Car not charging?!?
Discussion in 'Prime Main Forum (2017-2022)' started by JMalmsteen, Sep 23, 2017.
  1. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    We ordered a charging cable and for the first time tried to plug the Prime into our garage. I'm going to let my husband type this since he was the one who was attempting to get this to work:
    We purchases a 100ft 12AGW GFCI extension cord. After about 10 to 15 seconds, the GFCI trips. Any advice would be helpful. Thanks.
    #1 JMalmsteen, Sep 23, 2017
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    It sounds like you are using a GFCI breaker.
    When the Prius takes a moment to sense if power is available. When it does sense that power is available it draws power. When it draws power, it is such a sudden draw that it trips the GFCI.
    If you used a non-GFCI outlet with a regular 20-amp breaker it should work fine. [mine does]
    JMalmsteen likes this.
  3. JMalmsteen
    287
    266
    The GFCI is part of the cord. If I reduce the car to pulling only 8amps, would that stop the GFCI from tripping?
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Neither rate of change of current nor total current draw should have anything to do with a GFCI tripping. A GFCI trips when hot and neutral currents don't add up to zero meaning current is leaking to ground through some other path.
    priuscatprimeguy and JMalmsteen like this.
  5. JMalmsteen
    287
    266
    I tried 3 different outlets. Is it possible that the extension cord is bad or the GFCI is bad?
    #5 JMalmsteen, Sep 23, 2017
  6. Alan Winston
    Alan Winston Junior Member
    38
    30
    Seattle
    Why 100'? That's awfully long - if at all possible, I would go with a shorter length.
    Is any part of the cord coiled up? If so, try serpentining the excess cord instead, with the cord never crossing itself, or lying adjacent to itself. You may be getting inductive coupling between the conductors and the ground line sufficient to throw the ground fault interrupter.
  7. Salamander_King
    Salamander_King Senior Member
    11,024
    8,972
    New England
    Alan beat me to it. Why 100 ft extension cord? You said you are charging in your garage. Isn't your car also in the garage? Also, not related to your question, whay you mean by "ordered a charging cable" means the extension cord you are using? A charging cable should have come with the car.
  8. JMalmsteen
    287
    266
    I will try that. We got a 100 because of the distance from the house to the driveway. Thanks =)
  9. JMalmsteen
    287
    266
    My husband is trying to hook the car up again- the 100 feet is for an extension cord. My vette is in the garage, we have a bunch of motorcycles and my vette in the garage, it's a 1.5 car garage that's a barn, but only room for one car even though there are lots of rooms attached and a full size loft area, if that makes any sense. We have the Prime next to the garage and the extension cable is going out one of the windows and running to the side of the barn/garage. The vette can't go on the street or next to the house, in my infinite wisdom, I bought the nicest corvette that Chevy is making right now, something you don't want to leave outside, so I can't have the vette outside and the Prime inside.
    -JEN
    Salamander_King likes this.
  10. Salamander_King
    11,024
    8,972
    New England
    I got it. :) Can you bring Prime close enough to any outlet so you don't have to use the extension cord. If that works, then at least you know problem is not the car or charging cord. I don't think GFCI is bad inherently. I connect my Prime on a GFCI outlet on side of my house, and have not had any problem. I also have used extension cord to connect my charger cord through inside house, this also worked fine, but I don't do it anymore for fear of overheating extention cord.
    #10 Salamander_King, Sep 23, 2017
  11. ForestBeekeeper
    780
    310
    Maine
    GFCI breakers are designed to be touchy. I have seen them on occasion to be very touchy.
    My garage is wired with a regular 20-amp breaker [no GFCI].
    I am prone to suspect a bad GFCI.
  12. Alan Winston
    38
    30
    Seattle
    At the earliest opportunity, get an electrician to run a 120/20 dedicated circuit & outdoor outlet to where the Prime will park, if at all possible so charging can be done without any extension cord at all.
    While he is doing that have 240/50 wiring run to the same place, even if it is not connected up to the electrical panel or an outlet at this time - it will save you a lot of hassle later on, when you get your next car, or if you decide faster charging of the Prime would be nice.
  13. Lee Jay
    5,850
    4,036
    Yes to both.
  14. JMalmsteen
    287
    266
    I would have to move the vette to plug in the Prime, which I'm not willing to do. I will take the vette out tomorrow and try plugging the Prime into an outlet in the garage without the extension cord, if I can do that, just to trouble shoot. I also don't want to set my huge wooden barn on fire! This is where my stuff (motorcycles and car) live. I'll also try to use the extension cord inside the house to see if that's a problem. We are in PA now. Back in NY, we don't even have a garage. The previous owners turned the garage into another living room (why I don't know, but hey). To charge in NY, I would either have to get a charging station installed or use the extension cord. We are five miles away from the Levitron headquarters though! I have gone there to charge, but almost every time there has been the same Ford whateveritis and BMW I something.
  15. JMalmsteen
    287
    266
    Bad GFCI on the cord? It's built into the cord itself. My husband spent like $130 on it and it says "Jen and Tom's cord" all over it, so I hope they would take it back, I mean, you would think they would have to if it's broken.
    UPDATE: husband just got back from the garage. He used the cord to plug into our air compressor and it didn't trip. What do you guys think??
  16. Lee Jay
    5,850
    4,036
    Need to plug the EVSE into a GFCI outlet directly, just to isolate the cause.
  17. JMalmsteen
    287
    266
    Ran it with no coils or cross overs. Still tripped. Onto the next test lol.
  18. Salamander_King
    11,024
    8,972
    New England
    You may already know tihs, but just FYI in case you have not read the manual, Toyota strictly prohibit use of an extension cord for charging. I know it doesn't help your situation, but doing so may void the warrenty if it causes any problem to your car. The manual also states to CONNECT to an outlet with GFCI.
    Here is what the manual says:
    ■Power sources precautions Observe the following precautions. If you do not follow them, fire, electrical shock or damage may occur, possibly resulting in death or serious injury.
    Connect to an AC 120 V outlet (NEMA 5-15R) with a Ground-Fault CircuitInterrupter (GFCI) and supplied by a circuit breaker per your local code. Use of a 15A individual circuit is strongly recommended.
    ●Use of a block heater for charging is prohibited.
    ●Make sure to connect the charging connector and charging inlet directly. Do not connect a converting adaptor or extension cord between the charging connector and charging inlet.
    ●Do not connect the charging cable to a multi-outlet adapter, multi-plugs, or conversion plug.
    Connecting the charging cable to an extension cord is strictly prohibited. The extension cord may overheat and does not contain a Ground-Fault Circuit-Interrupter (GFCI).
    ●Do not connect to a power strip.​
    Prodigyplace likes this.
  19. Lee Jay
    5,850
    4,036
    "The extension cord may overheat and does not contain a Ground-Fault Circuit-Interrupter (GFCI)."
    A large enough extension cord won't overheat, and you can either plug one into a GFCI-protected outlet or buy one with a built-in GFCI.
    In other words, both of Toyota's concerns can be mitigated by a simple application of a little electrical knowledge and technology.
  20. JMalmsteen
    287
    266
    That's what my husband said he wants to do, get an external outlet and not use the extension cord. In NY, I don't have a place where I could do that and plug into an outlet on the side of the house, so I will need to come up with plan b. We work in NY and I will be commuting from NY. We go to PA on weekends.
