Misfire code won't rev over 2500 rpm
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Robert Couchman, Feb 12, 2019.
  1. Robert Couchman
    Robert Couchman Junior Member
    This is a 2005 with 278k on the clock, new plugs in the last 500miles (NGKs) my wife started her commute to work the other day had to limp home at low speed. Pulled the codes (Torque Pro OBD!!) PS302 was the only error code, switched coil packs between cyl 2 and 3 no change same error code. I have never done the EGR maintenance, wonder if that might be useful. Here are the test outputs:
    Mode $06 report generated by Torque for Android
    Thanks in advance for any light you can shed on this:)
    Vehicle VIN: Not present
    Vehicle Manufacturer: Unknown
    Vehicle Calibration ID: 34705200
    Test report:
    MID:$01 TID:$8e
    - O2 Bank 1 Sensor 1
    Max: 7.99527 Min: 0
    Test result value: 1.12911
    PASS
    MID:$02 TID:$07
    Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
    Max: 0.233V Min: 0V
    Test result value: 0.135V
    PASS
    MID:$02 TID:$08
    Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
    Max: 65.535V Min: 0.605V
    Test result value: 0.855V
    PASS
    MID:$02 TID:$8f
    Max: 1.19895 Min: 0
    Test result value: 0.23363
    PASS
    MID:$21 TID:$a9
    - Catalyst Monitor Bank 1
    Max: 9.99393 Min: 0.1098
    Test result value: 0.2504
    PASS
    MID:$3b TID:$c1
    - EVAP Monitor (0.090")
    Max: 0.182kPa Min: 0.001kPa
    Test result value: 0.006kPa
    PASS
    MID:$3c TID:$c2
    - EVAP Monitor (0.040")
    Test incomplete or dependant test failed
    MID:$3d TID:$c7
    - EVAP Monitor (0.020")
    Max: 3.8S Min: 0S
    Test result value: 0S
    PASS
    MID:$3d TID:$c8
    Max: -0.294kPa Min: -32.768kPa
    Test result value: -1.905kPa
    PASS
    MID:$3d TID:$d4
    Max: 32.767kPa Min: 0.927kPa
    Test result value: 2.319kPa
    PASS
    MID:$3d TID:$d5
    Max: 3.9S Min: 0S
    PASS
    MID:$3d TID:$d6
    Max: 327.66998 Min: -4.11
    Test result value: 0.97
    PASS
    MID:$a1 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Monitor General Data
    Max: 65,535Count Min: 0Count
    Test result value: 352Count
    PASS
    MID:$a1 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Monitor General Data
    Test result value: 9Count
    PASS
    MID:$a2 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
    Test result value: 0Count
    PASS
    MID:$a2 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
    Test result value: 5Count
    PASS
    MID:$a3 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
    Test result value: 349Count
    PASS
    MID:$a3 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
    Test result value: 1Count
    PASS
    MID:$a4 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
    PASS
    MID:$a4 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
    Test result value: 3Count
    PASS
    MID:$a5 TID:$0b
    EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
    PASS
    MID:$a5 TID:$0c
    Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
    PASS
    End of report.
  2. JC91006
    16,933
    8,643
    Maybe the plugs are not torqued down? You can try putting the old plugs back in and see if things change
  3. Robert Couchman
    I torqued the new plugs and ran several hundred miles after they were installed, so I am confident it is not the issue. Thanks for your reply
  4. Patrick Wong
    18,210
    6,517
    G2 does not have an EGR system.
  5. JC91006
    16,933
    8,643
    If you get this error after you change your plugs, that is where I would investigate first. By taking out that plug that's misfiring
  6. Robert Couchman
    Thanks!
  7. Robert Couchman
    removed plugs 2 and 3 (the misfiring one is the lean one on the right, the left one is rich I suspect because I previously had switched coil packs to isolate the problem and only ran the ICE for a minute. i am thinking maybe a bad injector? prius plugs.jpg
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Welcome to PriusChat!!
    If the COPS are good (no visual carbon tracking), and given the DTC and the swap you've reported (P0302), my 'WAG' is you need to service/replace the injectors with used ($25 for four), or new ($$$), or send off your current set to be tested and cleaned ($60+).
  9. Robert Couchman
    Thanks,
    Can you recommend a resource for used replacement or rebuilding?
    best,
  10. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    I picked up a rebuilt (used) set on ebay for $23 including shipping, they were mismatched and one of the intake o-ring retaining caps appeared to be slightly cocked/angled. But after talking to someone on the phone, I have no doubt they would've replaced one or more if it was required. The seller was a yard in the Los Angeles valley, the injectors appeared to be clean/rebuilt with new rubbers/seals etc. They worked after installation, though I also checked the resistance before install.
    Here is a link to 'AtlantaAuto' / ebay store:
    Atlanta Auto Dismantling - Auto Parts & Supplies - 7259 Fulton Ave, Valley Glen, North Hollywood, CA - Phone Number - Yelp
    Atlanta Auto | eBay Stores
    There are also New 'non-denso' (chinese) offerings for similar pricing, which may work given the light duty application. But from what I've read elsewhere some of the higher CC versions can fail to deliver fuel at greater duty cycles, which causes a lean burn and damages the engine at best. Would be interesting to see how a new set of (4) four injectors for under $30 performs.
    Here are a some places I've previously bookmarked for reconditioning, some do charge for return shipping though :
    http://fuelinjectorspecialists.com (website is down, this is who I considered using as they include pics with their report)
    Fuel Injector Specialists LLC in Wheat Ridge, CO - (303) 456-0789 - Chuck is/was the owner.
    You can read some of the old website here : fuelinjectorspecialists.com - Fuel Injector Specialists - Home - Wheat Ridge, CO
    Fuel Injector Cleaning and Flow Testing- Fuel Injector Service Utah, Salt Lake City, 84115
    Injector-Rehab Fuel Injector Cleaning Services
    Fuel Injector Cleaning and Flow Testing Service. Injector Repair LLC
    Ultrasonic Fuel Injector Cleaning Service - InjectorExperts.com
    Fuel Injector Cleaning and flow testing service, refurbish reconditioning
    Fuel Injector Clinic
    Fuel Injector Service -- Pro Flow | Ultrasonic fuel injector cleaning and flow testing specialists
    Please update if you use one of the above services. Would be interested in seeing the before and after flow rates after 278k.
    Raytheeagle and JC91006 like this.
  11. Robert Couchman
    Thanks for the extensive reply, as it turns out I ordered a set of injectors from AtlantaAuto ($26.28 wi shipping for 4 reman injectors)
    SFO likes this.
