Car in neutral while running
Discussion in 'Gen 2 Prius Technical Discussion' started by DWJM2513, Jan 12, 2019.
  1. DWJM2513
    DWJM2513 Junior Member
    64
    24
    US
    I don't know much about these CVT transmissions but is it okay to set the parking brake and put the transmission in neutral just to keep the engine running for heat in the winter?
    SM-N960U ?
    52,773
    no, you'll kill the battery. just press park
    #2 bisco, Jan 12, 2019
  3. JC91006
    16,933
    8,643
    Why do you need to put it in neutral? Can't you just leave it in park?
    The HV battery does not charge in neutral
    Tyfly and Mendel Leisk like this.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You would be better off in park. The Prius cannot charge the big battery in N, and it is nontrivial to find a charger if you run it down.
    WilDavis likes this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    You are fooling yourself.
    N is there for towing ONLY.....and pushing when EVERYTHING is dead.
    Either D or P would be better, since theoretically the engine NEVER runs in N.
  6. DWJM2513
    64
    24
    US
    Actually it does. It will stay running in N and will shut off when I put it in Park
    SM-N960U ?
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Can't stress it enough -- do NOT leave it in neutral. Put it in park so the engine can charge the traction battery as needed.
    Skibob and WilDavis like this.
  8. ChapmanF
    18,955
    a rare moment of PriusChat unanimity
    Tyfly, TomB985, RRxing and 4 others like this.
  9. bisco
    52,773
    give it time :cool:
    m.wynn, jerrymildred and WilDavis like this.
  10. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …I seem to remember someone else saying the same about the current Cirque du Washington! :whistle::whistle::rolleyes:;)
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It's complex.
    The engine can neither start or stop in N. So if it is already running, it can't stop and does not charge the big battery, it just produces hot water.
    If it is not running when you put it in N, it will stay off and the HV Battery will run down.
    In the US, Toyota is required by law to have an N mode. You just never want to use it.*
    *If you want to test your friction brakes, you might use N. If you want to make it about 75% of the way through a car wash that pulls your car, you could start in N, the car wash owner will not be happy. The other users will not be happy. You will not be happy.
  12. bisco
    52,773
    prius will produce heat in 'park', with the engine starting and stopping to maintain water temp.
    Raytheeagle and m.wynn like this.
  13. landspeed
    landspeed Active Member
    387
    210
    NZ
    2003 Prius
    It has been said, but : If you leave it in neutral, the high-voltage battery *cannot* be charged. If the car is powered up, the high-voltage battery will discharge to keep all the computers running etc.
    Once it is discharged, you need to get the car trailered to a Toyota dealer. Give the dealer advance warning, as they need to, in advance, get one of the few chargers in the country couriered out to them. They can then charge your HV battery up. It will cost a lot of time, also money.
    Please heed the advice of the people above. If you need heat, leave it in 'Park', with engine running (or not). Apply 'footbrake' / 'parking brake'. It will even be more economical, as the engine will stop/ start based upon the need for hot air from the heaters.
  14. fuzzy1
    10,687
    N is for towing a Prius? Where did this delusion come from?
    A Prius should be towed only with the front wheels off the ground. When the car is dead, it is automatically in Park, and it takes very special actions to disengage that Park pawl. But even then, it mustn't be towed with the wheels on the ground, unless one intends to cause transaxle or engine damage.
    Skibob, m.wynn and jerrymildred like this.
  15. DWJM2513
    64
    24
    US
    True, but if the engine works like it should, it'll pump the water through the radiator while running to cool the engine just as if it was a regular car engine running all the time
    SM-N960U ?
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    While I am not an expert, from everything I've seen discussed that sounds like a major problem.
    There is no practical reason for the engine to run in Neutral.
    (edit) Except for a design "quirk" that has been explained, causing it to stay ON if it already is running when the shift to N is made.
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    So.....what IS the recommended procedure for properly going through a car wash like that ??
    I have been just switching to N and getting away with it. Just lucky, I guess.
    Rickyedger and WilDavis like this.
  18. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    This is exactly why you should leave it in Park. If you absolutely need as much heat as possible, set the temperature to max with the car in Park, and the car will handle when it needs to turn the engine on or off. Or if you want a specific temperature, set the thermostat to that temp and your engine will run even less.
  19. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Or the battery in the C copes better than the Battery in the Gen 2?
    My advice is to not use car washes that want you in N.
  20. sam spade 2
    7,035
    2,804
    2017 Prius c
    Gee thanks, that really helps a LOT.......since most all of them near me work that way.
