Car Full of Water Underneath Carpet - How to Clean?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Friendlyx, Feb 2, 2019.
  1. Mendel Leisk
    41,486
    Trouble shoot the smoking gun with the smoke machine? Hey, it was too much to resist.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    At least there wasn’t smoke coming out of your ears cause you thought about it too hard:p.
    I’ll take the grooved softballs from time to time too(y).
  3. Pdaddy
    Pdaddy Member
    160
    49
    I had a leak from a disconnected AC hose. It took about 2 weeks to find out what the source of the smell was when I noticed something placed on the rear floor was damp. The carpet has a platicized backing so it holds back a lot of the water from seeping through.
    I took out all the flooring, cleaned with hose, detergent, and scrub brush and then disinfected the carpet and padding with a fungicidal disinfectant. Wiped down the metal car floor as well.
    I would be careful with chlorine and ozone based products as they can discolor vinyl. There is a hydroxyl generator that you may be able to rent that does not discolor but takes a day longer to treat in a closed environment like your car. I would place the carpet a pad back in the car and flip them around after a day with 2 day treatment. Still should wash and dry them first. 20190206_114109.jpeg
    SM-G920V ?
