Car not charged at set departure time?
Discussion in 'Prime Technical Discussion' started by Hydrocket, Oct 26, 2020.
  1. Hydrocket
    Hydrocket Member
    79
    39
    CA
    Technology
    Post 17 seems to disagree, as their experience mirrors mine..except they're on level 2.
  2. hill
    9,014
    wishful thinking, but if (while charging) climate control prepping for departure could simply be heated seats & steering wheel, that would pretty much do the trick - for many.
    That stinking 2011 leaf - the resistance heater could pull almost 5KW (in drive mode) - while the on board charger was limited to only 3.6KW.
    #22 hill, Oct 29, 2020
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Depends on one's settings. Set the interior temp too high and even L2 may not be able to make it up in time as they can only give what the car will accept (typically 3.3kw rate for most PHEV's). Like Hill said above, most resistance heaters can pull 5kw when working hard; add in the fan, all the on board electronics, electrical converters, line losses, etc., and the next thing you know demand outstrips supply.
    AldoON likes this.
  4. hill
    9,014
    On plugins that have it, watching the liquid cooling activate when a battery is warm while charging, the system's cooling - fans - circulation - pump will intermittently operate and even after charging is complete will cycle back on to make sure optimum battery temperature is maintained for better traction pack life expectancy.
  5. AldoON
    AldoON Member
    108
    Milton, ON
    2018 Prius Prime
    Upgrade
    Next time I'll try a lower temperature for pre conditioning, maybe 19 C. I assume that even if the battery is not quite at 100%, is still a net savings vs not pre heating...
