Car for Mexico?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by coolredmudball, Mar 20, 2016.
  1. coolredmudball
    coolredmudball New Member
    Oregon
    I'm thinking of buying a new Prius but I thought I'd come here for some feedback first. We drive to Mexico each winter from Oregon. We currently drive. 2002 Rav4 which has a road clearance of 6.3 inches. This is just about right for the Mexican speedbumps (topes) which seem to be eberywhere. The Prius has only 5.3 inches. Is there a way to raise the Prius e.g larger tires or raising the suspension? Would this mess with the odometer/speedometer or anything else? Also are the rear seats removable to create a larger cargo area? And finally, does it come with or is there a factory roof rack available? Thanks in advance.
  2. JC91006
    16,936
    8,647
    A Rav 4 would fit your needs more than a Prius. They are coming out with a Rav4 Hybrid (maybe already out)
  3. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I think you'd be just fine. Each time we've gone to Mexico, it seems like the most common vehicles were the classic-style VW Beetle and the Nissan Tsuru (earlier-gen Sentra) along with a number of Corollas. You can cross the topez at a tiny bit of an angle if it makes you feel more comfortable. I wouldn't go through the trouble of trying to increase the ride height.
    The Prius rear seat folds flat for excellent cargo versatility.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If you raise the suspension, expect the aerodynamics (and MPG) to suffer. Larger tires would indeed alter the speedometer/odometer.
    Stock the rear seat fold flat (60/40) and hold quite a lot. if you removed them it would hold more but you would lose the flat load floor.
    Four 8 gallon tubs and a 17 foot extension ladder in a stock gen 2 with seating for 3.
    And again, if you get an aftermarket roof rack, expect the aerodynamics (and MPG) to suffer.
    Toyota RAV4 - 2016 Models: RAV4 Base, RAV4 Sport & RAV4 Limited
    Starbrand likes this.
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
  6. bisco
    52,834
    welcome! why not consider a mexican car that's designed for the terrain?
