car hood insulation - radiant barrier reflective foil
Discussion in 'Gen 3 Prius Accessories and Modifications' started by walter Lee, Nov 18, 2011.
  1. walter Lee
    1,126
    376
    Maryland
    Has anyone experimented with adding additional insulation under the Prius' hood? More specifically, has anyone installed any kind of Radiant Barrier Reflective Foil insulation (with the primary objective to speed up the warm up cycle and keep the gasoline engine warm during the winter ) underneath the Prius' car hood like the ones sold by koolmat[1] or Amazon[2] or Ebay[3]?
    [1] Motor Armor Foil Insulation
    [2] http://www.amazon.com/HEAT-SOUND-Shield-INSULATION-BLANKET/dp/B001AX87A6
    [3] ARMA FOIL Radiant Barrier Reflective Insulation, 500sf | eBay
  2. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    MrHJ5 likes this.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The nice thing with the prius (gIII) is you wouldn't have to worry about as many moving parts (e.g. belts).
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I did at one time, It may help the ICE stay a bit warmer during long glides and ICE off periods, but honestly since removing mine (it fell off where I had it stapled on the underside of the hood), I can't tell any measureable difference.
