1. Missgreen2061
    Missgreen2061 New Member
    Chandler, AZ
    hello, I have a 2008 Prius. I was driving and the Master Warning Light + the check Light + something else came on and a few moments later my car died. I just had it towed home. I am not sure what to do. Any advise? I just had the windshield replaced, air filters replaced, oil change completed a few days ago. Help???
  2. Stevewoods
    Stevewoods Senior Member
    666
    1,267
    where I am
    Probably NOT the problem, but a quick, easy thing to check is the oil level. Pull the dipstick and see how much oil is in the engine.
    This car is very sensitive to having the oil overfilled, and unfortunately, it is not Uncommon for the oil to be overfilled during an oil change.
    If that is the problem, hopefully draining the excess will solve the problem and there is no long term damage.
    Reading the codes, of course would help.
  3. Missgreen2061
    Chandler, AZ
    Sorry to sound stupid, but I have always had the oil changed at shops. Where is the dipstick for my son to check?
  4. Stevewoods
    666
    1,267
    where I am
    Watch this video, after she puts the supplies on top the engine, she pulls up the dipstick and checks the oil
  5. Missgreen2061
    Chandler, AZ
    Sorry, found it in the manual, my son will check it.
  6. Missgreen2061
    Chandler, AZ
    Yep, Oil is fine, no overage.
  7. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Welcome! Sorry you are having a problem with your car. Maybe you can have it towed to a Toyota dealership or an independent hybrid-trained mechanic so they can figure out your problem and whether it had anything do to with the work you recently had completed. As the other poster said, they can use a computer to read the trouble codes from the car's computer and that will help them figure out the issue. Good luck! Let us know what they find.
  8. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Just a thought, but do you know you weren't out of gas?
  9. Missgreen2061
    Chandler, AZ
    It has plenty of gas. Oil was fine as well.
  10. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Well, those are the simple things . . . :(
  11. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Try this: Without placing your foot on the brake pedal, press the start button twice to see if there's power
    (the start button should be a solid green at this time). If not, then you should consult your owner's manual
    as the first step of troubleshooting the problem(s). When you say your car died that can mean a lot of things.
  12. Missgreen2061
    Chandler, AZ
    Thanks, I will try that. ... Ok, I tried that. No luck. Thanks anyways...
  13. jadziasman
    1,355
    488
    District 6
    Does that mean you saw solid green on the start button or not?
  14. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    You have 8-yr 100000 mile warranty so you might be just over 8-yrs? Hopefully just under.
  15. johnjohnchu
    johnjohnchu Active Member
    212
    105
    Perhaps it is the batteries (12V and/or HV).
  16. Missgreen2061
    Chandler, AZ
    The only green light is where the Key goes.
    only green light is where the key goes. and on the dash, it lights up showing the car door is open.
  17. Missgreen2061
    Chandler, AZ
    I bought the car used from a Toyota Dealer. I have only had the car now for just over 5 years.
  18. bisco
    52,847
    welcome! how many miles? might be your inverter pump. did you do the recall?
    Stevewoods likes this.
  19. Stevewoods
    666
    1,267
    where I am
    This is all just going to turn into "did you."
    The easy first checks are the oil and the gasoline. You apparently passed. Without a great deal more information, this will all be WAGS.
    Bisco (and I am surprised:eek:), does bring up a sort of decent point. You should register your Prius on the official Toyota owners website -- google it == it will tell you at least some information about the car and will let you know if any recalls have or have not been performed, such as the inverter.
    But, at least from my point of view, all the rest of this is just throwing chaff into the wind without some solid codes, or even better information about how the car "died/"
  20. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Your 8-yr/100000 mile hybrid warranty is based on when the first owner purchased the car...you may need to call Toyota to establish your car age in their records. Unfort you may be just over, but it's worth a chance. Also depends on miles which you have not given us yet.
