Car misfiring and shaking after going to the store
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fart, Jul 28, 2022.
  1. Fart
    Fart Junior Member
    I went to a grocery store and went shopping for about 20 minutes. When I got back to my car and started it up it started to misfire and sounded like a thrown rod. The car was vibrating like crazy and I recorded it on my phone to demonstrate the behavior.
    This has happened before and I took it to the dealership and they suspected it was spark plugs since they are the original plugs, (90k miles). I didn't get the car diagnosed because the issue went away when I brought it to the dealership--so I drove home. With that said I replaced the spark plugs and noticed oil on the threads. I replaced the plugs and ordered a valve cover gasket which I was planning on installing this weekend. I originally suspected the oil was causing this misfire.
    3 weeks later, today, l encountered the issue again so I recorded a video! I noticed the check engine light will flash and then turn off and when the car cools down and the check engine light goes out and the car runs like normal.
    It would seem like a component is failing but I don't know what the issue is. Does anyone have advice?
    Here's the video I recorded today:
  2. JC91006
    16,477
    8,394
    How many miles are on your car? If you're lucky (I mean you have to be really lucky here), all you have is a problem with the coil or spark plugs. If you're unlucky (which is what most of every 3rd gen Prius owner) you have a head gasket failure coming. Are you losing any coolant?
    If you're not losing any coolant, you may still be able to avoid this catastrophic failure. Try cleaning the intake manifold and EGR Circuit and see if the problem goes away. These 2 areas get clogged with Carbon and heats up the car, leading to head gasket failure.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,431
    1,485
    NJ-USA
    What year is your Prius? Do you have any means to scan the Engine Control Module for codes? Being able to read codes would help direct you to which cylinder the ECM thinks is misfiring.
    In order to have combustion, the engine needs: air (and compression in the cylinder), the correct amount of fuel, and spark - all of these at the correct time.
    For a Gen2 Prius, the most common fault that causes misfire is ignition problems- bad spark plugs or a weak/ bad coil. There can be wiring or ECM faults that cause a miss, but not very often.
    Since you replaced the plugs, a next step would be to replace coils or to swap coils around and see if the miss follows the coil (you have to be able to read and clear codes).
    Some parts stores will read codes for you. Or you can get a bluetooth OBD adapter and app. See the sticky thread on app reviews at the top of the Gen2 Technical discussion forum. You can also use the search function to learn about Techstream- Toyota's pc based diagnostic software.
    Fuel injectors can cause problems- less common on the Gen2, and usually not intermittent. Same thing for intake vacuum leaks. And most engine problems as well. Usually if something mechanical breaks enough to cause a miss, it will stay broken.
  4. Fart
    Fart Junior Member
    The car is a 2nd gen with 90k miles. Also I researched that there isn't a physical EGR valve in the car. I was reading that the EGR is set digitally by the ECM.
    I'm facing issues scanning the code because the check engine light goes out and completely disappears. I don't know if I can view history codes but I don't have a scan tool. If there's not active codes would the part stores still be able to read the codes?
  5. bisco
    49,384
    it does sound like a head gasket, because replacing the plugs sometimes solves the problem until they get fouled again.
    90k shouldn't really present any problems on the whole. does she burn any oil?
  6. Fart
    Fart Junior Member
    No oil burning yet and no coolant loss
  7. bisco
    49,384
    you can try an auto parts store for reading the codes and post here, but sometimes their code readers aren't specific enough for a prius.
  8. JC91006
    16,477
    8,394
    2nd Gen car, you are most likely dealing with bad plugs and coils. Since you are only needing a valve cover gasket, you should just do that and clean up the plugs again.
    Fart likes this.
  9. mr_guy_mann
    3,431
    1,485
    NJ-USA
    You might want to consider getting some type of scantool. It can be really useful when trying to repair things yourself.
    You can use the search function to learn about Techstream (Toyota's pc based diagnostic software). Or look at the sticky thread at the top of the Gen2 Technical discussion forum to read reviews about several apps and Bluetooth OBD devices.
  10. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    did you check the PCV when you changed the plugs? That’s the time to do it but if not, may want to check it now and see if it has oil on it or is even working.
  11. Fart
    Fart Junior Member
    I did the valve cover gasket today and ordered some coils yesterday. I used the great FIPG instead of the RTV since I want to do this right. I did wait a few hours and did a test run to see if the car would have the same misfire. Unfortunately after changing the plugs and the valve cover gasket the misfire did showup today after I went to the market again. It starts fine but intermittently does not like starting hot. I'm hoping the coils fix it otherwise the next thing to check would be the injectors I suppose.
    I reviewed the thread you posted and saw inspiration in the Autel MaxiAP AP200! I ordered one and it should be here tomorrow.
    Yes. When I changed the plugs I also swapped out the PCV since it was only ~$10.
    Just an update but I've finished the valve cover gasket and now the total changes are:
    1. New oem sparkplugs
    2. New oem PCV valve
    3. New oem valve cover gasket
    4. Cleaned the MAF and throttle body
    Bonus: Ordered the Autel MaxiAP AP 200 scan tool
    After waiting for the FIPG to dry for 3 hours I went to the market to see if I would have the same issue and unfortunately the issue still remains. This time I put the coils in a different order and I noticed the misfiring disappeared faster this time.
    I have new oem coils coming in the mail from my local dealer and they should be here Tuesday. In the meantime I can only suspect the fuel injectors may have some kinda issue next. Before I load up the parts cannon I'm hoping the scan tool comes soon so I can see what the historic codes are and get a better idea why the car is acting this way.
