car not coasting ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by graham hendren, Jan 13, 2013.
  1. graham hendren
    graham hendren Geeman .. taximan
    82
    NOTTINGHAM ENGLAND. UNITED KINGDOM
    it started last nite bin driving in normal mode with no probs and getting a reasonable 57mpg . now it feels like the brake is sticking you go to pull off and it wants more pedal than normal then when you get it up to speed it feels like its pulling back? then you take ya foot of the accelerater its not coasting very well just stats dropping speed instantly just feels like a brake is bliding but the e brake if that makes any sence? gen 3 1.8 59 plate 67k any one have this or know anything about it
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Since the friction brakes are used so sparingly rust can be a problem. Try putting your car in neutral when ready to brake. This will disable the HV battery and thus regen braking and force the friction brakes. This will help wipe the rotors and remove any rust, etc. Try this a few times and see if this helps.
    Claudiopi and F8L like this.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the proper Gen III forum from the Prius v forum since the OP shows he has a liftback in his profile.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Did you accidentally put the "gear selector" into B instead of D?
  5. graham hendren
    82
    no its not in b its in drive all the time . still doing it now drove 50miles and it just feels like its being held back as soon as you take off accel it just starts dropping and it feels like its in b, but its not
  6. Did you try what post 2 said?
  7. graham hendren
    82
    im just giving it ago . but the discs do look very clean
  8. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Frozen e brake?
  9. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Sounds crazy, but check your floormats are not holding the brake pedal down, the return spring is not very strong. I experienced this and only realised when the brake pedal sprung back up and slapped the sole of my shoe (non-standard mats over the proper ones).
  10. bwilson4web
    16,472
    • Is there a noticable difference decellerating shifting between "N" and "D"? - If regenerative braking is involved, shifting into "N" defeates it. But if there is no noticable change, I would check wheel alignment, brake calipers, tire inflation, bearings, and transaxle lubricant.
    • Suggestion of excessive regeneration? - The brake-light switch might need adjustment as it may signal a partial pedal depression. I would look at the regeneration bar and if small, no problem, but if it is thicker than the line it abutts, I would want to find out why.
    Regardless, please let us know what you find.
  11. It's still in warranty right?
  12. graham hendren
    82
    im not sure the service book says 60k but when i phoned up to check the service history she said the hybid parts where up 100k its going in for the 70k service soon so ill have to get them to check. the problem with these is it always need to go back to the main dealer if you do have a prob with the hybrid parts
  13. ursle
    ursle Gas miser
    1,049
    192
    NH
    I'd jack up the rear and spin the rear wheels, if they don't I'd suspect the parking brake, which I do, cycle it on and off a few times anyway, if it's not in any way related to the rear brakes I'd consider the egr valve, or, get ready... the 12v battery:), I'd also go to the dealer before an aftermarket shop for this particular problem.
  14. graham hendren
    82
    really the 12v battery ? its 3 yrs old with 67k on it
