Car knocks When Changing Mg2 to ICE in a hill
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by san, Nov 28, 2016.
  1. Mendel Leisk
    42,323
    Check 12 volt with car off, with digital multimeter.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    My only concern with cleaning in place is where does the stuff go that you use to clean and deposits removed? Unfortunate answer is to the oxygen sensors and cat. A couple of expensive items, but it is easier than removal I guess.
    m.wynn likes this.
  3. san
    san Junior Member
    24
    Sri Lanka , Colombo
    I also thought the same thing and asked them, they said it goes out with exhaust .they done this way because easier for them.but they done good cleaning with egr valve egr pipe and manifold.now i'm concerning about the HV battery how it went bad suddenly at 135000km.and why it happened after changing 12v battery.
    #43 san, Dec 2, 2016
  4. san
    san Junior Member
    24
    Sri Lanka , Colombo
    Car off 13.4v.when car on hybrid system running engine running 14.8v-14.9v
  5. bisco
    52,819
    no, they work the same. there's a surface charge on the battery when you shut down, what the voltage after everything has been off for several hours?
  6. san
    san Junior Member
    24
    Sri Lanka , Colombo
    Yesterday i put a New Hybrid Battery ,actually slighty used one( Year 2014. year of the battery can identify from the sticker with serial number ,12th & the 13th number of serial no displays year of the battery & car .on relays also mentioned year) from japan.so far no problem.runs well.fuel Economy average also improved.thanks everyone for all the tecnical opinions & suggestions.
  7. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Glad to help. All the best(y)!
    san likes this.
  8. Mendel Leisk
    42,323
    Huh, just like that. (y)
    Did you do it yourself?
  9. san
    san Junior Member
    24
    Sri Lanka , Colombo
    No,Hybrid maintainace center changed the battery.it took only one hour.
    #49 san, Dec 10, 2016
  10. Mendel Leisk
    42,323
    Here (North America) some dealerships are charging $1000~1200 labour to do this. :mad:
