Car powered off and won't turn back on. Was stranded on the side of the road at midnight.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AlohaSpirit, Aug 12, 2018.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,389
    3,254
    Madison, Wisconsin
    The other part I like about remivi g the headlight assembly is that is makes it less likely to spill fluid.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    JC says the pump is shorted dont plug it back in.....needs new pump...
    Bisco says no new fuse needs pump
    Then:
    I replaced the fuse and no turbulence.
    LOL... Is there something in the water that's making everyone so stupid? My head is so sore banging it on my desk reading these posts.
    bobodaclown likes this.
  3. AlohaSpirit
    AlohaSpirit Junior Member
    75
    23
    Hawaii
    No iPhone, have a galaxy
    I'm getting the pump tomorrow.
    A shop quotes $100 to install.
    (I don't have hose vice grips so its tempting)
    Yeah, I originally had it towed at 2am because it was a big piece of metal near an intersection.
    And when I towed it, the tow truck put it on a less than ideal place on the property.
    So... I replaced the fuse to be able to park it a little better... and since the car was on, and the fuse is cheap, I left it on to check turbulence. Honestly I was just happy to see it start.
    Hope that makes a little more sense.
    Thank you for your patience and understanding.
  4. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    Good deal.
    My guy charged me $350 recently and I got the pump myself off Amazon.
    Toyota dealer quoted me $750-ish for pump and install.
    As aside, I did get stranded by 7-yr old Optima 12v, in a near-by school parking lot. But I was able to finally get it started to get home and put in a new Optima. Then then inverter pump went following week.
  5. ericbecky
    4,389
    3,254
    Madison, Wisconsin
    $100 to install is a good deal.
    You can probably find the clamps at your local auto parts store ore harbor freight. ($20-$30?)
    audiodave and AlohaSpirit like this.
  6. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    Just how much will one lose by quickly removing hose, pointing/holding it up till reinstalled? Or using large vice-grips to clamp?
    My 06 had the recall pump campaign done but I want to change that one out based on time as a piece of mind preventative measure.
    AlohaSpirit likes this.
  7. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
  8. AlohaSpirit
    75
    23
    Hawaii
    Yikes. Glad you got it home tho
  9. ericbecky
    4,389
    3,254
    Madison, Wisconsin
    I hate those plastic clamps.
    I prefer metal ones.
    ITBland likes this.
  10. AlohaSpirit
    75
    23
    Hawaii
    Got the replacement and installed.
    There is water turbulence in the coolant reservoir when car is on.
    Thanks again for all the help.
    I now have a new Optima Battery and a new coolant pump. The brake actuator was also done and i have a spare skid ecu. I hope there isn't more surprises.
    #30 AlohaSpirit, Aug 17, 2018
    ITBland, bisco, Raytheeagle and 2 others like this.
  11. AlohaSpirit
    75
    23
    Hawaii
    6 month update. I get the odd P1121, P1116 code from time to time, sometimes after filling gas. My coolant is topped off and isn't leaking. Info from the forum says I shouldn't be too worried since it's for cold starts and cabin heat.
    Called a place because I was interested in hybrid battery diagnostic and the guy said no need if I wasn't having a problem. (Still getting 45mpg +)
    Was quoted 1200 to rebalance battery tho and would have to leave it for a week. (I read the info regarding the $400 reconditioners and not sure if I'm up for that). Gonna run as is for now.
    Wishing everyone a Happy New Year
    Aloha
  12. JC91006
    16,748
    8,554
    $1200 to rebalance a battery is crazy expensive. If I were to do this, it would be no more than $100. All you do is leave a charger and discharger on. You don't have to physically do anything
  13. AlohaSpirit
    75
    23
    Hawaii
    I read some instructions and you still have to take out the rear seats and connect everything directly to the battery, right?
  14. JC91006
    16,748
    8,554
    You can get to that battery in about 10 minutes, minimal disassembly required.
  15. litesong
    litesong Active Member
    371
    122
    Everett, WA
    My $6 cigarette lighter air tire pump gave great service, then quit. Replaced the dollar fuse, now works top-notch, again..... no $500 tow.
  16. AlohaSpirit
    75
    23
    Hawaii
    Ok. I'll search around the forums for some info.
  17. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    No need
    And you don’t have to fully remove the battery to install the cable
  18. Patrick Wong
    18,200
    6,500
    Check coolant level by removing the radiator cap, do not be satisfied just by looking at the reservoir.
    Raytheeagle, AlohaSpirit and Skibob like this.
  19. AlohaSpirit
    75
    23
    Hawaii
    Did that. All is good.
  20. Patrick Wong
    18,200
    6,500
    OK, you probably don't care too much about cabin heat in Hawaii - so there is no immediate need to replace the engine coolant valve until you have state emissions testing which requires no logged DTC and no check engine light.
