Car hasn’t started in a year. All lights on.
Discussion in 'Gen 2 Prius Technical Discussion' started by dirt657, Jan 7, 2019.
  1. JC91006
    16,936
    8,647
    That reading should be taken when the battery has rested 10+ hours.
    But 12.4v would mean it's good
  2. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Right. I heard the dude above say 1 hour. But I’ll do it again tomorrow
  3. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    4 days later, the 12v is fine. I have a driven it around some more. One of the ABS codes is gone. Lights that are on: Maintenance required, TPMS, CEL, VSC, ABS, and now the monitor is saying that it's 36 degrees outside when its really 60 degrees.
    Code are p0138 and C0205 which is O2 sensor 1 bank 2 high voltage and left front wheel speed sensor signal malfunction, respectively. I recharged the hybrid battery as well. Car runs like a scolded dog, I just want to make sure it isn't anything else before I go and get rid of those codes. I have thought about keeping this car. Even if I do and don't decide to sell it, I need to clear those lights before I go crazy!
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Maintence required is a timed mileage light you can turn off yourself. Abs and others might be the wheel speed sensor.
  5. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    What would the VSC sensor be? And does anyone have a write up for the 02 sensor?
  6. dolj
    dolj Senior Member
    8,651
    4,401
    Wellington, New Zealand
    You have mentioned in this thread and others that you "read the codes and got only Pxxxx ..." codes. I'm thinking you are not seeing the codes from all the car's computers.
    Are you using Techstream to read the codes or something else?
  7. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    I bought techstream. Needless to say, problem solved. Pretty insane what this technology can do.
    Raytheeagle likes this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    So the solution to the problem was:whistle:?
    Always good to have the resolution shared for the next guy(y).
    Skibob likes this.
  9. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    The lights were genuine. CEL is off after changing O2. Will be replacing the wheel speed sensor tomorrow I'll see if that shuts off the other 3. Then an oil change for the maintenance required light.
  10. Skibob
    2,912
    1,505
    Northern California
    Changing the oil does not turn the light off. You have to manually turn it off. See your owners manual for the details.
  11. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    I know that. Lol. I’m saying I’m going to change the oil and then turn off the light. The car needs one. I should’ve been more clear
    Skibob likes this.
  12. Skibob
    2,912
    1,505
    Northern California
    Gotcha, mine turned on yesterday. Going to turn it off Saturday when I change the oil. ;)