    - Fart
    #11 Fart, Jul 31, 2022
  12. mr_guy_mann
    3,431
    1,485
    NJ-USA
    I would expect that you have some kind of P030x misfire code (P0301 for cylinder 1, etc). A test would be to write down the code, clear it, then mark and swap coils around (1 with 2, 3 with 4, or whatever). Drive the car and see if the miss stays on the same cylinder or follows one of the coils.
    Or, if the new coils arrive soon, just put them in and see how it goes.
  13. JC91006
    16,477
    8,394
    You may not need to have new coils, just swap the misfiring cylinder coil to another cylinder to test. If you determine it's not the coil, then don't buy new ones.
    I would look at your injectors next, that has been a weak point for the gen 2 at higher mileage. If you follow the repair manual, it'll direct you the next steps to diagnose
  14. Another
    1,802
    511
    Naples, Florida
    What did the old PCV look like? Any oil or carbon deposits? Was it still functioning?
  15. Fart
    Fart Junior Member
    So the Autel scan tool came in and I have pending codes from the hot start. I have a P0300 which is a random/multiple cylinder misfire and the suspects are Cylinder 2,3 and 4. I wonder if when the vehicle is sitting after it was running something floods these cylinders. The issue goes away after the car runs so something must be flooding the cylinder or the drive cycle on a hot start is different from a cold start.
    Either way the issue is easily repeatable by hot starting the car. On Tuesday when the coils come in I will check again. I can't help but think maybe there is actually something serious going on. It would seem like something is flooding the cylinders while parked. I do not know if I should take it to the stealership as I am not the most skilled and the parts cannon is running out of parts.
    I did see a write up of someone taking out the fuel rail without removing the valve cover. I don't really want to remove the valve cover as I just did the valve cover gasket.
    The old PCV looked good still rattled there was oil and some carbon deposits on the outside but it was still functional.
  16. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Swapped injectors like that once, and it took a a number of tries before I was able seat all of them without leaking, pissing gas on each start up. You can't insert the injectors evenly at the same time because of the valve cover restricting the fuel line. Needless to say the process was fun in the moment, and only add extra time to the job. I wasn't giving up, and the spewing fuel cleaned up the sandy exterior of the intake.
    If I did it again, I might consider notching part of the protective loop that restricts the fuel line, and the job would be far easier and quicker.
  17. Fart
    Fart Junior Member
    Did you buy all new OEM injectors or did you get them cleaned by Rich?
    Injectors from my dealership near me are $134 each. I did a quick ebay search and found some interesting things: https://www.ebay.com/itm/403578803740 for only $50.00 you can get FOUR. This seems like a fake/cloned part since the dealership is $194.58 MSRP for one injector.
    Then here's this guide which links to this: https://www.ebay.com/itm/121312381714 which are remans which seem legit. The guy who made the guide had good results.
    Both claim OEM one being reman but I wonder what I can do because it doesn't really feel good to spend $500.00 on more parts. Maybe the remans can fix the issue temporarily and then I will know for certain what to parts cannon next time.
    The part that makes me not trust is their "oem" part number. I can clearly look it up on Toyota and it says the part number is this:
    Part Number: 2320921020
    Supersession(s): 23209-21020
    Yet the part number 23250-21020 does not show up in the Toyota database. I can't find a clear manufacturer but I'm assuming it's from China and not Japan. 23250-21020 23250-21040 23250-21060 Fuel nozzle Injector for Toyota LEXUS - IBUYautoparts.com
    #17 Fart, Aug 2, 2022
  18. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Fart likes this.
  19. Fart
    Fart Junior Member
    Just an update I changed the coils and none of them looked bad. I tried to create the issue and all was well for a few days but on a hotter day I was able to reproduce the issue.
    While I waited for the coils to arrive I preemptively ordered the ebay reman injectors from Atlanta Auto. Today I did the fuel injector procedure and while removing the old injectors I noticed they were not OEM and instead were some remans as well! It was quite a shock because I planned on the injectors already being OEM so I could get them professionally cleaned by Chuck.
    Now that I don't have OEM injectors I'm not going to clean the old ones. These are basically junk to me.
    Picture for reference: https://i.imgur.com/vyJlLxT.jpg
    Looks like whoever did this job before used silicone grease instead of oil or gasoline. I used oil this time since I didn't have a can of gas laying around.
    I decided to measure the resistance of the old injectors just because and 3 out of 4 were in the range of 14.6-14.9 ohms. The heavily silicone covered injector had a resistance of 27.3 ohms! This seems unusual and perhaps was why the fuel injector was failing under higher temperatures.
    The re-manufactured injectors I just put in all had readings of 14.9 ohms so lets see how long that lasts.
    The manual says:
    If I encounter issues with the injectors I might just buy OEM injectors.
    To close the issue for now the total parts cannon consisted of:
    • new OEM spark plugs
    • new OEM coils
    • new OEM PCV valve.
    • re-manufactured injectors
    The cleaning list was only MAF and throttle body
    Thanks everyone for the help!
    #19 Fart, Aug 7, 2022
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Start thinking about what your going to do when your hybrid battery fails. You have a very low mileage car that’s not good for the hybrid battery,
    There all failing on a G2 it’s just age.
    Your mileage is probably poor.
    You live in Ca how many times has your catalytic converter been stolen?
