Car does not turn off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kitty500, Mar 18, 2026.
  1. Kitty500
    Kitty500 Junior Member
    Wisconsin
    The car is not shutting off after the key is removed and the power button is pressed.
    • MFD display turns back on when the car is turned off.(attempted to be turned off)
    • The car beeps as if the key fob is still in the ignition.
    • The cars doors will not lock.
    • All of this creates a drain on the battery.
    • The battery reads less than 12 V with no load and 14.1 with a load
    • a new battery has been placed in the vehicle – AGM
    • disconnected negative cable from a fully charged battery and the next day, the battery has been drained.
    Please help. please provide steps to determine if there is a parasitic draw from the system. I have a multimeter. Thanks in advance….:
    #1 Kitty500, Mar 18, 2026
  2. ChapmanF
    18,993
    How is the combination meter (speed, odo, fuel, mpg, PRNDB) behaving?
    Brian1954 likes this.
  3. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    Can you confirm that what you mean here is you have disconnected the negative cable from a fully charged battery and left it disconnected for the whole night, then when you checked the voltage of the new battery with a volt meter the next day, it was completely drained–i.e., measured 0 volts. If this is not what you meant, can you state exactly what happened?
  4. ChapmanF
    18,993
    It could also have meant "around 10 volts or less", a common threshold for "completely drained" for a 12-volt lead-acid battery.
  5. dolj
    dolj Senior Member
    8,635
    4,389
    Understood, but that is not what I was going for. I was intrigued by the battery draining when it was not connected to the car—if that's what happened. Hence the quest for clarification.
  6. PriusCamper
    PriusCamper Senior Member
    13,428
    5,421
    Pacific Northwest, USA
    Once you get a fully charged 12v and have checked the 12v connections to be sure they aren't loose we can help with a diagnosis. But I'm fairly certain that once that's addressed you won't have any more problems.
  7. pasadena_commut
    pasadena_commut Senior Member
    3,034
    942
    Southern California
    A battery cannot "drain" if there is not a complete current loop for the electrons to follow. If the negative lead is truly off the battery and that battery's open circuit voltage actually drops then the battery is toast, severely damaged (or worn) internally. The normal 24h open circuit self discharge on a working AGM battery is a tiny fraction of a volt. That's how they can sell them "charged". They are fully charged (essentially, actually loading them with fresh electrolyte is the same thing) at the factory, and then they will hold most of that charge for a year and half in storage, shipping, and sitting on the shelf at the store.
  8. PriusCamper
    13,428
    5,421
    While true, you need to fully charge a battery after you buy it prior to installing it. There's way too many folks out there who think you can install a 12v right off the shelf without making sure its charged first and that annoys me every time I hear it.
  9. pasadena_commut
    3,034
    942
    Southern California
    Agreed. While the battery is still usable at a year it may only be charged to 12.2 volts, or something like that. Automotive charging systems, at least these days, are much better at maintaining voltage than at recharging a battery. So it is better to charge it up with a dedicated charging device before installation. Unfortunately a lot of people don't own one of these, and if they have the work done at a shop they aren't going to take the time, so the battery usually goes in at the lower voltage and the car will take a while to get the battery up to a full charge.
    One other reason to charge it up first. Most modern chargers will detect if a battery is really screwed up and turn on a red LED or something similar. If that happens, take the battery right back to where it was purchased and try again. The same bad battery installed in a car might damage the charging system. Having a car fail this way is probably a very rare event, but with tens of millions of batteries being installed each year, it must happen.
    PriusCamper likes this.
  10. bisco
    52,807
    You’re up
  11. ebikeman
    ebikeman Member
    121
    Northwest
    Make sure when you press the power button
    If you push the button to shut off the car and it doesn't shut off, maybe it's the button? You can replace it very easy. If it's not shut off, sitting on may drain the battery?
    ebm
  12. Kitty500
    Wisconsin
    I found out that the issue was the combination meter. I replaced the 100 UF capacitor on the meter with a 220 UF capacitor. Now the car works fine but when I turn the car on, it’s in maintenance mode. I get the red triangle with! No other lights. Is there somewhere I can have this board tested to make sure it’s nothing that I did.
  13. dolj
    dolj Senior Member
    8,635
    4,389
    That is not maintenance mode. The red triangle with the '!' in the middle is the master warning light (MWL) and indicates there is a hybrid system diagnostic trouble code (DTC) that you need to read to find out what the car wants to tell you. You need a capable scanner that can read all the ECUs (12-15) and, in particular, the HV Control ECU. Having a capable scanner avoids the 'I scanned the car, but there were no codes' scenario.
    If you don't have a scanner, you might try an auto-parts store that offers free scanning, although you have to bear in mind that not all stores have capable scanners.
    If you want a little more autonomy and control over diagnosing your car, read the first couple of posts in this wiki article and then skip to post #37 to understand what's available that can do the job. Note that the Autel AP2500 is not the same as the Autel AP200, if that's the one you land on.
