Car locks on it's own 30 seconds after unlocking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gutsy, Mar 13, 2013.
  1. Gutsy
    Gutsy Junior Member
    30
    Yardville, New Jersey
    I'm hoping someone can help me. I have a 2008 Prius (I am the original owner) and all was well this morning when I went to work (12 mile trip). I went to the car at noon for lunch and the car door wouldn't open when I touched the door handle, nor when I pressed the unlock button on the fob, so I used my key to get in. The car also wouldn't start, so I inserted my fob in the slot to get it started. I arrived at my destinationand locked the car. When returning to my car, the car door unlocked automatically this time when touching the handle, but I couldn't start the car so I inserted the fob in the slot.
    When I got home I replaced the battery in the fob and now the car recognizes the fob and the doors open automatically ... but now, after clicking the fob to Unlock the door ... just 30 seconds later, the doors lock by themselves automatically. At the time my wife was 12 miles away with the 2nd fob. When my wife returned, I used her fob to unlock the door, and it again locked on it's own again after 30 seconds (I timed it). So I decided to remove the new battery from my fob (in case the button was stuck), and I then used her fob and again ... the car locked on it's own again, 30 seconds later. I rarely use the fob buttons to lock and unlock the car.
    Any ideas? The car has 54,000 on it and this is the fiorst time this has happened.
    Thanks in advance for your help or advice.
  2. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    Actually I think you'll find this is correct behavior - if you unlock the doors using the remote but don't open anything they will relock themselves after 30 seconds for security. In the Gen 3 I think that changed to 1 minute (by default, but is dealer-programmable to different timeout values), but it still relocks if you don't open a door or the hatch in time.
  3. Gutsy
    Gutsy Junior Member
    30
    Thank you Wlterm. I never realized that was the case. I don't believe I ever unlocked the car without opening the door to realize that it automatically locks after 30 seconds. Thanks for getting back to me.
  4. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    A few times, I unlocked the Prius with the key FOB inside my house and went out to the car to get something only to find out its still locked :mad:
    This all makes sense now - I took too long to get outside after unlocking Prius and not opening it, so it relocked. I thought I was going crazy (which still might be true but at least I know I can scratch this off the list) lol. :D
  5. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I always press the unlock button on the arm rest as I get out of my 2004 Prius after parking in my garage. Then when I go back to it, the car is still unlocked.
    JeffD
  6. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I don't know about Gen 2, but I was able to have my car programmed to not do this (though it took the dealer half an hour to acknowledge that it was actually possible).
  7. Rocket Man
    Rocket Man Junior Member
    38
    Denver
    The 30 second re-lock function is a common feature in Toyota products. I believe the thinking is: what if the car is accidentally unlocked (by whatever means)?
  8. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Yep, the behavior is by design. It won't auto-relock itself if a door is opened before the auto-lock timeout.
    It should be mentioned in the manual somewhere.
